Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 02-27-2005, 05:03 PM   #31
mauri's Avatar
mauri is on a distinguished road
Quote: Originally Posted by guino
No, launch Milkdrop to Audio Player of RR, run the visualization with the effects ok, but after 5/10 seconds max, hide the effect of Milkdrop and black screen to his place (i speak ONLY of the space reserved to the visualization of Milkdrop).
I use BrushMetal update.
EDIT:the blu car icon in RR skin is to use ???
I don't have tested run in my car with GPS connect and new BrushMetal update , tomorrow I make the first test
Mauri
Wierd, have you tried another Vis (AVS/Tripex3) ?
The Cop car is supposed to be hidden, until you go over the speed limit set in RRConfig. Then when you get to that speed it starts blinking to warn you that you're over the speed limit.. that voice warning was just way too annoying..[/QUOTE]
Use Milkdrop( Winamp release 5.0.0.8 )AVS don't work,no tested with Tripex3
Yes, ok, is hide,good idea the appears of the car to speed warning , the original voice message is
EDIT: is possible write my personal over speed limit in RR Config (55 is to default(KmH?) ,possible chance to exsample to 90 Kmh) ?
Set the same speed limit warning to MM config to work correctly?
Thanks Guino
Mauri
mauri is offline   Reply With Quote
Old 02-27-2005, 05:08 PM   #32
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Thanks Guino
Mauri
I ask if yu CAN try a nother vis (other than MilkDrop) and see if the problem happens with it as well.. Try AVS for instance.
The speed is set in RRConfig in the GPS section. you can set whatever you want, it has nothing to do with MM Settings.. and it is in whatever you use in MM (mph or Km/h).
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-27-2005, 06:13 PM   #33
mauri's Avatar
Ok, tested in my carPC.
Set to RR AVS
Set Options/Winamp (winamp.exe settings no RR )to visualize AVS.
Perfect, to RR the AVS work correctly.
Use this!!
EDIT:Milkdrop same problem posted,my card to Epia V8000 is flac to Milkdrop?
No problem , its ok AVS!!!
Mauri
Old 02-27-2005, 06:22 PM   #34
guino's Avatar
Set to RR AVS
Use this!!
Mauri
You might want to try changing settings on MilkDrop .. it is probably something related to too much CPU usage etc.. reduce frame rate to say 15, and disable any fancy options I'd say..
Old 02-27-2005, 07:16 PM   #35
carpcnoobie's Avatar
carpcnoobie is on a distinguished road
Just downloaded the latest version. OK, maybe I missed something. With daily upgrades, it's very possible.
OK.. a few things I'm wondering about.
-- In the audio browser. Before I could click on the "+" to add all the songs to the playlist. Now, it's not working. I can add one at a time, but not all.
-- I'm trying to reproduce this problem, but sometimes when I go from the audio browser back to the player, or click the return button in the audio player, the vis shows up. I don't use vis, so this is a double whammy for me. If I can reproduce the exact conditions, I'll try to give you better explaination.
-- Is there any way you can put in an option for us iGuidance/Routis users to click OK for the nag screen? There are several programs out there, and I'm using one now, but I think it would just be cleaner getting to Routis. Not a big deal.
Sorry for the gripes. I'm really lovin' this program and feel bad about complaining.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 02-27-2005, 07:59 PM   #36
guino's Avatar
I changed a little bit on the + code.. but it's supposed to only have effect when you click + in a m3u file.. I'll double check.
AVS has serious problems in some machines.. that is, RR actually "finds" the VIS window and enbbeds it, even though you have not started it.. To get rid of this, just set MilkDrop in RRConfig .. it should prevent that from happening.
I don't have Routis/iGuidance to know details of the window, how to find it or test anything to get rid of the nag.. I'd suggest trying to find a direct EXE patch/hack for this.. depending on the type of the window, even resource hacker might take care of it..
Old 02-27-2005, 10:46 PM   #37
guino's Avatar
I've just posted a few more fixes/changes.. I'm expecting a radio tuner during this week (Thanks to "Clean Customs"). So I'm going to get things ready in RR for that.
Let me know if any of the fixes still don't work.
Old 02-27-2005, 11:42 PM   #38
Chita79's Avatar
Chita79 is on a distinguished road
seems as though the "appearance" and "day/night" come up as pressed as default until u actually press it... hmmmm, anyone else gettin this?
EDIT: looks like it leaves the last button used in RR pressed.. i just got the "exit" button pressed when i got back in RR...
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
Old 02-27-2005, 11:46 PM   #39
guino's Avatar
What do you mean ? The button shows in a pressed state by default ??
Old 02-27-2005, 11:51 PM   #40
Chita79's Avatar
found another bug in the video player... the mute button goes crazy when u press it... it wont go back to "unmute" ... u might want to check that out guino
oh.. i found the "pressed" buttons bug in the video player as well... there is always some button that is in the pressed mode... hmm
Old 02-27-2005, 11:54 PM   #41
Chita79's Avatar
also, would it be possible to add an option to go to video browser when u press the video section? thanks again on an excellent program!
Old 02-28-2005, 12:07 AM   #42
Chita79's Avatar
when i enter RR... the appearance button and night/day button are highlighted, i didnt touch them... so for some reason something is telling them to be pushed down. The same happens in the video section with some of the player controls (stop, play,...etc)
Old 02-28-2005, 01:46 AM   #43
guino's Avatar
You always have the weirdest bugs... never seen nor heard of that.. nor the code that controls this stuff has been touched for the longest time... :/
Did you try those update links I sent you a while back ?
Old 02-28-2005, 02:46 AM   #44
Thanks for the response. I'll double check on my end as well about the +. As far as the Routis/iGuidance clicker... I know Frodo has done this with FrodoPlayer. Perhaps he'd be willing to help you out in creating something like this. We've already tried with ResHack to get rid of the nag screen, but no go.
Thanks again.
Progress Meter:
Old 02-28-2005, 02:52 AM   #45
guino's Avatar
Thanks again.
I actually fixed the + bug (yes it was a bug). Sure thing, if you can get the intel/info off Frodo, I can definitely add it into the code. I just don't have how to implement it out of nothing (no software to try)..
RR 2-20-05 ... Bug Fixes ... guino Road Runner 123 03-01-2005 02:27 AM
