Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-16-2005, 09:21 AM   #1
DjBac's Avatar
DjBac is on a distinguished road
Base Plugin Questions
Will there be a FAQ for the Base Plugin?
How can we use it in order to skin our own applications?
I have made an app for HVAC and some more stuff... It can communicate with RR and MM fine!! But my only problem right now is skinning!
DjBac is offline   Reply With Quote
Old 04-16-2005, 10:03 AM   #2
Raw Wave
Gobby is on a distinguished road
Use the Base Skinnable App to skin your own programs using the same skin format as RR. Open the Visual Basic App in Visual Basic - all the code is commented so no FAQ required really.
Gobby is offline   Reply With Quote
Old 04-16-2005, 10:10 AM   #3
DjBac's Avatar
I've already whecked the code.. The problem is that I am not too keen in VB!! I had to learn some in order to write my app!!
Any more help would be really appreciated, although I will check it more carefully!!
Old 04-16-2005, 11:47 AM   #4
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
There really isn't much you need to do with the base plugin:
-Design your skin
-Define your buttons/labels in a .skin file
-Open the Base PLugin
-Name your project in frmCOM (as the Comments tells you to)
-Add any button codes from your skin/software in the select statement of the EXEC function
-Add any label codes from your skin/software in the select statement of the LabelInfo function
That's about it for a simple application... And to be clear, the plugin you make can be used in RR or stand alone..
Ride Runner RR's Myspace
guino is online now   Reply With Quote
Old 04-16-2005, 01:04 PM   #5
DjBac's Avatar
I think I am getting somewhere now!
But I am having a problem to add button codes from my soft!! How should I do that!
Old 04-17-2005, 05:35 PM   #6
DjBac's Avatar
Some more help please??
Old 04-17-2005, 05:35 PM   #7
Raw Wave
What help?
Old 04-17-2005, 06:55 PM   #8
DjBac's Avatar
Some help on this?
How should I define my buttons codes?
Old 04-17-2005, 07:45 PM   #9
guino's Avatar
Man, sorry, but did you even look ?
Please don't make any software available, without looking over at least the modules of the software..
This is what you find in the 'Exec' function:
'* Commands NOT used for navigation *
Case "mycommand1"
'Add here any custom commands..
Case "mycommand2"
Label codes are defined in the 'labelinfo' function somewhat like the buttons..
Old 04-21-2005, 08:11 PM   #10
DjBac's Avatar
I tried to have indicators (both RR and for my app)...
I've copied pasted some code from RR source code to the base plugin.. (GetIndicator function).... But NO luck!!
Should there be another way?
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Help with winXP/hibernate/LCD plugin dave123456 Software & Software Development 0 10-17-2002 09:17 PM
winamp audio level plugin darkwingduck Software & Software Development 1 07-27-2002 09:37 AM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
