04-12-2005, 05:21 PM
#91
well this could not work....change the "ACCEPT_CALL_PHOCO" to "DIAL_PHOCO"...
thats it!!
#92
OK, I fixed it (don't know exactly how) and all is working again. I started phoco manually and after that RR. Then I closed both and run RR again and phonecontrol opened like it's supposed to do.
you can put the link back guino.
04-12-2005, 05:25 PM
#93
thats it!!
Ok hematec, now working correctly! Thanx
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
#94
@guino could it be, that the sourcefiles and the exe-file are not the same source???
in the source the lines in the sub checkafter are missing, but the exe works fine...??
04-12-2005, 07:26 PM
#95
Raw Wave
@guino & @hematec:
Are you using the info that Zorro sent out about starting phoco?
I'm having trouble... I restart my computer, load RR+Phoco, my phone isnt detected, I can go into phone it is as if there is no phone connected... if I receve a call RR/Phoco dont notify me...
I can then quit RR/PhoCo and load PhoCo on its own, then it works, and I can go into RR and it will work.. it seems that when RR starts phoco it isnt forcing phoco to look for the phone and reset it and everything...
Z sent me this saying to use this to start phoco hidden for max speed, I'm not sure if there is something here that you guys missed out, or if we are all at a loss...
Code:
Public Sub StartPhoCo(ByVal pi_sAppPathExe As String)
Dim l_sPath As String
Dim l_lHandle as long
' extract the path
l_sAppPath = Left(pi_sAppPathExe, InStrRev(pi_sAppPathExe, "\"))
' start it
l_lHandle = ShellExecute(0, "open", pi_sAppPathExe, "-remoteNoDesign", l_sAppPath, 0)
If l_lHandle < 32 Then
' signal user that PhoCo can't be started (see ShellExecute for the "why")
End If
End Sub
This starts PhoCo without using any Design file, so the startup is pretty much faster.
04-12-2005, 08:41 PM
#96
RoadRunner Mastermind
@Hematec
I may have not updated the package correctly.. I'll review the code to add that "ACCEPT_CALL_PHOCO" (as well as "DIAL_PHOCO") and repost the beta4, with a fresh source package..
@RoyN
cool.. I'll add that...
Ride Runner RR's Myspace
04-12-2005, 08:54 PM
#97
Ok, Just updated the Beta4 Update:
http://rmc.pimpedwheels.com/PhocoBeta4.zip
also updated the sources:
http://rmc.pimpedwheels.com/RoadRunnerSource-Phoco.zip
This should fix the Answer call bug ("ACCEPT_CALL_PHOCO" command is now added -- but "DIAL_PHOCO" can also answer calls). Also added the -remoteNoDesign to load phoco faster..
Is there anybody still having Phonebook issues ?? and if so, did you try that test app Hematec made to show the phonebooks available from your phone ?
Thanks for the help with this guys...
Guino.
04-13-2005, 01:33 AM
#98
I downloaded the newest files and I just configured the new WIDCOMM drivers so that I can accept calls and hear them over my speakers, as well as talk from a mic. whenever I recieve an incoming call RR will lower it's volume, but I don't get a screen that gives me an option to answer/ignore/etc. I was able to see this screen when I was using the windows drivers, but not with the WIDCOMM drivers. I beleive the problem also arose when I got the newest version of the program. phoco would open, but not be visible, and it is now. any ideas?
04-13-2005, 01:54 AM
#99
try to start Phoco BEFORE RR runs to see what happens.. also, check if you get a call notification in Phoco alone.. I'm waiting on my phone to be able to do any tests myself...
04-13-2005, 02:48 AM
#100
@ATXAccord
is the volume lowering or muting when you get a call???
could you dial out of RR? Is there a skin file named call_in.skin??
04-13-2005, 03:56 AM
#101
i downloaded the update. the accept, ignore, cancel all works. i get all my contacts show up. the calls list, all calls, missed calls, etc. don't work from the phone, it only remembers the list from what you do on the computer.
04-13-2005, 04:05 AM
#102
are you able to pull those from Phoco (outside RR) ? I'm assuming you have pressed any "reload" buttons available in the skin..
04-13-2005, 04:09 AM
#103
trying out the edit features, i cannot edit any of the contacts on the phone not even the delete, if i edit it saves it on the internal phonebook. if after using the program you go to delete any contacts from the internal phonebook it crashes the program.
04-13-2005, 04:11 AM
#104
yes in phoneco it all works i can see all the phonebooks from the phone and the call lists
04-13-2005, 04:51 AM
#105
i will change this thing with the calls...
editing the phone and sim phonebooks is still not supported by the phoco sdk...
when its available i'll change this of course...
| Thread Tools |
| Display Modes |
Linear Mode
