Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-11-2005, 05:58 PM   #31
hematec is on a distinguished road
hi @all
please tell me what exactly is not working ...
hematec is offline   Reply With Quote
Old 04-11-2005, 06:24 PM   #32
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Hi Hematec, Have you tested this version I put out ? It seems to me that for some reason no incomming data from Phoco is working/comming into RR. So it lets people send commands out but nothing comes in... I have taken a look at the code but without the hardware I coudn't find anything wrong with it... The skins do seem to be in order..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 04-11-2005, 06:25 PM   #33
Partybuster's Avatar
Partybuster is on a distinguished road
well, when I go to misc - phone , RR starts phonecontrol up, so that works.
but the connection with the phone isn't OK. I can dial a number but the rest doesn't work at all. No phone status, no phonebook reading, no saving of changes, reload button doesn't work, etc.
the file AdressBook.xml isn't created, do I need to make one because I can't find one anywhere.
Partybuster is offline   Reply With Quote
Old 04-11-2005, 06:27 PM   #34
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Quote: Originally Posted by mauri
Who of you that it tries the tests of Phoco, please face a list of the compatible jail cell, I beg me
Mauri
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 04-11-2005, 07:58 PM   #35
contaygious's Avatar
contaygious is on a distinguished road
yo am I doing something wrong it won't load up phoco for me.
what am i supposed to do with the phoco.ini it looks fine to me.
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
contaygious is offline   Reply With Quote
Old 04-11-2005, 08:05 PM   #36
dmurray14 is on a distinguished road
I'd be willing to test. I have a T637 and everything that PhoCo can do works with my phone.
Dan
dmurray14 is offline   Reply With Quote
Old 04-11-2005, 08:12 PM   #37
@contaygious
you need to have the right path for phonecontrol in your ini file. Mine is for example:
C:\Program Files\PhoneControl.NET\
the AdressBook.xml should be created by RR I guess, but it doesn't happen.
awaiting more info from guino and hematec to continue testing
Old 04-11-2005, 08:17 PM   #38
thanks, but mine looks like this and doesn't load phoco
phocopath=C:\Program Files\PhoneControl.NET\
Old 04-11-2005, 08:23 PM   #39
check your configuration file for phonecontrol and see if remote control is active (server)
<RemoteControl>
<Mode>Server</Mode>
<IPPort>17015</IPPort>
</RemoteControl>
Old 04-11-2005, 08:25 PM   #40
yup that's how mine looks too:
<RemoteControl>
<Mode>Server</Mode>
</RemoteControl>
Old 04-11-2005, 08:27 PM   #41
hmm, weird, phonecontrol launches on my pc because I see it's window on the taskbar. I can't open it but that's because RR is controlling it. Try do dial to any number to see if that works (that's the only thing I can do)
Old 04-11-2005, 08:29 PM   #42
nope doesn't work either :?
i have the trial version does that matter?
Old 04-11-2005, 08:32 PM   #43
hi,
my mistake. please comment out the line in frmCOM
which is:
'Call ParseXML(left(m_sRecvBuffer_PHOCO, Len(m_sRecvBuffer_PHOCO) - 1))
this sends the xml messages to RR
also please change:
winsPhoCo.GetData l_sTmp
to:
call winsPhoCo.GetData l_sTmp
also i updated the modPhoco.bas and changed the startup and closing of phoco.
its no difference if phoco is running or not, but it will be closed when you close roadrunner. you can now also tell RR if you wish to save your call list and how many entries you want maximal at your list of every type (default 25).
please check before you use phoco with RR that it works correct when you start it manualy. in the config-file of phoco the remote-port has to be set to 17015 (is the default value)
Old 04-11-2005, 08:39 PM   #44
i forgot that you now had to write the complete path to the phoco.exe in the phoco.ini not only the path!!!!!
but this only if you use the new version of the modPhoco.bas
Old 04-11-2005, 08:51 PM   #45
did those changes, still doesn't load for me.
phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Beta testers: AiPC2 Seraph Software & Software Development 35 01-22-2004 01:58 PM
X-MP3Pad is out! I need beta testers! PorscheMP3 Software & Software Development 1 07-15-2002 03:33 PM
Wanted: beta testerss for X-MP3Pad (formerly MP944) PorscheMP3 Software & Software Development 0 05-07-2002 12:58 PM
