The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 03-29-2005, 11:43 PM   #1
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
Arrow RR 3-30-05 ... Mappoint ...
I know it's been awhile since an update, Mappoint support required a lot of screens and functions to be added.. including direct GPS management directly built into RR... I consider this a BETA due to so many changes at once...
Here are the changes:
* Fixed OSK indicators bug (Shift/Caps)
* Fixed Launch List Font Color Bug
* Fixed Radiator 'Freq-' bug
* Fixed Update bug when using Browser out of audio player
* Fixed Shutdown Mute Bug
* Improved Freq+/- to support broken freqs
* Added Support to Reset PCI/USB TV Card
* Added Support to Reset PCI/USB Radio Card
* Added MapPoint Support at 90% (Major feature)
* Added Video Player Crash prevention
* Added Support to Rename Files using Folder Browser
* Added Support to Delete Files using Folder Browser
* Added support to change RR's skin labels through SDK
* Added Skin Commands: "PAUSE", "RESUME"
* Added Label Codes to Display GPS Info
* Added Option to Reload List after hibernate (HORM support)
* Added support to send keys to embbeded applications
Now the part even I hate.. the notes:
MAPPOINT support is still not finished, those are the features missing:
-Save Map/Route Info
-Import Map/Route Info
Those are the few I want to add extra:
-Allow for custom loading of Alert Distances/Messages
-Allow for Switching AutoZoom Mode ON/OFF while in RR
Furthermore, You need to make sure the MAPPOINTERS folder is in place (in RR's folder) before using it. This is shipped in the Binary Package. I also recommend the Brushmetal Update for improved Mappoint support.
On another notice, the built in GPS support works with the NMEA protocol ONLY. I don't know if I'll ever implement SIRF, seemed like a whole lot of trouble the last time I looked at it..
Extras already in place:
-Search Nearby Places (the ugly icon on the right of the Brushmetal Update I made)
-Search Results after places search -- including nearby places (the ugly icon on the left of the brushmetal update I made)
-Voice Over Turn-by-turn instructions (this may be buggy)
-Single Point Route Calculation. If you wish to route from the current GPS location to an addres you've entered, simply leave only ONE address in the route planning screen and RR will add the GPS location as start when you hit "calculate"
-Autozoom -- right now it has fixed speeds, but I intend to allow custom speeds
-If you have Mappoint and MM, you CAN actually use both simulteneously! RR will manage the serial port whe opening/closing MM and communicate with it when open in order to make mappoint work while MM is running. This is a completely optional feature and will only work if MM is set to use NMEA and it is embbeded natively (RR FAQs explain this).
SPEECH support has been improved to use SAPI5
If you do not have, or do not wish to use SAPI5, you can still use SAPI4 by adding this line to your RR.INI:
sapi5=false
Card Resets
To reset a PCI/USB Radio/TV card, check the reset option in RRConfig and select the device to be reset. This adds considerable time between switching into Radio/TV, so I'd suggest using it only when you absolutely have to. The time it takes is to: Close winamp (it may be using the card), Reset Card, Start Winamp.
Other Notes
Reload on Hibernate is done with this line in RR.INI:
hibernatereload=true
The Sendkey function works with the same VB sendkey strings -- I'll post those later, for now, feel free to ask me how to send specific keycodes.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Sponsored Links
Old 03-30-2005, 12:05 AM   #2
BeaverWise's Avatar
Vehicle: 1989 Camaro RS
My Photos: (0)
Good god Guino, you are a machine!!! I am constantly impressed with your work ethic! And on an open source project. Again, thank you, your efferts are greatly appriciated.
Everyone else - don't forget the donation thread
VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
BeaverWise is offline   Reply With Quote
Old 03-30-2005, 12:26 AM   #3
My Photos: (0)
edit: no love on the updated skin. file not found.
Woo hoo!!! you rock!!! gonna download it right now....
badandy is offline   Reply With Quote
Old 03-30-2005, 12:30 AM   #4
Mr.Fabio's CarPC Specs
Mr.Fabio's Avatar
Vehicle: Ford Focus C-MAX TDCI
My Photos: (5)
The link of the BrushedMetalUpdate is not operative....
