Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-30-2005, 07:51 AM   #31
guino great work!!
Anyone have a screenshot of mappoint in RR??
camsgs3 is offline   Reply With Quote
Old 03-30-2005, 08:46 AM   #32
I have now updated the Install to include this latest version.
You can get it at: http://www.majesticpw.com/roadrunner/Index.html
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
bry21317 is offline   Reply With Quote
Old 03-30-2005, 08:47 AM   #33
Raw Wave
Guino,
The new sdk with labels is really useful, have just integrated my USB Media Transfer program to allow it to place labels on the screen ... anyway of bring custom icons or showing the certain parts of the _ON skin??
Any chance of doing the same but able to pull information back from RR?? i.e labels etc for Track Information, remaining track time etc .... would allow people to create 'plugins' for RR for LCD displays etc and pocketpc remotes ...
Gobby is offline   Reply With Quote
Old 03-30-2005, 10:19 AM   #34
Kato's Avatar
Hmm...with the ability to use the sendkeys functions, it should be too hard to use FMA ( folat's mobile agent ) for bluetooth phone app. It just needs a touchscreen friendly interface.
Kato is offline   Reply With Quote
Old 03-30-2005, 10:50 AM   #35
I only had about 5 minutes to mess with it this morning. I'm not sure how to create a route. I can add the destination but I can't figure out how to create the create the route.
Many of screens for this destination entry are messed up. Text boxes don't appear until I pass my mouse over the box location. I'll try to send screenshots this evening.
Other than that it's coming along nicely with MapPoint. I'll play with it tonight and write something more detailed.
Chuck
chuckster is offline   Reply With Quote
Old 03-30-2005, 10:52 AM   #36
drait's Avatar
You mean maybe floAt's Mobile Agent?
http://fma.sourceforge.net/index2.htm
89 Supra Turbo
drait is offline   Reply With Quote
Old 03-30-2005, 01:05 PM   #37
RoadRunner Mastermind
guino's Avatar
Quote: Originally Posted by badandy
1. first time in radio using the fx button to save preset works fine. but after, subsequent time in radio, pushing the f/x button will add the content of the music directory to the preset list rendering the preset list unusable.
Can you make me a log file ? I have tested it here and found no problem, please also tell me which Radio tuner you have and if you reset the radio card or not before using it.
Quote:
2. not sure if this is a mistake on my part but if i select do not use id3 tag in rrconfig, the tile of the artist doesn't show up only the title of the songs are display in music player and browser. same effect in video player/browser.
When you disable ID3 support it simply disables ID3 support altogether, meaning the TAGXXXX codes are useless.. When not using ID3 tags the "Playlist" label code will have the folder name of the songs you've selected (in most cases this is the artist name).
If the built-in player doesn't play a file, it's likely you need some sort of codec/filter to play that file.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 03-30-2005, 01:09 PM   #38
guino's Avatar
Quote: Originally Posted by Javiles
Hi guino, I a create a button for sendkeys , at the moment I press this button Would I lose the focus of the currente box of embbeded application???
No.. when sending keys, RR will get focus (when you press the button), but then immediately before sending the keys, RR returns focus to wherever you were in the application, and pulls back the focus to itself, in order to allow keyboard handling to work in the main application (RR).
Old 03-30-2005, 01:12 PM   #39
guino's Avatar
Quote: Originally Posted by UK_MP3Car
Guino,
I can easily allow for creating custom indicators.
Pull back info from RR is on my to-do list, but you'll most likely need to implement COM hooks in your side of the application like RR does.. I'll make sure to change the SDK example to include this when ready.. I just need to re-arrange the code that processes labels updates.
Old 03-30-2005, 01:16 PM   #40
guino's Avatar
Chuck
To Create a Route
With a GPS Lock:
1-Click Route Planning, Add, enter address, hit Search
2-Highlight location and hit select
3-exit the plannig screen, click "route" and "calculate"
Without GPS Lock the procedure is the same except you have to do 1 and 2 above TWICE so you have two addresses in there.
I have seen a few issues with the re-drawing of the gps_location screen, this seems caused by mappoint's "lag".. I'll add some prevention against that..
Old 03-30-2005, 02:07 PM   #41
Raw Wave
Excellent, thanks Guino - BIG Smiley face from me .... you will open RR wide open then to allow plugins etc.
Could you possibly provide a .bas file to add to a vb app to call the hooks etc? Or at least an example once its done ... appreciate your work.
Old 03-30-2005, 02:56 PM   #42
Clarre's Avatar
I've done a test I copied the maps from MS autoroute 2005 to Map Point because it's newer map for the euroupean maps what I know. And it works great. The Map Point is from 2004. I don't have the possibility to test in my car so far but I do it tomorrow.
BTW Great job Guino.
Via Epia M1000
512MB RAM
120MB IBM Hard drive
Netgear MA111
Lilliput 8" Touchscreen
http://www.clarre.com/carcomputer.htm
Clarre is offline   Reply With Quote
Old 03-30-2005, 03:03 PM   #43
Chita79's Avatar
i wonder when Map Point 2006 is coming out?
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
Old 03-30-2005, 04:16 PM   #44
vortex's Avatar
maybe in 2006
www.vortexleather.com
vortex is offline   Reply With Quote
Old 03-30-2005, 04:17 PM   #45
reduce sound volume
Guino great work!!
tell me - reduce sound volume in GPS working with external GPS aplication also? if not what can we do with this issue?
albert is offline   Reply With Quote
I-BUS sterring buttons now working for RR CdRsKuLL Road Runner 51 06-19-2007 08:13 PM
RR 03-06-05 - Radio Preview ... guino Road Runner 37 07-04-2005 01:58 PM
girder on RR mick0uziel Road Runner 4 03-29-2005 07:00 PM
GPS and MapPoint 2004 questions. wampa MediaCar 3 07-15-2004 05:40 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 12:07 AM
