Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 05-31-2005, 02:12 PM   #31
RiXst3r is on a distinguished road
Quote: Originally Posted by guino
What do you mean ? I have 4 USB devices plugged in the car, 3 of which are pllugged into a usb HUB, I can hibernate and resume without any issues.. so what kind of dongle are you talking about ?
sorry, I was referring to my above questions...
The usb serial adapter is not the thing with the issue, it is ibuscomm.exe crashing on resume from hibernate if you use it on a usb serial adapter...
gork was going to add the power managment code into cdr's modded app, and I was wondering if I should still wait for that to happen... otherwise I will just switch something else to the usb-serial adapter, and hope that software is hibernate aware...
e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
sold it all... :-(
Coming Soon - 2007 BMW 335i UMPC install
RiXst3r is offline   Reply With Quote
Old 05-31-2005, 02:17 PM   #32
unless you want to try to integrate i-bus support into RR...
here is the sourcecode to talk to the i-bus serial adapter...
http://sourceforge.net/project/showf...ease_id=292951
that would be sweet if RRConfig had options for i-bus to map the 6 steering wheel buttons to skin commands(which is what CdR made his ibus app do, it just runs seperate of RR)
sold it all... :-(
Old 05-31-2005, 04:12 PM   #33
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I'd rather talk to CDR and work with him to modify the code to try and improve it to be more HIBERNATE "aware".. this is the kind of thing I'd not want to add into RR because a very few select people would use it.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-03-2005, 07:19 PM   #34
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
I have been so busy the last few days.. got work tomorrow, but I still have the harddrive to swap out and search on.. I can stick the hibernation reconnect code in no prob's only take 5 mins.. the hardest thing is finding my source
CdR
CdRsKuLL is offline   Reply With Quote
Old 06-03-2005, 07:22 PM   #35
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
probably in the bottle marked 'HP'
Enforcer is online now   Reply With Quote
Old 06-03-2005, 10:06 PM   #36
BMVEE's Avatar
BMVEE is on a distinguished road
What does CdR stand for anyway...
_________________________
It's better to be ****ed off than ****ed on!
BMVEE is offline   Reply With Quote
Old 07-29-2005, 05:23 PM   #37
zaid175 is on a distinguished road
I bought an I-bus interface from Rolf in Germany as well. However this is what happened to me.
I got the interface and came to attach it to the cd changer cables, the interface has 3 pins, while the cd changer cable has 4 connectors, i didn't know which ones to connect to, yet i still connected it.
I then connected the serial cable. Closed the boot lining and kept on tuning my amps.
I didn't program the carputer for the i-bus was too lazy to do it and decided to work on it in a couple of days.
A couple of hours later my Air conditioner's compressor and half of them items on the instrument cluster stopped working. I check all the fuses non have blown. so the next day i drove down to the bmw service centre and the check the car on their diagnostics system, the K bus was ****ed up, i went there and removed the ibus interface and everything worked fine.
Can anyone give me a logical explanation for what had happened?
zaid175 is offline   Reply With Quote
Old 07-29-2005, 07:59 PM   #38
Confusion Master
Enforcer's Avatar
Old 11-08-2005, 09:43 AM   #39
drex is on a distinguished road
any update on solving the problem with hibernating and the Ibus serial connector on USB dongle?
thanks
drex is offline   Reply With Quote
Old 11-08-2005, 10:37 AM   #40
FreeDrive Creator
CdRsKuLL's Avatar
please search for a version 2.0 its fixed :-)
Old 11-08-2005, 02:05 PM   #41
thanks
i never hooked it again.
Old 01-10-2006, 08:50 AM   #42
Hark's Avatar
Hark is on a distinguished road
Does anything else need to be done other than using the above files? No modifications to the KeyTBL.ini or anything? I had the ibus working with Frodo, and now I'm using RR with the exact files above (changed the com port to the one I'm using), and button presses make the RR screen flash a little, but no action. I'm sure I have something wrong somewhere, but after a few days of looking at it I've not figured it out.
Hark is offline   Reply With Quote
Old 01-10-2006, 10:58 AM   #43
Jir1984 is on a distinguished road
hey guys are you using blitzsafe adaptors or some kinda aux adaptor to your cd changers..if so doesnt your aux adaptors plug into the ibus? if so which cord do you plug yours into...i have an aux adaptor that plugs into the sound but also plugs into the i bus cord...not sure if blitzsafe does but mine does. can anyone help me...im still tryin to figure out which i bus cord i plug into..i have 2 different sets of cords...cd changer ones...and then some other set which has a thicker connecter but also has a i bus cord.
Jir1984 is offline   Reply With Quote
Old 01-10-2006, 11:35 AM   #44
Mattkins99's Avatar
Mattkins99 is on a distinguished road
it's it's actually a solit state device made by a guy in Germany that hooks directly into the iBus. Most people hook it into the CD changer port... because it's no longer needed and already in the trunk, but you can also hook it into the center console port.
The ibus cord is actually a small flat three wire plug.
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
Old 01-10-2006, 01:26 PM   #45
hey thanks for the post....i already have the piece..just tryin to figure out which one to plug it in...so for example my cd changer cord has the audio and i bus plug into my aux adaptor for some reason...can i just plug the i bus controller into the other i bus cord in the back...because i am positive i have two...one goes with the cd changer cord..and the other is the pre wired phone control cord..please let me know
thanks
Jason
How-To: Relocating Screen Buttons Altimat Fabrication 41 11-07-2007 04:48 PM
Road Runner on Xp nlited no buttons working mick0uziel Road Runner 5 03-14-2005 01:54 PM
next to-do: chassis front pannel buttons, need your suggestions mpattonm Fabrication 7 02-05-2005 07:41 AM
Where To Buy Buttons, Switches, Lights? eCar™ General Hardware Discussion 7 02-22-2004 03:25 PM