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 03-30-2005, 12:37 AM   #5
guino's CarPC Specs
guino's Avatar
My Photos: (5)
try now.. sorry I am sure I uploaded it, and then tried it again now, I think I ran out of space on my main site.. I posted and redirected it onto the mirror.
Old 03-30-2005, 12:38 AM   #6
BMVEE's Avatar
Vehicle: '01 BMW 325CiC
My Photos: (0)
Getting a "Run-Time Error '424'" Object Required when I go into RRConfig
BMVEE is offline   Reply With Quote
Old 03-30-2005, 12:43 AM   #7
guino's CarPC Specs
guino's Avatar
My Photos: (5)
umm... sounds like some setting you have that is not in there anymore ... the easiest solution would be to delete your RR.INI and recreate it RRConfig (just run and set settings again).. you can most definitel make a backup of your INI in case it still doesn't work afterwards..
Let me know..
Old 03-30-2005, 12:47 AM   #8
Mr.Fabio's Avatar
My Photos: (5)
Ok, downloaded
Mr.Fabio
Travla C134
Old 03-30-2005, 12:48 AM   #9
BMVEE's Avatar
My Photos: (0)
Let me know..
That Did it... I'll have to re-config... small price to pay... Thanks Guino. I have worked out most of my troubles so far. I'll let you know if the radio/tv switching works for me...
Thanks Again!
Old 03-30-2005, 12:55 AM   #10
Raw Wave
Gobby's CarPC Specs
Vehicle: Pug 306 XSi
My Photos: (0)
Nice one Guino - even though the MapPoint is beta going to throw in the car for this weekends UK meet so I can test both MapPoint and MM.
Donation on its way later today.
Gobby is offline   Reply With Quote
Sponsored Links
Old 03-30-2005, 01:00 AM   #11
BMVEE's Avatar
My Photos: (0)
Let me know..
Ok... As soon as I select my GPS path or application, I get the runtime error. I have ensured my paths are correct.
That is to say... When I go to modify the GPS settings. I can specify the paths correctly, so long as I leave GPS mode at 'Menu'. I can save...everything works ok at that point. The moment I select either MapMonkey or External... BOOM
Old 03-30-2005, 01:04 AM   #12
guino's CarPC Specs
guino's Avatar
My Photos: (5)
ok... let me do a quick check..
EDIT: Sorry, overlooked something in the GPS settings.. re-download the binary package and it should work..
Old 03-30-2005, 01:15 AM   #13
BMVEE's Avatar
My Photos: (0)
That's got her!
Yok & Yoll baby, Yok & Yoll
Old 03-30-2005, 01:22 AM   #14
My Photos: (0)
ok just tested the radio/tv. the reseting part works great. noticed a few weird things.
1. first time in radio using the fx button to save preset works fine. but after, subsequent time in radio, pushing the f/x button will add the content of the music directory to the preset list rendering the preset list unusable.
2. not sure if this is a mistake on my part but if i select do not use id3 tag in rrconfig, the tile of the artist doesn't show up only the title of the songs are display in music player and browser. same effect in video player/browser.
update: **figured out the video problem. had to use external player.***
3. i have a few video that would play in rr but it would play fine in winamp. rr would see the file and allow you to select it but it would just skip to the next file.
good work.
Old 03-30-2005, 01:26 AM   #15
Raw Wave
Gobby's CarPC Specs
My Photos: (0)
How do we use the Labels SDK?
I can see the skin command but how is it 'sent' to RR?
Sponsored Links
vB code is On
Trackbacks are Off
I-BUS sterring buttons now working for RR CdRsKuLL Road Runner 51 06-19-2007 08:13 PM
RR 03-06-05 - Radio Preview ... guino Road Runner 37 07-04-2005 01:58 PM
girder on RR mick0uziel Road Runner 4 03-29-2005 07:00 PM
GPS and MapPoint 2004 questions. wampa MediaCar 3 07-15-2004 05:40 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 12:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
