Quote: Originally Posted by guino
Seems like MM is not taking kindly of the "close" command.. funny enough, the SDK command to close MM doesn't work either..
I'll look into it..
For now, I'd suggest you to set Map Monkey as external GPS and set it as default to run External GPS, with the window title "Map Monkey -" (no quotes) it should work like it used to on prev. versions.
Ok ,tested , work set to EXTERNAL, but not displayed embedded RR,hide the RR button in this mode , temp, scroll title etc...
EDIT: the 19-02 version of RR running ok
Not problem , tested in my house PC the 20-02 v. but have several bug posted.
One other question for Guino:
i have make the prototype of your hardware to reader the tamper(you kit)
Created the .hex file and burning one P12C509.
The 4 DS18B20 comunicate with the COM ok,but second me one problem:
the tamper read its not real,exsample 25°C real embedded to RR write 7578,0 (same in Yperterminal), set to Centigrade,but....same to F,with jumper to hardware and MM config utility.
Secon me its one problem or of the firmware about the Ds1820.asm write not correctly , or the DTR signal is low to power the hardware(tested, 4.40v after the regolator 78L05(the regular voltage its 5v correct )....
UPDATE
fixed problem , work correctly!
EDIT :sensor 3-4 in txt file its the DS18S20 not B20 , bad compatible.
1 and 2 its DS18B20, and work ok with Yperterminal.
Tomorrow tested with RR
If is ok , make one board home made of you hardware....
TXT file to save with Ypert.
F and C
The problem its to displayed the temp. to RR.
Comma problem...see the screenshot
In Italian XP configuration the point don't work the same of UK configuration, change in the RR firmware whit comma to reader the temp. , second me work correctly !
Its possible?
Mauri
