02-05-2005, 05:05 PM
#1
RoadRunner Mastermind
Vehicle: 04/Mazda/RX-8
Update: 2-12-05.. Flash Support!...
Release 2-12-05 is out...
http://guino.home.insightbb.com
Update Includes the below listed (I'll use the bullet thingy): - Added Flash Support! (see sample with Skin Update)
- Updated BrushMetal Skin with TV support
- Added Mix ID3 tag load (loads available ID3 info separately)
- Fixed "freeze" bug when software was running past mid-night
- Yet more prevention against empty playlists
About RADIO: Got that RadioTime card ordered.. now I gotta wait again..
Try it at will, let me know of any bugs.. if you're having some sort of problem/bug, please add this line into the RR.INI file:
debugmode=true
Then try to reproduce the problem and send me the debug.txt file created in RR's folder.
Thanks for your support,
Enjoy!
Next to come:
-D-Link Radio support
-Radiator Support
02-05-2005, 06:05 PM
#2
Vehicle: Honda Civic 5-Door '97
Girder:
So far it's very cool remote works awsome in Audio mode but having some problems in video mode where the remote buttons dont seem to do anything when a video file is displayed full screen but when the info bar is displayed at the bottom the remote functions work fine without problems but i'd like to be able to use remote when a video is playing full screen i belive rr.exe is not receiving the remote commands when MPC is on top.
PlayList
ID3 is working ok now but would be cool if you could set which fields are displayed eg. Artist & Track Name or Album Name & Track Name.
BUG: If i open a M3U file it opens the playlist and every other audio file in the subdirectories of where that m3u file is saved.
02-05-2005, 06:31 PM
#3
Quote: Originally Posted by vortex
Girder:
PlayList
I'll try the Girder with video -- haven't had a chance to do it yet, but what you said makes sense, just need to add some extra code for full screen support..
I was planning on adding the format for the playlist display.
I haven't made any special handling for M3U files yet, if you want to simply open the M3U file by itself, then clear the playlist and use the ADD1 Button to add only the playlist.
02-05-2005, 07:39 PM
#4
OK great i hope you sort out the girder problem.
Clear Playlist dont seem to work properly if i clear playlist the playlist on winamp is cleared but not in road runner so if i select a song it crashes Road Runner as it doesnt exist in winamp.
In GPS mode using Map Monkey my start bar is displaying on top of Map Monkey covering half of the buttons if i click on the top at road runners title bar then the start bar dissapears but re-appears if i click anywhere on map monkey. Not sure if this is a problem with road runner or map monkey as i also had the same problem with Media Car with Map Monkey.
02-05-2005, 10:53 PM
#5
-Ok, fixed the Girder-Video issue.. it works fine now both when the controls are displayed and when they're hidden.
-I've fixed anothe bug with clear playlist, and added some more prevention against it crashing the software...
-This taskbar "issue" is just an option of the taskbar itself -- you should just NOT use the "keep task bar on top of other windows option".
I'll post those changes sometime tomorrow with the next update..
02-06-2005, 08:21 AM
#6
Thanks for the task bar trick it has worked!
One thing i noticed is if i close Map Monkey from whithin Map Monkey menu then Road Runner still displays a black GPS page until i press X or Back.
Thanks for your help and i can't wait till next version
02-06-2005, 08:35 AM
#7
I get an error with the new version, 2-5-05 Binary download, since the source wasn't yet updated.
Here is the Error that I am getting:
Run-time error '53'
File not found.
This occurs on My laptp, I am just trying to test the new version before Putting it to the car. I then opened just Winamp and click Play, the same file plays not problem.
Any Ideas? This is also with the ID3 tags on and off, both.
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
02-06-2005, 08:43 AM
#8
Raw Wave
Vehicle: Jeep GC
Well of course it does, that's what the X is for!
02-06-2005, 10:37 AM
#9
Run-time error '53'
File not found.
Thanks,
Bryan
It's somewhat unsafe to close the screen when detecting that the enbbeded application has closed -- also, this provides for better future interfacing capabilities (i.e. running and alternating applications from same screen likin in the launch screen)
I believe you might be having problem with a playlist bug I just fixed.. can you tell me what exactly you do to get it ? Or better yet, add:
debugmode=true
That is, into your RR.INI file, run RR and cause the problem and PM me with the debug.txt file.
