04-14-2005, 02:38 PM
#151
RoadRunner Mastermind
Ok, I've added this "NoDesign" option into RRConfig... When I heard of it at first, I thought it would work on all versions.. I'm leaving it as an option for those who like to try before buying..
I've updated the source and binaries with the changes Hematec made and the nodesign option. It was my bad in not noticing all changes Hematec made to the source so this is the reason on the PreRelease not working right..
http://rmc.pimpedwheels.com/PhocoPreRelease.zip
http://rmc.pimpedwheels.com/RoadRunnerSource-Phoco.zip
[b]AGAIN: If you have tested any Phoco BETA Version:[b] The Address Book File had misspelled elements (Adress instead of Address) and I thought I'd correct it while not a wholoe lot of people use it.. so please remember to delete/fix your current file and also to update your settings in RRConfig (they've been moved over -- Phoco.ini is optional and only for language settings now)..
Let me know,
Guino.
Ride Runner RR's Myspace
04-14-2005, 04:08 PM
#152
Just tested the new preRelease. Now when a call is incoming RR goes in crash..
Here is the error; Translation : unable to find the path specified
I have deleted the previous address book and cheked the path, but i'm still having this error
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
04-14-2005, 04:14 PM
#153
Ditto. SE T610, PHOCO 1.4 registered. "cept mine is in english and i'm betting it says the same thing.
04-14-2005, 04:17 PM
#154
A minor problem : some fields labels in the new RRConfig appearing incomplete. Another Internationalization problem?
Mr.Fabio
Travla C134
04-14-2005, 04:21 PM
#155
I'll add a load of error preventions to the phoco code (right now has barely any).. then post it as a release (Phoco still will be beta) -- I need to get my hands on the T637 I'm getting to do any testing myself..
Meanwhile, if you can post the Phoco settings used and tell me if you heard the ringing sound or not, would help a little to diagnose the issue..
04-14-2005, 04:23 PM
#156
This is because of the resizing capabilities of the config now.. (i.e. you can embed it in the launch screen) depending on resolution settings, it's impossible to fit everything correctly.. I'm still trying to improve a bit on it..
04-14-2005, 04:28 PM
#157
Ok. I have listened the ringin sound.
these are my settings in phoco.ini :
unknown_caller=Sconosciuto
incoming_call=Chiamata da:
in_call=Chiamata:
outgoing_call=Chiamando:
intPhoneBook=Contatti Interni
phonePhoneBook=Contatti Telefono
simPhoneBook=Contatti Sim Card
allCalls=Tutte le Chiamate
inCalls=Chiamate Ricevute
outCalls=Chiamate Effettuate
missedCalls=Chiamate Perse
And in RR.ini
phocopath=C:\Programmi\PhoneControl\PhoneCtl.NET.e xe
addressfile=C:\RoadRunner-Phoco\
callsfile=C:\RoadRunner-Phoco\
ringtone=C:\WINDOWS\Media\ringin.wav
standardphonebook=0
maxcalllistentries=100
Mr.Fabio
Travla C134
04-14-2005, 04:51 PM
#158
Raw Wave
i assume u double checked that all these paths exist, yes? why a space in ".e xe"?
dunno what else it could be, just trying to help ya
04-14-2005, 04:54 PM
#159
Raw Wave
It isn't the hyphen is it in addressfile or callsfile is it? Or even the fact it points to a folder rather than a file? Just ideas.
04-14-2005, 04:58 PM
#160
I have rechecked RoyN. In my RR.ini is right writed : PhoneCtl.NET.exe.
Mr.Fabio
Travla C134
04-14-2005, 05:52 PM
#161
please check if the ringtonepath is correct!!!
i had the same problems when i forgot to set a correct path to a wave file.
as guino said, there are still some problems if a filepath is not given correctly...
i bet it's a wrong ringtonepath!!!
04-14-2005, 06:15 PM
#162
Oh boy... I think I forgot to add the filename to the setting on Callsfile and Addressfile.. try making it:
addressfile=C:\RoadRunner-Phoco\address.xml
callsfile=C:\RoadRunner-Phoco\calls.xml
and see if it works..
04-14-2005, 06:24 PM
#163
I'm now entering the phoco arena!!!
I bought a PhoCO license this night.
I have no problems with my phone (t610).
The only thing I sincerely don't understand is if RR can show and manage the contact of the phone as Phone Control make without importing importing, esporting or other conversion but only connecting the devices.
04-14-2005, 06:29 PM
#164
From what I understand, there's no phoco interface (yet) to manage the contacts from the phone/sim cards.. it lets you load them and that's it (I think)... this would also be something that many phones woudnt support -- thus the idea behind the internal phonebook in RR. I also appreciate this function for the times my phone will go dead dry and I need to know a phone number to call somebody..
04-14-2005, 06:31 PM
#165
you could use the calllist of your phone by leaving the entry for the callsfile empty...but i've only tested this with my phone (t630)...
if id doesn't work, please use my tool i posted above to get the names of your phonebooks and send the names to me, i'll then try to add the entries.
| Thread Tools |
| Display Modes |
Linear Mode
