Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 02-27-2005, 11:43 AM   #16
Raw Wave
Gobby is on a distinguished road
Just tested this version - looking better than ever - love the ability to hide the taskbar :-)
Could I ask for a little request?? Is it possible to add 24 hour time as well as the others?? I'm not sure about the rest of the UK users but I personally use 24 Hour time a lot.
Gobby is offline   Reply With Quote
Old 02-27-2005, 12:08 PM   #17
Mr.Fabio's Avatar
Mr.Fabio is on a distinguished road
May be a problem of regional settings...
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 02-27-2005, 12:12 PM   #18
Raw Wave
Just played around with the time options - Long time converts it to 24 hours
Old 02-27-2005, 01:54 PM   #19
Deepgear is on a distinguished road
Hi Guino,
I am still Playin around with holistics new skin, but I have got a Question.
Is there a chance to embedd the destinator Buttons like Menue, Planning Mode, Redlgiht... I mean only the Main Buttons in RR??
(The following Menues with Plan Route, Gps Status, can sty like they are.The skin You see is "CdRsKuLL With BG", it may be a good basic, because of the centered menues. So we only need to integrate the main buttons)
This would be a great step for integrating MM completely.
Thx
Deepgear
Deepgear is offline   Reply With Quote
Old 02-27-2005, 03:18 PM   #20
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Quote: Originally Posted by Blue ZX3
one more small thing with the "tagXXXXXX" in the audio player screen:
when a song is previosly playing/stopped/paused when you close RR, then run RR again the tagartist/tagalbum stuff is blank until it goes to the next song...same with going into the browser and selecting a new playlist....
I'll look into this, I have not done extensive tests with it.
[QUOTE=Blue ZX3]
Could the currenttracktime be made so that when you clicked it, it would change to the remaining time like in winamp...?
[QUOTE=Blue ZX3]
Definitely, just never implemented it since I thought it was redundant since the total time is always on display..
also, would anyone like to have a way to add songs to a favorites section?...kinda like FP...if you have played around with it much..
How does that work ? I've never seen that.. probably best if made in a form of a playlist ?
I also see my name in the donations list twice...Woohoo...
$236 So far -Fee's
I can only thak all of you guys..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-27-2005, 03:24 PM   #21
guino's Avatar
Quote: Originally Posted by wizz
Guino 2/27 takes out the video. Message on screen says "cannot find xvid commpressors" Install previous update video returns.
EDIT: We are talking internal player, OK
Wizz
Yeah, I've been messing quite a bit with the buil-in player.. it really kind of sucks, but from machine to machine you generally get a different effect...
I was messing with it until 4AM (my time) so if you think you may have doenloaded it before then, I'd try and re-download it to see if it works.. and if it doesn't: I'd suggest you try and download the FFDShow filters from www.ddigest.com (Divx->Software->Filters) and try again.. if it doesn't work, I'm going to HAVE to make up some tweaks for the built in player..
Old 02-27-2005, 03:28 PM   #22
guino's Avatar
Quote: Originally Posted by mauri
Setting hide taskbar with RR config, hide ok, if resetting the task bar appears but not menu XP icon
I'll add preventions before restart/power off.
The winamp visual in my PC home work perfectly(Milkdrop setting) in my carPC work ,even 5 secon, black screen (in the space of Milkdrop visual run).
What did you mean by the above, it takes 5 seconds to work or it doesn't work at all ?
Old 02-27-2005, 03:35 PM   #23
guino's Avatar
Quote: Originally Posted by chuckster
I see the multiple command support for a buttom and I was thinking (scary i know!) how about allowing the user to name a button what they want. I'm not sure if this would work but I thought we are so dependant upon skin developers to make the one skin with all the right buttons for our needs that how about if a skin developer just develops the layout and the user can name the buttons whatever.
If a GPS button is wanted to be in the upper left part of the menu instead of the lower right we just need to rename the button in the skin file and move the command line to that location.
Satellite radio is something I want to add to RR but right now there is a radio button. I do not plan to have a radio on my PC as I plan to have a head unit in my vehicle so I could rename the "RADIO" button to "XM RADIO" on my own without having to request a new skin.
Just a thought...Maybe this would really allow for the next level of customizing.
Chuck
I have indeed thought of that, and you CAN do it right now.. You just have to make blank buttons and define dynamic labels in the skin (like I do with Car: and Outside: -- for temps.) The problem with using "Dynamic" labels is that none of the effects used in the buttons will show onto the labels, and that includes pressing the button etc.. so really it just doesn't look all that good, but it works.. there's just not much I can do to "fix it".. I'd say chances are that if you had the PSD file to edit the label(s), that it'd look better and would be just as easy to change..
Old 02-27-2005, 03:37 PM   #24
guino's Avatar
Sure, it's been there all along, just where it says Time format in RRConfig, select : "HH:MM:SS" or "HH:MM" that will be military time.
Old 02-27-2005, 03:40 PM   #25
guino's Avatar
Quote: Originally Posted by Deepgear
Hi Guino,
Thx
Deepgear
Yest there is... and it's already implemented, we just need to get a skinner to do it.. the only thing we need to figure out is how to remove the buttons from the bottom of MM. I'm assiming there's probably a skin setting we can use for that.. then all those buttons (AND The buttons inside MM, plan route etc) can be performed inside RR.
Also, I may have failed to say this, but you MUST enable the TCP Listening on MM to allow integration with RR's skins (open settings.ini and set listenport=9913 and enable=yes)
Old 02-27-2005, 03:58 PM   #26
wizz's Avatar
wizz is on a distinguished road
Video's work fine on last D/L of 2/27, but when you leave the video screen, the main RR screen appears for a split second and then the screen goes black, with no return from that state...have to re-boot OS/RR.
PS: Aready have FFDShow & AC3 filter. The codecs were there RR just couldn't find them, but thats OK now...it's just the exit to main RR, as described above.
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 02-27-2005, 04:10 PM   #27
mauri's Avatar
mauri is on a distinguished road
Guino wrote:What did you mean by the above, it takes 5 seconds to work or it doesn't work at all ?[/QUOTE]
No, launch Milkdrop to Audio Player of RR, run the visualization with the effects ok, but after 5/10 seconds max, hide the effect of Milkdrop and black screen to his place (i speak ONLY of the space reserved to the visualization of Milkdrop).
I use BrushMetal update.
EDIT:the blu car icon in RR skin is to use ???
I don't have tested run in my car with GPS connect and new BrushMetal update , tomorrow I make the first test
Mauri
mauri is offline   Reply With Quote
Old 02-27-2005, 04:19 PM   #28
bry21317 is on a distinguished road
I have updated the Install to add all of the new changes as of 2/27/05. It has the updated Binaries and also the updated Skins.
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
bry21317 is offline   Reply With Quote
Old 02-27-2005, 04:44 PM   #29
guino's Avatar
Wizz
Ok, cool, I'll try to find why this problem is happening..
Old 02-27-2005, 04:48 PM   #30
guino's Avatar
Mauri[/QUOTE]
Wierd, have you tried another Vis (AVS/Tripex3) ?
The Cop car is supposed to be hidden, until you go over the speed limit set in RRConfig. Then when you get to that speed it starts blinking to warn you that you're over the speed limit.. that voice warning was just way too annoying..
RR 2-20-05 ... Bug Fixes ... guino Road Runner 123 03-01-2005 02:27 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
