Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-11-2005, 08:55 PM   #46
Partybuster's Avatar
Partybuster is on a distinguished road
shouldn't that be program files instead of programme ?
I think hematec is using german windows, hehe.
phonecontrol is launched here again (only path without the exe in ini file), but now nothing works. I have done all the changes.
Partybuster is offline   Reply With Quote
Old 04-11-2005, 09:04 PM   #47
contaygious's Avatar
contaygious is on a distinguished road
yeah well mine is phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
and even when i have phoco open myself the two don't seem to interact at all...
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
contaygious is offline   Reply With Quote
Old 04-11-2005, 09:06 PM   #48
It's getting late (03:06 AM) and my eyes are closing so I'm going to sleep. I will continue testing tomorrow.
Old 04-11-2005, 09:16 PM   #49
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
The changes made by hematec will only work after re-compiling the sources.. I'm updating this right now.. and I'll re-post it in a little bit..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 04-11-2005, 09:17 PM   #50
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
do the changes effect any of the possible problems i mentioned?
phonebook, incoming calls, etc.?
ATXaccord05 is offline   Reply With Quote
Old 04-11-2005, 09:18 PM   #51
hematec is on a distinguished road
that are the sourcefiles....you have to add them to the vb-project!!! to get an .exe file you have to compile them.
what version of phoco do you use???
to check if the winsock connection works, start phoco manually, then open hyperterminal, name a connection, set type/used modem to tcp and type for the host 127.0.0.1 and port 17015. if you connect, you should see the first messages from phoco...
hematec is offline   Reply With Quote
Old 04-11-2005, 09:21 PM   #52
yes they do! because RR got no data from phoco, Phoco could not interact with RR and so RR got not phonebookentries, message about incoming calls, and so on...
Old 04-11-2005, 09:26 PM   #53
guino's Avatar
Ok, I've updated the main download file as well as re-compiled it for those without VB:
http://rmc.pimpedwheels.com/PhocoBeta4.zip (just unzip over your current files AND ADJUST YOUR SETTINGS IN PHOCO.INI)
This makes a lot of sense since everyone coundn't get any incomming information from Phoco.. this version should provide for it to work.. Thanks Hematec.
Old 04-11-2005, 09:27 PM   #54
im confused i'll just wait a while to try again. i have phoco 1.4 trial version, i'm not sure what hyperterminal is but phoco works fine by itself, just doesn't interact with RR-this is with the update you just posted...
Old 04-11-2005, 09:31 PM   #55
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
get the latest version contaygious.... post #53... read #52 for explanation...
no need to wait a while it is working now apparently
RoyN is offline   Reply With Quote
Old 04-11-2005, 09:34 PM   #56
guino's Avatar
yeah, you just need to unzip that Beta2 update over your current setup, make sure the settings in Phoco.ini are set (the package has new settings) and try again..
Old 04-11-2005, 09:34 PM   #57
ha still confused. won't open phoco, does anyone else have it working with the trial? do i need full version?
Old 04-11-2005, 09:36 PM   #58
with the trial you'll get a problem at all...because the trialversion show a info screen on startup...on solution should be to start phoco before running RR...
Old 04-11-2005, 09:37 PM   #59
Raw Wave
RoyN's Avatar
also edit the phoco.ini to contain the PhoneCtl.Exe filename in the end... the zip file's phoco.ini doesnt have the exe name!
Old 04-11-2005, 09:38 PM   #60
Master !
It's working here and I just lost the need to sleep, hehe. I can call and receive calls.
One minor thing: simcard contact and internal contacts work, but I can't read the internal phonebook from the phone.
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Beta testers: AiPC2 Seraph Software & Software Development 35 01-22-2004 01:58 PM
X-MP3Pad is out! I need beta testers! PorscheMP3 Software & Software Development 1 07-15-2002 03:33 PM
Wanted: beta testerss for X-MP3Pad (formerly MP944) PorscheMP3 Software & Software Development 0 05-07-2002 12:58 PM
