The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 03-26-2005, 02:43 AM   #1
Bullwinkle777's Avatar
Vehicle: 91 Honda Civic Si
My Photos: (0)
HELP!! RR can't find skin
I'm wanting to use RR but I keep getting
"E:\App\Road Runner\Binary\Skins\DEFAULT does not contain a valid skin! Check your settings and try again." I've check everything and I still can't get it to work.
Am I an idot and put the skin in the wrong place? Or am I just a moron? Because no one else seems to be having this problem.
Bullwinkle777 is offline   Reply With Quote
Sponsored Links
Old 03-26-2005, 02:47 AM   #2
Curly_cat's Avatar
Vehicle: Audi A4 2.4 V6 and 1972 MGB Roadster
My Photos: (0)
Run RRConfig and make sure the path is set correctly.
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
Curly_cat is offline   Reply With Quote
Old 03-26-2005, 02:53 AM   #3
Vehicle: Opel Astra
My Photos: (0)
Just remove the dir DEFAULT?
Or set the skin directory 1 level up (to ../skin instead of ../skin/default
As far as I know, RR looks in that dir, and directory-names are the skin names.
Otherwise you can edit/view rr.ini manually
*can't check it myself now, i'm at work, car is in parking space outside*
DJSmiley is offline   Reply With Quote
Old 03-26-2005, 02:58 AM   #4
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
check to see if you have a resume.ini file in your RR directory.. if its there delete it. Then try again
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 03-26-2005, 03:14 AM   #5
My Photos: (0)
Thanx to everyone with your speedy replys!!!! As soon As I posted the problem I went back and moved the folder and it works now!
Thanx everyone!!!!!!!!
Old 03-26-2005, 03:46 AM   #6
My Photos: (0)
O.K. now all of my sliders flicker. Why would this happen?
Old 03-27-2005, 12:59 AM   #7
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
You probably have sliders with the Y definition.. open your .skin files for the screen with sliders and simply comment out (add a '/,' in front of) the lines that start like:
YXX,....
This typically happens with older skins only.. it is faster anyway if you don't have that definition in there -- but this might remove the background effect on your sliders (if any is in place).
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 09:50 PM
v.3 SKIN WeeZyFellA FrodoPlayer 89 10-15-2004 08:29 PM
new skin idea, need help Electrohacker Media Engine 0 09-20-2004 11:56 PM
Brushed Metal skin v.1.9 febsperanza MediaCar 50 09-01-2004 04:45 PM
Laguna Skin CdRsKuLL MediaCar 65 06-20-2004 08:27 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
