Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-29-2009, 09:49 AM   #136
Spacelord is an unknown quantity at this point
When I exit RR the master volume is muted and doesn't unmute again when I start RR, have to unmute it manually. I checked all settings, mute on exit is false, fading is false and maping mastervol is 0. What did I oversee?
Additionally, pressing on progress bar in music player doesn't send a event to the player.
All this happens after installing foobar and applying newest RR to the setup.
I searched in the topics for a while, but couldn't see any helpful hint.
Car: Ford S-Max 2,5T
CarPc: intel D201GLY, 7"-Touchscreen, RoadRunner, IGo8
HiFi: Alpine CDA 9855R, Diabolo D19/AA165g, Tymphany LAT500, Signat RAMbo, AudioSystem f2-300
Spacelord is offline   Reply With Quote
Old 10-29-2009, 05:00 PM   #137
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Does it happen with other players ? RR doesn't change the master volume when exiting -- only the PLAYER volume and ONLY when mute on exit is enabled. This could be some setting in Foobar itself.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-29-2009, 08:02 PM   #138
Well, have to configure another player and look. (Aunt Edith told me yesterday that this also happen with winamp configuration)
It happens only exiting or hibernating with RR running (with foobar plugin).
I made a mistake, the master volume is on, but "wave" is muted. Foobar alone doesn't mute anything.
Tonight I also found out that foobar continues playing when I switch to video.
Old 10-30-2009, 08:21 AM   #139
guino's Avatar
Can you make/post a debug log ?
Old 10-30-2009, 05:15 PM   #140
hi guino,
i made 2 logs, one with winamp set as player and another one with foobar.
in both cases the wave is muted after exit.
with foobar I also reproduced file access error on forward and not working progress bar click
hope this would be enough. as additional information I also have silabs radio installed.
Old 10-30-2009, 07:23 PM   #141
Dougw133 is an unknown quantity at this point
Quote: Originally Posted by Dougw133 View Post
since I applied the update, switching from HD radio back to Music freezes/crashes RR. This has never happened, and I have all settings the same.
Dont mean to be over persistent but this is driving me nuts, I cant use the HD Radio without crashing if I go back to music. Where could I start to look? I'll post a debug tonight.
Dougw133 is offline   Reply With Quote
Old 10-30-2009, 08:44 PM   #142
Raw Wave
mitchjs is on a distinguished road
dont go back to music...
id assume, u already simplified... ie use carwings, with say WMP
and no plugins....
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 10-30-2009, 11:52 PM   #143
and no plugins....
I'll give it a go
Old 11-01-2009, 10:32 PM   #144
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
I've noticed a bit of instability with the newest Carwings lite skin and HD radio. I was occasionally getting a BSOD using the radio in Carwings lite. Completely random, sometimes while switching back to music, sometimes when letting it play for awhile and changing stations, when it did crash it was initiated by me hitting a button (skin command) Since I switched back to Shock v6.0, HD radio and system have been solid.
blk02si is offline   Reply With Quote
Old 11-01-2009, 10:56 PM   #145
Raw Wave
there is nothing special about the skin... a BSOD is a driver crash.... user code will not BSOD windows
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-01-2009, 11:09 PM   #146
High Voltage
blk02si's Avatar
That's what I thought too, but it only happens with the Carwings Lite skin, but honestly I think it has something to do with the USB X-Fi sound processor/card I am using. The HD radio output is being routed to the line in of that card. Just think it's strange it only happens with one skin, worth mentioning anyways.
Old 11-03-2009, 07:43 AM   #147
guino's Avatar
Quote: Originally Posted by Spacelord View Post
hi guino,
nothing unusual here, can you post your rr.ini ?
Old 11-04-2009, 03:26 PM   #148
yes, sure
Old 11-04-2009, 06:42 PM   #149
drewbp is an unknown quantity at this point
Dont know what version of RR this started with, but since this is the latest and you read this one regularly, I will post here.
My problem is with resume. If I shut down the laptop or hibernate, I have no problem with resume. The last song playing comes up where I left off. If I exit RR with the exit key, I can see a resume write, but it is for the last song playing when I shut down or hibernated, and not the last song playing when exiting.
HARDWARE: Dell 8600 w/WiFi and dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, BU353 GPS w/iGuidance, OBDPros w/DashCommand, Always the latest version of RR with DFX Skin
drewbp is offline   Reply With Quote
Old 11-04-2009, 07:38 PM   #150
Raw Wave
since you didnt provide enough info here for use to help you...
but a debug.txt of a session and u exiting would help
ill take a guess, using dx4 skin?
-Thanks
Mitch
www.rush2112.net
within our hearts
RR 06-01-2009 Release mitchjs Road Runner 64 07-03-2009 01:39 AM
XM works in Timetrax, not RR bruha Road Runner 25 12-30-2006 08:38 AM
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
