Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-03-2009, 01:37 PM   #46
brandensin is an unknown quantity at this point
yeah, i am having unicode issue as well... minor though compare to what i had to deal with.. hopefully, next release take care of it. U use foobar2000? i can't never get it to work for some reason.. maybe i should try now since i got a major problem out of the way..
Quote: Originally Posted by vinchan View Post
Thanks for the tip. I tried, and the unicode problem still remains.
brandensin is offline   Reply With Quote
Old 10-03-2009, 02:03 PM   #47
vinchan is on a distinguished road
Try this, this is where I learned to use Foobar as my audio player
http://www.mp3car.com/vbulletin/rr-r...er-plugin.html
vinchan is offline   Reply With Quote
Old 10-03-2009, 02:46 PM   #48
Raw Wave
mitchjs is on a distinguished road
the foobar plugin is included in installer, using another one, might be going backwards
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 10-03-2009, 02:48 PM   #49
Raw Wave
brandensin, vinchan, i think you guys are both dealing with chineese unicode....
best bet is to deal with Guino, but, not just say unicode problem remains...
get a mp3 file to G, maybe a screen shot
i tried a chineese mp file, looks fine to me, but i can never be sure
with any unicode... since i NEVER really have to deal with unicode in USA
some things i didnt know...
UNICODE is only supported in ID3v2, NOT in ID3v1
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-03-2009, 03:11 PM   #50
suavecito's Avatar
suavecito is an unknown quantity at this point
Quote: Originally Posted by mitchjs View Post
albumart only an issue if you're using a plugin that affects the albumart indicator
and its in most cases, MP3Art plugin
mitch
mitch, I am having the same problem and I am not using any plug-ins at all.
eLite Lite has been released
suavecito is online now   Reply With Quote
Old 10-03-2009, 05:57 PM   #51
Raw Wave
it doesnt have to be mp3art
it could be any plugin that touches albumart
i have seen a plugin try to use albumart, when it shouldnt too!!!
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-03-2009, 07:13 PM   #52
yeah.. guino has sample songs.. So, all i have to do to use foobar is to install foobar2000 and COM SERVER and set the player to foobar(auto) in config? Is that it? Is foobar native just like winamp?
Old 10-03-2009, 09:29 PM   #53
[QUOTE=mitchjs;1346957]brandensin, vinchan, i think you guys are both dealing with chineese unicode....
Enclosed are the pictures... It happens whenever I need to browse files.
Old 10-03-2009, 09:43 PM   #54
Raw Wave
sounds right..... i did only try foobar2000 once way, back when G 1st did the module...
native is a loose term here, but RR directly controls it via the com interface
ONLY use the foobar add on in the installer, i cannot say if the one in the post in the forum is up to date!!!
the one in the installer has the unicode support
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-03-2009, 10:07 PM   #55
suavecito's Avatar
Quote: Originally Posted by Blue ZX3 View Post
Yes, already noticed and fixed..
I downloaded this file and have noticed the following:
I receive a run-time error,
Run-time error '381'
Invalid property array index
or it returns a complete different screen then the one that I am currently working on at the moment.
This happens when going form standard skin editor mode to virtual editor and back to skin editor mode.
This was also was happening before I replaced the skin editor (10-01-09 included file) with the one I downloaded.
Old 10-03-2009, 10:20 PM   #56
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Does it do it on the same screen, all, random. Could be something you have defined on a screen thats missing from objects.txt? I'm not sure, does it say do the same with the default skin(carwings dyno lite)?
Trying to narrow down if its skin related or app related.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-03-2009, 10:53 PM   #57
suavecito's Avatar
I have tried it with carwings lite and carwings full and I still get the same results. I believe it may be the application itself causing the problem.
Old 10-04-2009, 01:34 AM   #58
I tried it.. didn't work.. i select the songs from an album.. it didn't load up into a playlist.. i minimized RR to check the foobar, its playlist is emty as well.. Tried it both auto and manual.
i am gonna run debug to see what's going on.. I'll post it here..
edit:
10/4/2009 12:43:05 AM: Warning: Could not find Foobar2000 in the provided Path (C:\Program Files\foobar2000).
but i noticed foobar2000 was launched every time i started RR, so that warning doesn't make sense. Am i suppose to use a different set of commands that i used to control winamp?
Old 10-04-2009, 04:33 AM   #59
The Curator
Blue ZX3's Avatar
No. I recently DL'd the very latest foobar2000 v0.9.6.9 and tested the it against the 10/1/09 RR release and had no issues. I even installed foobar2000 right in RR's folder. I think that the issues has to do with the COM server part of foobar. Did a clean install of RR, installed foobar v0.9.6.9, and the COM Server from site listed in docs. Ran RRConfig and set the player to foobarRR (manaul) and its path.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-04-2009, 04:43 AM   #60
The Curator
Blue ZX3's Avatar
Yep, I get it too...
Will fix, and repost another one...
Oh..lookie...there's one now....
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
RR 06-01-2009 Release mitchjs Road Runner 64 07-03-2009 01:39 AM
XM works in Timetrax, not RR bruha Road Runner 25 12-30-2006 08:38 AM
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
