Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-04-2009, 08:14 PM   #1
aleshu's Avatar
aleshu is an unknown quantity at this point
Transparency issue in iLists latest build
Hi all, I had my system working perfectly & flawlessly until I updated to the latest version (10-05-09). Now the selection bars in every iList have lost their transparency and, instead, a pink (RGB FF00FF) bar appears as their background color.
I have tested it in two machines and the same happens. I downgraded to the previous release to test it and it works fine. The problem is that I can't keep the outdated version because of the reminder nag we all know about, that forces me to update and therefore gives me headaches for all the things that dont work anymore and the ones I have to check that work OK before transferring the system to the carPC..
Examples of iLists, all failing to show transparent sel bars:
IL,PL,RGBff00ff,RGBff00ff
S,22,105,463,304,148,148,148,32,32,32,255,255,255, 255,0,255,255,255,255,TRUE,18,"Tahoma"
S,392,54,400,293,255,255,255,32,32,32,236,208,100, 149,149,149,255,0,255,255,255,255,,18,"Tahoma"
IL,DL,RGBff00ff,RGBff00ff,************,2,70,50
Any ideas, see anything wrong here?
aleshu is offline   Reply With Quote
Old 11-04-2009, 10:13 PM   #2
Raw Wave
mitchjs is on a distinguished road
when i look at ur S definition i see
255, 0, 255 for selection color, isnt that PINK
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 11-05-2009, 05:58 AM   #3
aleshu's Avatar
Yes indeed, but that pink (FF00FF) is supposed to be transparent. Anyways, I think that the IL PAR2 definition overrides the selection color in the S definition. Is that right?
Old 11-05-2009, 06:52 AM   #4
Raw Wave
maybe...
but i dont see that written in the skin commands.txt
infact i cant exactly tell you what par1 and par2 does when its in text mode
but i think when both are RGBFF00FF, that still uses the color settings in the S definition
it works, i change ur S def, where the pink is, to another color, it sets the color of the selection bar
S,140,81,430,446, 148,148,148, 32,32,32, 255,255,255, 0,128,128, 255,255,255,TRUE,18,"Tahoma"
IL,PL,RGBFF00ff,RGBFF00ff
got me
im not a skin expert for sure
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-05-2009, 08:14 AM   #5
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
at the top of skin commands.txt you find:
-trs is TRUE/FALSE to set if the list should display a selection bar (when trs=true).
your definition:
S,22,105,463,304,148,148,148,32,32,32,255,255,255, 255,0,255,255,255,255, TRUE ,18,"Tahoma"
tells it to display a selection bar -- if you don't want one, setting it to false should do it.
The other definition (without the TRUE) likely defaults to TRUE (as you omitted the value)
Let me know if that doesn't work -- we can always fix things (Plus, there are very FEW people using text mode ilists).
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-15-2009, 01:51 PM   #6
aleshu's Avatar
mitchjs, thank you for your answer. Yes, if I change it to another color it displays well. But anyways I can't accomplish transparency.
Here I attach pics of the same ilist using the latest RR version and using the previous one. There's just something changed in the new version that disabled this feature.
Guino, I followed your suggestion and changing the trs had no effect at all. Thanks anyway. Actually I am very surprised that I be the only user using transparent selection bars!
S,22,105,463,304,148,148,148,32,32,32,255,255,255, 255,0,255,255,255,255,FALSE,18,"Tahoma"
Old 11-15-2009, 04:17 PM   #7
Raw Wave
your the ONLY one using it in TEXT MODE
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-15-2009, 05:35 PM   #8
guino's Avatar
Well, very FEW use text mode... TEXT MODE+TRANSPARENT SELBAR = probably only you... try this instead just to see..
S,22,105,463,304,148,148,148,32,32,32,255,255,255, 8,0,8,255,255,255,FALSE,18,"Tahoma"
Old 11-17-2009, 06:18 PM   #9
aleshu's Avatar
Thank you, somehow that mysteriously worked
BTW, what's against text mode? Isn't it supposed to be faster? And simpler? Don't say that my iList doesn't look nice...!
Old 11-17-2009, 07:54 PM   #10
Raw Wave
absolutly NOTHING against text mode
yes.. your list looks nice
thats how the bug went unnoticed for awhile, till you found it
we tested ilists, but not in text mode with transparancy
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-18-2009, 07:19 AM   #11
guino's Avatar
I've already fixed the issue for next release (and what you have now will also work). Like Mitch said, we test text mode ilists, and even improve the code for it every now and then -- it's just not used as much since most people like the bitmap based lists. Performance wise, there's not a lot of difference.
Latest Build - 06-10-2009 ClockWorK Driveline 1 06-11-2009 04:29 PM
RR Config.exe and Radioshark error in latest build Firebird2 Road Runner 0 09-10-2007 05:53 PM
Beta: CCarProject BenjaminS MacCar 157 09-27-2006 01:25 AM
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
Build my PC? diddy0071 Newbie 9 07-11-2005 01:00 AM
