Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 01-10-2006, 06:40 PM   #46
Mattkins99's Avatar
Mattkins99 is on a distinguished road
if that's an ibus port... then yes. my car didn't have a phone in it, so I don't know if that's what it is (it would make sense there would be one back there for the brain though. You can try it, but I'd check the Yahoo group "Hacktheibus" or some E46 boards first just in case.
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
Old 01-11-2006, 11:34 AM   #47
Hark's Avatar
Hark is on a distinguished road
Quote: Originally Posted by Hark
Does anything else need to be done other than using the above files? No modifications to the KeyTBL.ini or anything? I had the ibus working with Frodo, and now I'm using RR with the exact files above (changed the com port to the one I'm using), and button presses make the RR screen flash a little, but no action. I'm sure I have something wrong somewhere, but after a few days of looking at it I've not figured it out.
bump - CDR, any ideas?
Hark is offline   Reply With Quote
Old 03-02-2006, 09:16 PM   #48
JohnMP3 is on a distinguished road
v 2.0 Source
CDR - Any chance you could post the source for the hibernation support? My com ports tend to be 10+ and that requires a slight tweak to the original ibuscomm code..
JohnMP3 is offline   Reply With Quote
Old 03-02-2006, 09:53 PM   #49
Also - still no luck resuming from hibernation with your v2.0 - it stops responding. Disabling the USB/Serial in system:hardware and enabling it makes XP search for drivers - I just want the system to resume out of hibernation! Looks like I may have to tap in elsewhere and leave the CD player intact so that I can avoid having to hit the CD/Tape button when I start my car.
Any help with this?
Old 03-06-2006, 03:21 PM   #50
DO NOT PLUG YOUR PHONE JACK INTO THE IBUS CARD. It will likely fry your card at worst. AT best, it will not work. The phone jack, while the same connector as the ibus is NOT an ibus signal carrier and will NOT work.
Old 05-13-2007, 06:32 AM   #51
vrslider's Avatar
vrslider is an unknown quantity at this point
can anybody please tell this newbie newbie ;-) which of the two cables in the trunk of the cdchanger contains the IBus connector? I have orderd the USB Ibus connector for the use with roadrunner.
I have a 2 connectors in the trunk, one with 3 white ones with stripes colors and one with also 3 wires wiht one brown red and white i took a picture see ( http://www.dreamonline.nl/images/ibus.jpg ) for the 2 cables..
All help is very welcome !
Raim
vrslider is offline   Reply With Quote
Old 06-19-2007, 09:13 PM   #52
phatbimmer is on a distinguished road
I need some help configuring the ibuscomm.ini to work with voice control in RR. I have set the hotkey to F10 in the voice.ini file and set the STW_RT_PRESS to KeyboardMap={F10} but i cannot get ibuscomm to successfully "press" the hotkey. When I press F10 on my keyboard it works fine, but the ibuscomm program cannot do it. Could it be maybe because the ibuscomm program is sending commands to RR and not to my voice program?
phatbimmer is offline   Reply With Quote
How-To: Relocating Screen Buttons Altimat Fabrication 41 11-07-2007 04:48 PM
Road Runner on Xp nlited no buttons working mick0uziel Road Runner 5 03-14-2005 01:54 PM
next to-do: chassis front pannel buttons, need your suggestions mpattonm Fabrication 7 02-05-2005 07:41 AM
Where To Buy Buttons, Switches, Lights? eCar™ General Hardware Discussion 7 02-22-2004 03:25 PM
