This is not working for me...
If i first clear playlist, then highlight the directory where the playlists are located, then press + (SELECT+) the result is a blank playlist...
If i clear playlist, then highlight the directory where the playlists are located, then press +1, the result is a blank playlist...
If i clear playlist, then highlight the directory where the playlists are located, then press play, the result is the first playlist in the directory loaded...
The only way i can load everything in all playlists is to clear playlist,browse into the directory, press +1 on each playlist, then the result is that all playlists are loaded...
See this debug on what i did:
2005-02-26 22:18:39: Executing: LIST
2005-02-26 22:18:41: Executing: CLEARLIST
2005-02-26 22:18:44: Executing: ADD1
2005-02-26 22:18:45: Shell: "C:\Program\Winamp\winamp.exe" /ADD "c:\MP3Lists\Test"
2005-02-26 22:18:53: Executing: EXIT
2005-02-26 22:19:06: Executing: LIST
2005-02-26 22:19:08: Executing: SELECT+
2005-02-26 22:19:10: Shell: "C:\Program\Winamp\winamp.exe" /ADD "c:\MP3Lists\Test"
2005-02-26 22:19:12: Executing: EXIT
2005-02-26 22:19:13: Executing: AUDIO
2005-02-26 22:19:15: Executing: LIST
2005-02-26 22:19:18: Executing: SELECT
2005-02-26 22:19:20: Shell: "C:\Program\Winamp\winamp.exe" /ADD "c:\MP3Lists\Test\1st.m3u"
2005-02-26 22:19:22: Executing: EXIT
Tried with older versions of RR.exe, same result, tried with Winamp 5.02 and 2.91 same result, same on all 4 of my computers...
The way I would prefer it to be is that when you press SELECT, SELECT+ or ADD1 it would load everything that is in that directory, regardless of if it is MP3 or M3U files...
Any ideas?
EDIT:
Found another strange thing with playlists. Had in my Playlists folder a file called New.m3u and a folder called New with some playlists in it. When i had Show extensions checked in setup, and played the New.m3u file, it loaded ok, byt when i unchecked Show extension and selected to play New.m3u, it went into the New folder and loaded the fist playlist there instead...
Strange...
