Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-04-2009, 07:09 AM   #61
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by brandensin View Post
edit:
10/4/2009 12:43:05 AM: Warning: Could not find Foobar2000 in the provided Path (C:\Program Files\foobar2000).
but i noticed foobar2000 was launched every time i started RR, so that warning doesn't make sense. Am i suppose to use a different set of commands that i used to control winamp?
I seem to recall a few months ago, someone was having trouble with foobar, turned out they had two entries in RR.ini for foobar, one with the wrong path. (Clue : have a look at the foobar 2000 player plugin thread, especially page 2)
Enforcer is online now   Reply With Quote
Old 10-04-2009, 08:23 PM   #62
brandensin is an unknown quantity at this point
Checked it several times to make sure i don't have any duplicate path definition.. I see only one.. Anyway, took blue's advice, reinstalled the whole thing. Now that warning is gone but still not working properly. Whenever i load the album, it empty out the playlist(foobar). Not quiet sure what's going on behind.. I am posting my debug file if anyone can help me out... I was thinking about posting it in foobar thread but since i didn't install the DLL(plugin which might be outdated), I wasn't sure.. Please let me know if this is not appropriate. Thank.
brandensin is offline   Reply With Quote
Old 10-04-2009, 10:15 PM   #63
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Its always best to attach the log instead of C&P'n it..
On the bug side...
Only other things i see are that you have RRToaster PI commands w/o haveing the PI loaded/installed, but your not using WA either. I don't see anything else that stands out in you log.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-04-2009, 10:23 PM   #64
Raw Wave
mitchjs is on a distinguished road
no need to look.. there is a bug in adding of album in foobar
for now, use another player
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 10-04-2009, 10:37 PM   #65
got you.. back to good old winamp for now
Old 10-04-2009, 11:15 PM   #66
The Curator
Blue ZX3's Avatar
Well...seeing that it seems to be a known issue, should be doc'd somewhere so that ALL of us can be informed of known issues. I for one, didn't know that, and might exaplain some of the odd beheivor I encountered while using foobar w/ RRMedia.
@brandensin clean up that log post.. please & thanks.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-05-2009, 08:06 AM   #67
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I just tried 0.9.6.9 and and the only way there's an issue with foobar is if your install is not right. (Given that if your install is not right RR may even freeze up, but it works just fine if the install is correct).
Please check the item in RED on this thread:
http://www.mp3car.com/vbulletin/rr-r...er-plugin.html
If you don't see it just like the picture in the above thread (or if your paths do not match up), please uninstall foobar AND com server and re-install them to get the correct result (I personally messed up my install when upgrading foobar and saw the SAME EXACT RESULTS that you and Mitch reported -- Uninstall/Re-install fixed it).
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-05-2009, 10:43 AM   #68
Raw Wave
its wasnt known, till brandensin posted the problem, and i actually tested it
and said, hey it doesnt load albums for me...
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-05-2009, 01:58 PM   #69
Guino, status looking good here. Just tested adding a song, confirmed that works... I normally add a whole album.. Now that clears out the whole playlist.. Therefore, none of the button is responsive since there's nothing in the playlist. I did a fresh reinstall, same result.. Could you confirm one more time that adding a whole album should also work?
Old 10-05-2009, 03:39 PM   #70
Raw Wave
brandensin, its fixed
we found it...
I have a new installer all built for you to test
do you know my FTP?
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-05-2009, 03:44 PM   #71
That's great. where can i download it, i'll test it.
we found it...
do you know my FTP?
Old 10-05-2009, 11:57 PM   #72
toyotatyrant's Avatar
toyotatyrant is an unknown quantity at this point
I have downloaded and installed this current version and it actually seems to run a little faster than earlier versions. For some weird reason, I had to ever so slightly resize a few labels in my skin which was no big deal at all. I do get a periodic error 51 when using the skin editor once in a while. Other than that it seems to do what it is supposed to do.
__________________________________________________ _
ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
toyotatyrant is offline   Reply With Quote
Old 10-06-2009, 08:48 PM   #73
guino's Avatar
1st post updated.
Old 10-06-2009, 10:38 PM   #74
This is now fixed. Fixed it yesterday. All is well.
Old 10-07-2009, 07:53 AM   #75
marteline's Avatar
marteline is an unknown quantity at this point
Gpsspd
Guino,
there is any way to supress the "unit" information on the GPSSPD? after the last uptade, the GPSSPD info is for example 100Km/h instead 100, and I am facing some trouble to make it fit on my skin.
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
RR 06-01-2009 Release mitchjs Road Runner 64 07-03-2009 01:39 AM
XM works in Timetrax, not RR bruha Road Runner 25 12-30-2006 08:38 AM
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
