03-07-2005, 05:03 PM
#16
Nope no succe. I think I tried it all out, but no it will not work. I tested the RR config, the RR GPS_MENU.skin but no. And as I can see I've the wave on my soundcard because I can adjust the slider to get back the sound but it will not work with the hide taskbar, as I can't minimize the RR .
03-07-2005, 05:08 PM
#17
RoadRunner Mastermind
You should run MapSonic "outside" RR (not have RR running) to be able to view it's info with WinspectorSpy.
Ride Runner RR's Myspace
03-07-2005, 05:14 PM
#18
Quote: Originally Posted by guino
Well, there's only one requirement for it to work: the GPS Window Name or the windowsearch string (Launch screen) must be exactly: "Map Sonic" (no quotes and no extra spaces) then RR will reset the wave line output every second. There's a requirement also that you must have a "wave line" on your soundcard.
EDIT: if the above Window title is not enough to find MapSonic, I'll need somebody with the software to run WinspectorSpy and tell me the class name and the possible Window Titles so I can "identify" it...
OK, the window title is "ViaMichelin MapStore 2.32" and the class name is "SWApplicationWindow" but as i said, this is for version 2.32, i don't now if Clarre has the same version...
03-07-2005, 05:40 PM
#20
That's a good start, I need some other Window names as to find something that is always in there... then I can put it RR and release it with next version.
03-07-2005, 05:43 PM
#21
I have the
00630238: SWApplicationWindow "ViaMichelin MapStore 2.3"
But where shall I put in the name? In the
Map Monkey Path
GPS Path
or
GPS Window Name?
and shall I use GPS Mode External?
Excuse me but this is little more then I can handle, but I do the best to learn.
03-07-2005, 05:45 PM
#22
Raw Wave
If it is the same version, try:
External GPS Mode, Window name "ViaMichelin" (without the "") or "!SWApplicationWindow" (also without the "")
03-07-2005, 05:56 PM
#23
Sorry Guino, I don't know if you've seen this (our posts have the same time):
http://www.planetsourcecode.com/vb/s...38589&lngWId=1
It can be a good "generic fix", keeping locked the wave balance always.
#24
Nothing you try on the current version will work... because the window name in RR right now is just not correct (in RR) according to the info you gave me.. The info you gave me is more than good, I just would like to see the window names from other people (if possible) as to accomodate everything at once.
EDIT: The mixer in RR is more than enough and this is only ONE line of code.. kjust gotta get the correct info and that's it..
03-07-2005, 05:59 PM
#25
Nope not even that works. And there seems to be another problem it raises the volume to 100%, but of course only in the left channel. So I have to go the hard way and autohide the taskbar so I can adjust it manually.
Oh BTW thank you for your support! It's great to have this forum so
thank you all. I'll try further.
03-07-2005, 06:11 PM
#26
If you want to try a quick fix, place this file over your current RR.exe (must close RR first):
http://rmc.pimpedwheels.com/rr.exe
03-07-2005, 06:22 PM
#27
I have the
Map Monkey Path
GPS Path
or
GPS Window Name?
You don't have to care about Map Monkey Path, put the path to MapStore.exe in the GPS Path, put "ViaMichelin" in the GPS Window Name, and select GPS mode to External. This should get the application to run embedded, this is working for me, but Guino has to change RR to fix the balance problem...
Guino, I just tried to change the line to:
"If LCase(.AppName) = "viamichelin" Then AdjustOutput IdxWave"
and it is working perfectly...
03-07-2005, 06:23 PM
#28
Sorry Guino but it's the same.
and you should know how greatful I'm for your help.
I'm sure ther will be a solution.
03-07-2005, 06:40 PM
#29
Well since Passe had how to test it and says it's working, then I've updated that exe for you Clarre, with Passe's fix
03-07-2005, 07:12 PM
#30
Yeeeha! That's it working great. Thank you, thank you, thank you.
As I said it would be a solution for it. Now I have to copy over all new stuff to the carputer. I'm sure it should work even in the car. Otherwise I be back.
One more time your are the best THANK YOU.
| Thread Tools |
| Display Modes |
Linear Mode
