Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 02-07-2005, 05:22 PM   #1
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Running RoadRunner and Winamp
Okay, I just download the 2-2 release and put everything under Program Files\RoadRunner\
When launch RoadRunner, Winamp launch first on it own, then RR.
Now I have 2 separate windows RR and Winamp.
If I close winamp, RR is not close but music is also stop and RR audio control button don't do anything.
Why is that?
BTW, I am running Winamp v5.06
Now the contents of RR.ini
Code:
voice=false musicpath=C:\MusicDir\English\ videopath=C:\VideoDir\ cddrive=c: [Local Disk] dvdpath=Internal launchpath=Click here to set path winamppath=C:\Program Files\Winamp\ skinpath=C:\Program Files\RoadRunner\Skins\Alpine (Red)\ mpcpath=C:\Program Files\RoadRunner\mplayerc.exe screentype=16:9 videoautohide=true videohidetime=4 videofiles=.AVI,.MPG,.MPEG,.RM,.RAM,.VOB,.ASF,.WMV audiofiles=.M3U,.MP3,.WMA,.OGG,.AAC,.MPC,.VQF hidemouse=false coverfile=*.jpg useid3=1 showid3playlist=true showid3browse=true gpsmode=0 mapmonkeypath=C:\DestinatorApps\Frontend_BETA3\Destinator3.exe gpspath=C:\DestinatorApps\Frontend_BETA3\Destinator3.exe gpsname=*Destinator*[Dest1.3] exitmode=0 showicons=true showextensions=true titlesafter=- listfollowssong=true resumemusic=true audiorepeat=off audioshuffle=off gammamode=1 dateformat=MM/DD/YY timeformat=HH:MM AM/PM
Running on my desktop for now.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-07-2005, 05:29 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Why is that?
RR uses Winamp to control/play music. Wianmp should run when starting RR and close when closing RR.. As long as your Winamp is not set to Always on top you won't have any issues with it in your car (it will stay behind and out of sight). If you wish to remove the winamp title from the taskbar, simply set it to be on the Systray Only (winamp preferences).
I may add an option to hide winamp in the future, right now, this is better for development and doesn't interfere with the usage of the software. If I hide winamp and RR crashes, then you'd have to use Task Manager to close it, get it ?
Also, I recommend Winamp 2.9x since it is faster to load... but winamp 5 should work fine..
guino is offline   Reply With Quote
Old 02-08-2005, 01:47 AM   #3
drait's Avatar
drait is on a distinguished road
Guino, something maybe to mention in the Readme or the website... if you have Winamp Lite (say from the old MediaCar install) it seems that the Mixer/EQ does not function. Probably because of the "lite" functionality
The full Winamp 2.9x fixed that in a jiffy.
89 Supra Turbo
drait is offline   Reply With Quote
Old 02-08-2005, 02:03 AM   #4
guino's Avatar
Yeah.. my bad.. I have a bad case of the documentation-fobia.. :/ But I try.. I've been working on it a bit here and there..
Old 02-08-2005, 11:09 AM   #5
MySQL Error
MatrixPC's Avatar
Cool, all work fine now. There maybe a little bug here and there, but at least the thing is working
When I get some free time, I will be able to code something for the safety stuff such as DVD/Video/Vis disable when ebrake is not engage. Pause music or whatever currently play when ACC is OFF. Basically serial safety/legal stuff that also implemented in Frodoplayer.
Old 02-08-2005, 11:51 AM   #6
guino's Avatar
Nice! Dont forget to get the latest source before making changes and specially, dont forget to send me a copy to share it with everybody else
Old 02-08-2005, 03:20 PM   #7
MySQL Error
MatrixPC's Avatar
That is my point to get RR installed.
Old 02-09-2005, 09:07 PM   #8
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
I had some issues using winamp ver. 5. My winamp would start playing the song it stopped when i entered the video window, then i could stop the music by pressing "list" and when i selected the video, the music would start again. I assumed it was a problem on my end (someone WOULD have said something:P ) when it asks for the winamp path use the version of winamp that comes with mediacar
ATXaccord05 is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
