Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-13-2005, 04:56 AM   #106
hematec is on a distinguished road
could you describe it a little bit more exact what you did to crash RR??
You edit a contact, save this and when you gonna delete it RR crashes??
hematec is offline   Reply With Quote
Old 04-13-2005, 05:06 AM   #107
SubaruWRX is on a distinguished road
sorry my mistake
SubaruWRX is offline   Reply With Quote
Old 04-13-2005, 08:49 AM   #108
i changed some code to load the calls from the phone...but i could only test it with my phone...
i think guino will release a new beta with this
Old 04-13-2005, 09:35 AM   #109
Mr.Fabio's Avatar
Mr.Fabio is on a distinguished road
With the last beta released by guino, when a call is incoming, i can see for a while the photo associated to the contact, then the skin of rr goes on the top. The same sensation i have when RR is finishing to load, seems to view Phoco that goes to full screen for a while and minimized
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 04-13-2005, 03:56 PM   #110
Mr.Fabio's Avatar
Sometimes appear the skin of Phoco mixed with the mmi skin of RR.
I'm the only one with these problems?
Mr.Fabio
Travla C134
Old 04-13-2005, 03:58 PM   #111
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
With all the versions I tested, the music stops playing when a call comes in BEOFRE I EVEN ANSWER... so I get no music until I ignore the call....
Also, call comes in, volume goes to 100% for a split second then mutes.... I speak, then hangup, music comes back at 100% then goes to the normal level...
Is this phoco or RR? What audio line should I be using in RRConfig? What is the best to use, I never figured out the difference
RoyN is offline   Reply With Quote
Old 04-13-2005, 03:59 PM   #112
Raw Wave
RoyN's Avatar
Mr. Fabio, that is when u start phoco manually, no? when RR starts phoco in remote mode, the skin will never show (phoco skin) as it wont even be loaded
Old 04-13-2005, 04:07 PM   #113
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by hematec
i will change this thing with the calls...
editing the phone and sim phonebooks is still not supported by the phoco sdk...
when its available i'll change this of course...
Can you change the internal address book to match the format used by Zorro?
I have two Phone Control Phone books I use with my PCMCIA CDMA phone card. And its would be a royal pain to convert it over to the RR "addressbook" file manually. Also if there are any other PhoneControl users with internal phonebooks this would help them too by letting them just point RR to their phonebook and it works.
Just trying to maintain compatibility.
GizmoQ is offline   Reply With Quote
Old 04-13-2005, 04:08 PM   #114
Mr.Fabio's Avatar
No RoyN I load only RR, and after some seconds , when Phoco is too loaded, RR starts. Until the previous beta release I didn't have these problems
Mr.Fabio
Travla C134
Old 04-13-2005, 04:32 PM   #115
contaygious's Avatar
contaygious is on a distinguished road
everything works great for me in RR, just trying to figure out why my audio gateway connection won't let me hear the other person through my speakers with my t610, maybe my s710a will be better...any ideas?
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
contaygious is offline   Reply With Quote
Old 04-13-2005, 04:37 PM   #116
Raw Wave
RoyN's Avatar
mine works with the t610... go to the phoco forum and search, i explained my procedure
Old 04-13-2005, 05:34 PM   #117
GizmoQ's Avatar
A little clarification. The following is my address book:
And this is part of my Phone Control phone book:
The differences are minor, but significant. The names of the categories are somewhat different, but more importantly RR address book uses on entry per name, whereas, PhoCo phone book uses one entry per number and as long as the names exactly match, it pulls all entries for that name together when its loaded. I'm assuming Zorro did this for compatibility with the various skin formats used with his program. Pages 19-21 of the Phone control docs talks about these phone book locations and specifically addresses static phone books thus:
I realize the RR PhoCo is still beta and I don't know what criteria Zorro uses when identifying front-end with internal PhoCo support, but two of the other frontends I've tried that support PhoCo also support my static phonebook without changing anything just pointint it to the file.
Great work so far! I really love whats being done with Road Runner.
Old 04-13-2005, 06:49 PM   #118
so would you like to have one entry for every number in your phonebook in your list off the internal phonebook off RR???
if you load phoco you'll still have one name entry with several numbers...
the phonebook of phoco is used in RR in the phone phonebook until you press "reload"...
or to you mean that there may be problems when you have double entries per a name??? f.e. you have 2 entries maybe name: "xyz" and once with numberwork "123" and a second with numberwork "678" ????
Old 04-13-2005, 07:28 PM   #119
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
@GizmoQ:
I don't understand the whole idea behind "converting" addressbook files into RR's format.. RR should be able to load the phonebooks from the phone and no conversion would be necessary then..
From what I see the Phonebook Hematec implemented is superior in details than the one from Phoco.. If you have any issue with loading the phonebook from the phone into RR, then we need to fix that ..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 04-13-2005, 07:35 PM   #120
Raw Wave
RoyN's Avatar
Guino, some phones dont support importing the pb, and some people want an option of having an extra pb (like from outlook) and that is what he is reffering to i think...
He wants to use the phonebook that he currently has from phoco in RR's phone
Looking for beta testers for new DC-DC PSU MikeH Power Supplies 22 05-18-2004 03:22 PM
Beta testers: AiPC2 Seraph Software & Software Development 35 01-22-2004 01:58 PM
X-MP3Pad is out! I need beta testers! PorscheMP3 Software & Software Development 1 07-15-2002 03:33 PM
Wanted: beta testerss for X-MP3Pad (formerly MP944) PorscheMP3 Software & Software Development 0 05-07-2002 12:58 PM
