02-28-2005, 03:15 AM
#46
hmm, i dont know what it is... but i did update from that link u sent me... weird.. could it be a skin issue? i dont see why though..
the video mode is still buggy and causes RR to get stuck inbetwen music player and video player...
btw, if i wanted to assign "Minimize" for girder, how exactly would you do that, i havent "learned" a button yet on girder. Could Ctrl-Alt-Del be learned to a single button as well?
thanks again
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
02-28-2005, 03:27 AM
#47
I figured out about the vis coming up. I had it come up again when I would leave video, the vis would come up again. I opened up winamp and ran it directly. I simply disabled the vis in the config of winamp and the problem is gone. I just downloaded a version from your site but I'm still getting the select + bug.
Also, does anyone else get a real slow start up of RR when using the 'hide taskbar' feature? It seems like RR waits for a sec.. fights with the computer then hides the task bar. Usually takes about 3-5 seconds. This is not really a problem for me as I'll have the taskbar tucked away anyways. Just noticed it in trials on my desktop.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
02-28-2005, 06:03 AM
#48
How do you disable vis in winamp ?
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
02-28-2005, 08:34 AM
#49
Wizz
Simply uninstall them.
Progress Meter:
02-28-2005, 09:17 AM
#50
The Vauxhall Vectra Project
Dumb question time... set my night skin and day skin up but when I press the day night button only the Gamma changes... its bound to be me... just not sure what.
Cheers
Terran
02-28-2005, 09:19 AM
#51
It's me too
02-28-2005, 09:22 AM
#52
Quote: Originally Posted by guino
Yest there is... and it's already implemented, we just need to get a skinner to do it.. the only thing we need to figure out is how to remove the buttons from the bottom of MM. I'm assiming there's probably a skin setting we can use for that.. then all those buttons (AND The buttons inside MM, plan route etc) can be performed inside RR.
Also, I may have failed to say this, but you MUST enable the TCP Listening on MM to allow integration with RR's skins (open settings.ini and set listenport=9913 and enable=yes)
Ok Guino, I found a way.
I simply made the main_bar.jpg of MM 1dot hight... thats it.
Could you please give me the cmmands I need for menue and so on ?
Thx
Deepgear
02-28-2005, 09:25 AM
#53
Cheers
Terran
I haven't tried it yet, but there is a new skin command for day/night skin. Look in the text about skin commands.
Progress Meter:
02-28-2005, 09:46 AM
#54
So in other words, we need to
02-28-2005, 09:56 AM
#55
This is what happerns when you just download the binarys lol.
Mmmm So I need to change the skin again, looks like I'll have to use the internal gamma thing then.
Terran
02-28-2005, 10:59 AM
#56
Two bugs....
1) Internal gamma does not work for some reason... checked my files against the orgoinal MC ones
2) When you switch with the new command the main screen looses font info... ie at the top of mine I use the LCD font. It turns to arial I think instead. Tested this manually and works fine.
3) Again the gamma does not work either using the skin switch function. I'm working on the basis that it is sposed to read the info from the general file.
Cheers
Terran
02-28-2005, 11:12 AM
#57
does the same here... but not everytime only once in a while.... but on mine it dosent reset to arial it displays the arial font on top of the original font
02-28-2005, 01:28 PM
#58
I had a chance to use  and I missed it!
Progress Meter:
02-28-2005, 01:29 PM
#59
RoadRunner Mastermind
Thx
Deepgear
The list of Commands can be found in Map Monkey's Help file (Development folder) -- The section you want is under Reference->Winsock->D3Request.
Instead of what you might think, there's no way to pull up those "predefined" menus from MM. So what you need to do is make a Menu/Skin file (like the exit menu in the brushmetal for instance), that is shown when you press a button in RR (say to be equivalent to the "menu" Button of MM. then on this menu's buttons you'd make the commands be like "MM;Destinate_Address||EXIT", "MM;Destinate_Favorites||EXIT" etc.
The "||Exit" in the end makes it so the menu is closed after executing the MM command to display the dialog you've requested. You may want to swap the order of the commands (just try it) to say: "EXIT||MM;Destinate_Address" ..
Ride Runner RR's Myspace
02-28-2005, 01:32 PM
#60
Two bugs....
Cheers
Terran
The Internal Gamma only works if the general.ini file has the Day and Night Gamma Info. It is completely unrelated to the skin switch command.
Maybe you want to send me your general.ini file to take a look (or compare it with other ones you have). Have you tried a different skin at all ?
Also, on the skin switch font problem.. can you test to see if switching the skin in the skin browser always works or has the same bug ? I don't think I have seen that before..
| Thread Tools |
| Display Modes |
Linear Mode
