03-21-2005, 11:12 AM
#46
I just tried it and it works perfect on my systems that I have tested on. Please redownload the File and run it off of your computer. See if that fixes it.
Other than that, you should beable to go to the Add/Remove Programs and select Remove.
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
03-21-2005, 11:42 AM
#47
Deactivated
You got PM
03-21-2005, 01:32 PM
#48
Quote: Originally Posted by Diewlay Lowmo
Same here, it hangs at copying tvskin or something like that.
I just used an older version and updated it with the binaries from the roadrunner website.
03-21-2005, 04:22 PM
#49
Deactivated
Exactly but unfortunately I no longer have an older version..
*Edit* I downloaded the binary version, and manually set it up, thanks.
04-24-2005, 10:32 AM
#50
The requested URL /roadrunner/road-runner3-20-05.exe was not found on this server.
Link seems to be dead
04-24-2005, 10:37 AM
#51
change 3-20 to 4-21
'01 4runner ░ P3 866 ░ 128mb ░ 20gb HD ░ Radeon 9200SE PCI ░ SB PCI ░ Slim DVD/CD-RW ░ USB GPS ░ 7" Lilli vga TS ░ XP Pro ░ MC ░ Routis '04
ForemostWebHosting
SpeedGuyParts.com
04-24-2005, 12:08 PM
#52
Quote: Originally Posted by sabre
change 3-20 to 4-21
4-20-05 not found..
04-24-2005, 12:31 PM
#53
Quote: Originally Posted by Urinemachine
4-20-05 not found..
http://www.majesticpw.com/roadrunner...ner4-21-05.exe
looks like he typo'd on the link on his page, use this.
e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
sold it all... :-(
Coming Soon - 2007 BMW 335i UMPC install
04-25-2005, 10:19 AM
#54
Here is the Page that you need to go to, it always has the currently updated file on it: http://www.majesticpw.com/roadrunner/Index.html
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
05-03-2005, 09:32 AM
#55
Quote: Originally Posted by bry21317
That page has a link which still points to 4-20 (doesn't exist) instead of
4-21
05-03-2005, 12:34 PM
#56
Thanks Kbyrd. I missed this. It is fixed for now. I will be updating to the next version soon, just hadn't had the time.
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
07-15-2005, 12:27 PM
#57
Hey, I just downloaded your program but unfortunately I haven't had the chance to enjoy it. I installed the free winamp 5.0, and also the windows media player classic you have on your site. After doing the installation of RR, and trying to run it, i get "error 372 Failed to load Flash form.....yada yada". Do I need to download macromedia flash from somewhere else or what is the problem?
Thanks in advance.
07-15-2005, 01:05 PM
#58
RoadRunner Mastermind
Read the installation FAQ.. you need flash to run a skin with flash, this is a 700Kb file..
Ride Runner RR's Myspace
07-19-2005, 02:33 PM
#59
ok i downloaded the file and put it in the main roadrunner directory
C:\\Program Files\RoadRunner\Flash\Flash.ocx
Still get the same error. Is there any other essential files i need other than the installer and the flash zip? Or is there any settings I MUST change inorder to get it working? Thanks.
07-19-2005, 02:38 PM
#60
Raw Wave
You need to put flash.ocx in c:\windows\system32\
| Thread Tools |
| Display Modes |
Linear Mode
