02-20-2005, 03:14 PM
#16
RoadRunner Mastermind
Quote: Originally Posted by vortex
This version still seems to load gama control when internal gamma is selected.
First time i press gamma button it's ok go bacxk to day then night and it turns into a redish colour.
Is it possible to select or create different aspect ratios for the video as i have a 16:9 screen but run at 800x600 so i don't want movies to be chopped on at the sides only the top and bottom.
Anyone know how to edit the rate of the spining car logos as i want it to spin slower.
This version feels more stable and responsive than the last one keey up the good work
The redish problem has been fixed in 2-20, along with the gammacontrol loading problem.. if you're getting that, you probably don't have 2-20 OR you have the Redish Gamma (and GammaControl) from running the buggy RR previously.. I'd suggest to restart your machine nad make sure you have 2-20. The redish Gamma should NOT happen Unless your Gamma settings (on your skin's General.ini file) are set to a redish gamma.
Ride Runner RR's Myspace
02-20-2005, 03:17 PM
#17
Quote: Originally Posted by chuckster
Wahooo. The video_ts is working. I will have to move all my JPG files up one folder though :-( but it is doable.
I'm having some serious issue with video playback all together though (not with just this release). When I select the video button I see the player start up screen and I struggle to get the control panel at the bottom to show up. When I get the panel to show up I then select a movie. The movie will start but I can't see it, I can hear the sound but I still see the video player start up screen.. When I finally manage to escape out of RR the video is now visible. It's like it does not get focus until I leave RR.
Any idea?
Thanks,
Chuck
Do you have any videos at all on your "Videopath" folder ? I'd suggest to put one ther at least, then delete your videos.m3u file and re-run. Select whatever videos to play and see if it works. After that, you can delete/move your video file(s) from the videopath folder. It will start using your last playlist from then on..
02-20-2005, 04:07 PM
#18
Quote: Originally Posted by aguila
well thanks, loos nice but on the version shown above you have the ETA on the bottom of the screen and the one I downloaded has it at the top. Is it a different version?
No, is the same version. In the screenshot you seen, i'm using the latest update of Brushed Metal Skin (downloadable from the guino's web site), and i've disabled the upper bar of MapMonkey (pressing the "i" button).
Nothing out standard
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
02-20-2005, 04:21 PM
#19
but I clearly see the ETA in the lower bar in your screenshot?!? Is that in the Brushed metal skin than? How does this work, does it pick the data from MM?
02-20-2005, 04:22 PM
#20
my region is set to english.... and so is the keyboard...
i just checked with all other version's of RR
it's a new thing that started in the 20-02 version
all fonts is set to a font called "SF Chaerilidae" and it displays fine in all
other RR version's
so the prob must be in the new RR Internationalization system
not on my system
besides "SF Chaerilidae" only displays std. english signs and letters so there should be no problem at all
02-20-2005, 04:29 PM
#21
You can make the info bar disabled by default in MM, just run its config.
02-20-2005, 04:31 PM
#22
Exactly
Mr.Fabio
Travla C134
02-20-2005, 04:33 PM
#23
That probably IS the problem.. Windows will not let me select a font that is different than the current charset selected.. I have just tried it here, and when I switch to english (and re-run RR), it works fine..
In any case, I'll add two options to RR:
1-Disable Internationalization
2-CodePage Selection (System, Western, Hebrew, Greek, etc)
That way, we can all be happy..
02-20-2005, 04:34 PM
#24
thx dear god.. it was killing me.... but the weird thing is... it displays the font correct in the playlist ... it's only on time, mp3 info, temp, etc. that it screws up
02-20-2005, 04:38 PM
#25
Quote: Originally Posted by guino
The problem is, MM can only run one copy of itself.. if you were for instance running it in RR (old version), then you updated it, and re-run RR, you'd probably get that.. Please restart your machine and re-test it.. if anything, please make sure you have 2-20 version (by re-downloading it).
This is what this version does: First time going into GPS will run MM no matter what (so if you have it open already it will cause errors).
Then after that, if you leave RR, MM will close. If you use the Close button in RR, MM will close and re-entering the GPS screen will re-load MM. I have even added code to close the GPS screen when using the "EXIT" button in MM, but apperantely this works only on some machines (I assume it's a bug with MM's SDK).
In any case, as long as MM is not running before you run RR, it should work.
I have MM final release.
RR 2-20.
Brushedmetal Guino full release downloaded with update.
Test:
Open RR
Launch MM
Exit to MM (not with X but ->)
Launch audio player
Reopen with button created in audio player the MM (pre open)
All ok
Close MM whit ->
Close RR with Exit main button
Close all , but error of MM displayed.
Test
Reopen RR
Launch MM
Displayed bad MM (see the screenshot)????
Mauri
02-20-2005, 04:41 PM
#26
What Kind of error from MM are you getting ??
02-20-2005, 04:49 PM
#27
See the screenshot
EDIT:MM after the error don't diplayed embedded to MM correctly.
Restar the PC ,and OK.
Same procedure posted, same error......etc....
Mauri
02-20-2005, 04:51 PM
#28
See the screenshot
Mauri
Do you get the same error when closing MM with the X button in RR ?
02-20-2005, 05:00 PM
#29
Yes , the same error.
02-20-2005, 05:03 PM
#30
Seems like MM is not taking kindly of the "close" command.. funny enough, the SDK command to close MM doesn't work either..  I'll look into it..
For now, I'd suggest you to set Map Monkey as external GPS and set it as default to run External GPS, with the window title "Map Monkey -" (no quotes) it should work like it used to on prev. versions.
| Thread Tools |
| Display Modes |
Linear Mode
