Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-07-2005, 02:54 AM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow RR 03-07-05.. Few Improvements..
A few improvements from the radio version:
-Added radio "LOCAL" skin command
-Added "SAVELIST" skin command
-Added "MINUS1" skin command
-Added Dlink Automatic Driver Switch (Crash prevention)
-Added special handlings for skins with a Folder List and a Playlist on a same screen
-Added Map Sonic GPS wave Line Fix
I have included the DLink drivers (OLD&NEW) on the binary and source packages. RR will automatically switch them accordingly when you search presets. This is something that can only be done in 2000/XP machines, but I believe 9X/ME machines do not have the problem with the old driver.
PLEASE NOTE:
The NEW DLink driver does not support seeking or the stereo indicator -- but it really doesn't crash on 2000/XP. If you wish to keep using your old driver, simply delete or rename the DLink sub-folder in RR. If you're running on 2000/XP, RR will still try to reset the DLink card as before using it to prevent crashes (as often). If you don't wish RR to reset your DLink card and wants to speed up the radio loading, you can simply delete/rename the devcon.exe file in RR's folder.
Man I need to start making some FAQs...
Let me know,
Guino.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 03-07-2005, 04:00 AM   #2
iPal is on a distinguished road
guino
so you found new driver somewhere?
sorry for late...
i had driver on my carpc...
i just got it downloaded today...
well i think you've got it...
it is same size as one i've got...
iPal is offline   Reply With Quote
Old 03-07-2005, 04:53 AM   #3
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
O. K. I like it so far, but there's one more improvement I'd like to see. Can you implement the ability for me to listen to videos on any page. Right now as soon as I switch away from the video the radio or MP3 player comes back on. Sometimes I'd like to listen to the videos even when I navigate using GPS. And if I had video controls and info available while doing so (like you did for the radio), that would be all the better.
DVD playback, too.
GizmoQ is offline   Reply With Quote
Old 03-07-2005, 06:57 AM   #4
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Particularly usefule when listening to music videos, and checking gps stuff...
EDIT: maybe putting an extra button ont the video screen, like in GPS (X - to quit video, and <- to keep it running and goto menu)
RoyN is offline   Reply With Quote
Old 03-07-2005, 07:34 AM   #5
vortex's Avatar
vortex is on a distinguished road
Now that radio is done I have a few requests.
* Can we save audio playlist as m3u file
* Remove 1 from playlist
is it possible to intergrate winamp library? as it already easily allows you to create/ view edit playlist and search all my mp3s in like 2 secounds.
www.vortexleather.com
vortex is offline   Reply With Quote
Old 03-07-2005, 12:02 PM   #6
drait's Avatar
drait is on a distinguished road
Remove 1 is already on Guino's "duly noted" list (per the Requests.txt file)
89 Supra Turbo
drait is offline   Reply With Quote
Old 03-07-2005, 12:45 PM   #7
bry21317 is on a distinguished road
Updated the Installation for 3-7-05.
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
bry21317 is offline   Reply With Quote
Old 03-07-2005, 01:26 PM   #8
guino's Avatar
@vortex and @Drait
The Changes above mentioned ARE for what you want.. you CAN already do those things, you just need a skin that supports it. RR will save playlists you make in your music folder unless you set a "playlistpath=<PATH>" in your RR.INI (still needs to be added to RRConfig).
Old 03-07-2005, 02:02 PM   #9
drait's Avatar
SAVELIST and MINUS1... you da man Guino!
BTW, you've got PM.
89 Supra Turbo
Old 03-07-2005, 03:50 PM   #10
Clarre's Avatar
Clarre is on a distinguished road
Question
Thank you Guino for all that work you do with RR.
One stupid questin how do I use the Map Sonic GPS wave Line Fix?
I try to use the new updates but it seems to be the same problem as before for me. I must be stupid os something. I'm sure I've checked everything, but
I must have missed something.
Via Epia M1000
512MB RAM
120MB IBM Hard drive
Netgear MA111
Lilliput 8" Touchscreen
http://www.clarre.com/carcomputer.htm
Clarre is offline   Reply With Quote
Old 03-07-2005, 04:08 PM   #11
Raw Wave
RoyN's Avatar
Guino, this was talked about previously, but I wanted to throw it in just so you can think about it, or maybe it is just skin configuration...
Is it possible to have the << and >> (fast rewind and fast forward) in the VIDEO module work also as a Track Back and Track Forward like in the Audio module? It would be an idea ta have One Click=Next/Previous Click&Hold = ff/fr.
Also, is it possible for ff and fr to be scalable depending on video size? like 1% of video cause when looking at music clips the Fast forward in video is too much, but for long movies it would be fine...
Old 03-07-2005, 04:11 PM   #12
Passe is on a distinguished road
I think there is something wrong here, I use MapSonic sometimes and the window name for the PC app is "ViaMichelin MapStore 2.32" , the exe file is named mapstore.exe. MapSonic is the PDA version of the program... There are older versions out there also so the window name is different on older versions...
Passe is offline   Reply With Quote
Old 03-07-2005, 04:23 PM   #13
Clarre's Avatar
Question
Yes I see mine is in D:\Program Files\ViaMichelin\MapSonic\MapStore.exe
So long it's right? But what is wrong? It's annoying, because I cant have the hide toolbar in RR. Otherwise I only have sound in 1 speaker.
Via Epia M1000
512MB RAM
Netgear MA111
Old 03-07-2005, 04:34 PM   #14
guino's Avatar
Well, there's only one requirement for it to work: the GPS Window Name or the windowsearch string (Launch screen) must be exactly: "Map Sonic" (no quotes and no extra spaces) then RR will reset the wave line output every second. There's a requirement also that you must have a "wave line" on your soundcard.
EDIT: if the above Window title is not enough to find MapSonic, I'll need somebody with the software to run WinspectorSpy and tell me the class name and the possible Window Titles so I can "identify" it...
Old 03-07-2005, 04:36 PM   #15
guino's Avatar
I have thought of that.. things are the way they are right now to maintain MediaCar skins compatible, but I am adding new commands to allow for what you want above... I'll also improve the video stepping according to video size..
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
News on the 07 version netsuo NeoCar Media Center 14 11-06-2004 10:01 PM