02-06-2005, 02:16 PM
#10
Vehicle: Opel Vectra 1.8i (1992)
Does the launch applications option already work?
I'm trying to start some apps within RR but no success so far. I love to start floats mobile control to connect with my K700 mobile. This allows me to use the mobile as a remote control for all aplications on the pc (for example controlling winamp, mediaplayer, rebooting pc, shutting down lilliput, etc.)
If the launch option is already active I would apreciate some help in making it work.
02-06-2005, 03:03 PM
#11
Here is what the Text File states:
2/6/2005 4:00:50 PM: Start
2/6/2005 4:00:50 PM: Master Vol: Volume Control
2/6/2005 4:00:50 PM: No Treble Support
2/6/2005 4:00:50 PM: No Bass Support
2/6/2005 4:00:50 PM: No Master ON/OFF
2/6/2005 4:00:50 PM: Source: Wave=&H1008/1
2/6/2005 4:00:50 PM: Source: SW Synth=&H1004/2
2/6/2005 4:00:50 PM: Source: 3D Depth=&H100A/3
2/6/2005 4:00:50 PM: Source: SPDIF=&H1001/4
2/6/2005 4:00:50 PM: Source: Aux=&H100A/5
2/6/2005 4:00:50 PM: Source: TV Tuner Audio=&H1000/6
2/6/2005 4:00:50 PM: Source: CD Player=&H1005/7
2/6/2005 4:00:50 PM: Source: Line In=&H1002/8
2/6/2005 4:00:50 PM: Source: Microphone=&H1003/9
2/6/2005 4:00:50 PM: Source: Phone Line=&H1006/10
2/6/2005 4:00:50 PM: Source: PC Speaker=&H100A/11
2/6/2005 4:00:50 PM: Winamp window not found.
Also, Winamp is running in the backround and is working correctly.
The window is showing Winamp 5.08.
It has been working fine on this computer, until this version.
The old version is now doing the same thing.
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
02-06-2005, 04:16 PM
#12
The Launch screen is fully functional already. You basically need to set up a "launch" folder in the same format of MediaCar (SubFolders are the program names and a INI file in the folder has parameters such as path and Window title to enbedd). You can typically point this into your MediaCar's Launch folder and it should work.
On The PATH NOT FOUND: I am finishing to add improved debug info and error prevention to a release I'll post later today..
02-06-2005, 04:28 PM
#13
The Vauxhall Vectra Project
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
Just tried my 'unreleased' MC skin on this and it looks like it will work fine. There are some monor tweeks to complete... including a big relisation that for some reason the only decent copy is on my CarPC ( guess who be doing what first thing lol ). Any way the point is that I will release it soon... and because of the way I do my skins there should be no big problem in putting your own logo in.
How ever - Guino - I would like to ask - is there any way you can place a setting in so that people like my self can select an external programe instead of the radio.
http://www.mp3car.com/vbulletin/showthread.php?t=41604 is a good example of the skin... I'd like to start a web prog up embeded instead as I don't have mine connected - others may have other ideas.
Cheers guys
Terran
02-06-2005, 04:38 PM
#14
Cheers guys
Terran
If you'd like to run an application when clicking the Radio button, simply change the code from "RADIO" into "RUNW;!<PATH+COMMAND>;<TITLE>" and it will do it. For example: "RUNW;!C:\WINDOWS\NOTEPAD.EXE" to run notepad, and return to RR when exiting. If you read the documentaion you can create custom "launch" screens with dynamic commands.
02-06-2005, 04:45 PM
#15
Simply change the code from "RADIO" into "RUNW;!<PATH+COMMAND>;<TITLE>" and it will do it.
Just looking at the documentation now... I am not very clear where you are refering to.
Terran
EDIT if I read you right... this will only start the app maximised.. I was looking to have it embeded so it could still run and I could move to other screens and come back at some point in the very same way the GPS software does... example attached....
| Thread Tools |
| Display Modes |
Linear Mode
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| compact flash raid |
B3AND1P |
General Hardware Discussion |
37 |
03-13-2008 07:23 PM |
