Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-07-2005, 03:39 PM   #1
Phythorian's Avatar
auto volume control
Just wondering..
The faster you drive, the louder the noise becomes in your car, so you have to set the volume higher to hear the same.
I'm talking if you have set your volume to conversation level, and not at competion level or so.
Could it not be possible to make some kind of program that auto adjusts the volume to the driving speed? Maybe using GPS or so?
Searched for this in the forum but couldn't find anything? Has this been done before?
If not, would it be hard to make?
Phythorian is offline   Reply With Quote
Old 03-07-2005, 03:45 PM   #2
RoadRunner Mastermind
guino's Avatar
Quote: Originally Posted by Phythorian
Just wondering..
Many cars (GM) have that built in their stock players.. it is definitely possible to do that using the GPS speed, although, not sure how to calibrate it as it stands RR can only pull GPS speed info from MM (and I haven't seen any other front end doing it either), but could definitely be done..
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 03-07-2005, 03:49 PM   #3
IntellaWorks's Avatar
Can RR grab nmea 1.83 data ?? or does mm do all of that intrensically ? if RR can grab the data it can just monitor the speed of the vehicle and calibrate the volume that way..
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 03-07-2005, 03:55 PM   #4
guino's Avatar
It COULD, but then again most GPS software (including MM) open (and LOCK) the serial port to where no other application has access to it, so unless somebody can make me a COM Port SPY (like Sysinternal's PortMon), there's hardly any other way of doing this short of getting your GPS app to deliver or allow polling this info from it into RR.
Old 03-07-2005, 04:00 PM   #5
Raw Wave
RoyN's Avatar
Why not use speed+mic for this? That way we can compensate for windows down and such? The adjustmen should be very drastic and there should be some way of ignoring "conversation", like detecting bakground noise, or hissing from windows?
EDIT: what about considering noise only after 5secs of CONTINUED sound level? this should compensate for voices vs. wind
RoyN is offline   Reply With Quote
Old 03-07-2005, 04:05 PM   #6
guino's Avatar
Noise, could work, but then if you have a Mic. is probably because you use NaviVoice, and threfore the Microphone line is also Locked for access. Maybe Something to lower the volume by mic. levels could be added to navivoice (since it holds the volume level info -- maybe, that is, if the SpeechAPI allows for reading that)
Old 03-07-2005, 04:10 PM   #7
Phythorian's Avatar
That's what I thought off in the first place, but when you play you're music, I think the mic will be picking up the loudness of the music, and raise the volume and so on and on...
Think the best way is using gps data in a way or so...
Old 03-07-2005, 04:11 PM   #8
Phythorian's Avatar
BTW I miss your face Guino, but I like the logo!
Old 03-07-2005, 04:22 PM   #9
Mr. Wiggles
shakes's Avatar
I think the mic would be a bad idea ... that way your volume would always go up everytime you yelled at someone in traffic
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 03-07-2005, 04:25 PM   #10
Raw Wave
RoyN's Avatar
As I said above in my suggestion, it would be filtering for CONSTANT noise........................................ read again mate!
The idea is that this "constant" noise will be able to ignore shouts/conversation/music... Although it might be possible to filter out the music, since the music is generated itself by computer. The idea is that sometimes your window is down, sometimes your window isnt down, sometimes you are accelerating, sometimes there is noise around you, sometimes there isnt... none of this is really 100% tied in to speed...
Old 03-07-2005, 04:28 PM   #11
Mr. Wiggles
shakes's Avatar
yes yes ... that's what I figured. just trying to make a joke.
My JeepPC Install
Old 03-07-2005, 04:39 PM   #12
guino's Avatar
I laughed hahaha...
Old 03-07-2005, 04:39 PM   #13
Raw Wave
RoyN's Avatar
oh.... no jokes after 9hrs of class in one day! ehhehe
Old 03-07-2005, 04:44 PM   #14
Raw Wave
RoyN's Avatar
less laugh more code!
Old 03-07-2005, 04:46 PM   #15
ddogg_777's Avatar
Guino, would virtual coms be the way to go in this instance?
http://www.mp3car.com/vbulletin/show...ight=ports+gps
ddogg_777 is offline   Reply With Quote
usb volume control?? help pleaseee 99acuracl Newbie 2 02-21-2005 06:09 PM
VOLUME_MIC LINE_can't get frodoplayer to use the mic line for volume control. GizmoQ FP Bug Reports 0 11-27-2004 05:47 PM
Volume control question.. Kamakazie2 Software & Software Development 3 10-07-2004 06:16 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-03-2003 11:00 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 10:43 AM
