09-30-2009, 11:53 PM
#1
Raw Wave
RR 10-05-2009 Refresh Release (Available Now)
*** Available now from here ****
A bunch of little things.. we wanted to get this out asap...
Foobar users, please check the foobar thread ( http://www.mp3car.com/vbulletin/rr-r...er-plugin.html)
WOW!
First I want to thank everyone who reported and helped get us though all the changes in the last month's build...
We did alot of clean up in this build. Nailed the bugs introduced when going to full unicode support. One thing to note, Winamp Versions < 5.30 does not support unicode. and Nailed some bugs we introduced during our late night programming...
Some KEY fixes:
Albumart Indicator
Foobar Fixes
tagcache fix
Albumart
Horm fix(actually a resume.ini issue from 8/1)
Improved icon support on iLists work with PNG/GIF transparency (BLACK also works)
Fixed Silabs USBRadio.dll not using correct audio capture device
Standard list, when DL contains music type files, black bar appears on inital selection
Code:
LEGEND:
- = Removed
+ = Added
* = Changed
! = Major code change
# = bug fix
^ = Note
10/5/09
# Path bug for plugin data path
# Foobar2000 player, a few different issues
# tagcache.ini not saving on exit
+ Added ONRBUTTON, ONMBUTTON events (Right/Middle Mouse Button Clicks)
# SkinEditor bugs fixed, see skineditor history.txt
* SkinTool updated v2.0, see skintool history.txt
* RRconfig, Added wintvpath, closeplayeronexit settings
9/30/09
+ SKIN DEFINITION "IND" Indicator image modifier property, code improvement (see "new skin commands.txt")
IND,NAME OF INDICATOR,PATH TO OFF IMAGE,PATH TO ON IMAGE
Example: IND,SHUFFLE,Indicators\Shuffle_off.png,Indicators\Shuffle_on.png
* Cleaned up "albumart" indicator code
9/29/09
# Issues with older winamp versions that dont support unicode playlists
# Tagache issue on restart
9/27/09
# RRConfig, Foobar200 (Manual) setting
# RRSkinEditor, couple of small fixes (see skin editor history for details)
9/24/09
* Improved icon support on iLists work with PNG/GIF transparency (BLACK also works)
# Standard list, when DL contains music type files, black bar appears on inital selection
# Fixed Silabs USBRadio.dll not using correct audio capture device
9/23/09
# fixed Albumart indicator (aka J skin definition)
# fixed resume.ini processing at resume from HORM
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
10-01-2009, 01:35 AM
#2
The Last Good Gremlin
Guino,
Just so I clearly understand. I have a Silabs radio and travel often to unknown cities. Please explain to me in detail, how to load local stations into the RR Radio screen. Yes, I am asking to be spoonfed!!!!
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
10-01-2009, 02:41 AM
#3
You can use the "LOCAL" command to switch the station list from normal to local.
Also the command "SEARCHPRESETS" search all frequencies and save the station in the local station list.
10-01-2009, 06:42 AM
#4
Raw Wave
GizmoQ, johnnyS has it right
the command "SEARCHPRESETS" will automaticly put you into LOCAL list too
"LOADLIST;mycoollist.ini" will also load a station list into the LOCAL LIST
now, do u need me to explain how to drive to a different city? or we good
-Thanks
Mitch
www.rush2112.net
within our hearts
10-01-2009, 09:18 AM
#5
RoadRunner Mastermind
I guess he wants something like this:
On your home city:
-Leave LOCAL mode OFF
-Add your home presets carefully (by hand to be sure)
When you leave town:
-Turn Local mode ON
-Use SEARCHPRESETS or add the local stations by hand (however you like)
When you go home again turn LOCAL mode off (your home stations should come back).
That's basically it.
Ride Runner RR's Myspace
10-01-2009, 09:28 AM
#6
Terminal flasher
aww yea birthday release thread
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
10-01-2009, 10:36 AM
#7
yayeah!
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
10-01-2009, 11:31 AM
#8
On your home city:
-Turn Local mode ON
Thanks, that's a start on what I was looking for. A single button with the command "SEARCHPRESETS" will automatically change the radio screen to local mode and search for and load all local radio stations as well as save them in a file "localradio.ini". I can then create an RRCode script to rename it and load it later using the LOADLIST command, but I have to switch to localmode manually first. Is that right?
For clarification, I have some more questions. Above what signal strength does this search occur? and can that level be adjusted? In what directory is the "localradio.ini" saved? If I don't switch to localmode first, will the LOADLIST of a saved "localradio.ini" over write the "radio.ini"? If I shut down the computer while listening to the radio in local mode, when I turn it back on will RR's radio still be in localmode still on the channel I was previously listening to? As I understand the above, the RADIO_MENU_FUNCTION.SKIN is no longer necessary - Please verify/confirm for me.
Thanks for the quick reply.
10-01-2009, 01:46 PM
#9
I'm sure this has been mentioned before, but are there any plans for RR to support MediaMonkey in the future?
My Mustang Website
My mp3Car Worklog
2006 Ford Mustang:
Tungsten Grey Premium GT | Dark Charcoal Leather | 18" Fanblades | 5-Speed Manual
Spoiler Delete | C&L Intake | Flowmaster American Thunders | MGW Interior Pieces
10-01-2009, 01:48 PM
#10
The Curator
Mitch's dept...
Going by code... I belive that it should be in the RR's Root (most likely).
10-01-2009, 01:51 PM
#11
The Curator
This should have been posted in the new RR Project section at top. Under Feature request...
Thanks.
10-01-2009, 01:53 PM
#12
Perhaps this has been discussed before, but I didn't see it and think it would be good practice...
Would it be possible for the downloads to have the date / version number included in the file name?
10-01-2009, 02:50 PM
#13
i'm working to end the develope of silabs module
i think can be make it in 4-5 days (i must add some detail to some function)
it is a "porting" and "merging" of my old plugin and base rds/old-silabs module
when i save my user-preset (0-9) i name the preset grabbing the rds name
if all whants i can name all the station using the rds radio name (if it has), is simple
all purpose (if are ok for guino and mitchs) are welcome
[QUOTE]Above what signal strength does this search occur? and can that level be adjusted?/QUOTE]
in my old plugin i can adjust the level strength under the radio must search an alternate frequencies, user can set it inside the silabs.ini config file (r from a form inside rr (in my old plugin)
2 example:
preset rds name (i use a popup  )
http://www.mp3car.com/vbulletin/rr-p...ml#post1232910
and the form loaded inside rr by my old plugin
next have less options to be saved (all audio var doesn't be used)
10-01-2009, 07:49 PM
#14
Raw Wave
GizmoQ, yep... do searchpresets
that will switch to local, search for presets, and they save in radiolocal.ini
-Thanks
Mitch
www.rush2112.net
within our hearts
10-02-2009, 12:01 AM
#15
Think I'm the first one to download this month. Thanks for the constant updates and improvements.
HARDWARE: Dell 8600 w/WiFi and dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, BU353 GPS w/iGuidance, OBDPros w/DashCommand, Always the latest version of RR with DFX Skin
| Thread Tools |
| Display Modes |
Linear Mode
