Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-25-2005, 04:04 PM   #1
mauri's Avatar
mauri is on a distinguished road
Update my first hardware (Serial Voltmeter).Add two new functions
Four functions with a one hardware:
Serial Voltmeter (see my old thread )http://www.mp3car.com/vbulletin/road-runner/44181-line-download-my-hardware-rr-serial-voltmeter-implemented-guino.html
Timer for power GPS when the PC and out
Automatic switch VGA-AV and AV-VGA with input from the lamp reverse of the car(only for Lilliput) connect in parallel to the switch original for rear cam use
Automatic fixed lighting of the blue leds of the keys when the lights of the car(only for Lilliput) connect to the pin 8 and 12 of the Lilliput
In the future I put in download the material for to build "home made" this hardware
In enclosure the photo of the new hardware
Mauri
01/05/05
UPDATE PHOTO NEW VERSION OF THE HARDWARE
Edit: ALL the Input -Output in the new board is optoisolated.
For all guys:
If you have the Lilliput monitor (7" TS) I ask you to make a test:
Turn on the PC and also the Lilliput, tries to push the button AV to manually go to AV1 (the PC has to be in initial phase of boot) and tell me if Suffered the Lilli, only in this condition (first 5/8 second max of operation) succeeds in commuting from VGA in AV1 or no.
Do you him to know in this thread.
mauri is offline   Reply With Quote
Old 04-25-2005, 04:09 PM   #2
Raw Wave
rando's Avatar
rando is on a distinguished road
I assume the AV/VGA Lilliput switching can get out of sync if you swap the modes externally via the button and/or remote, right?
2004 4runner
rando is offline   Reply With Quote
Old 04-25-2005, 04:13 PM   #3
mauri's Avatar
The Pic simulates the input on the original button of switch of the lilliput VGA-AV.
Mauri
Old 04-25-2005, 04:14 PM   #4
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
I am sorry but I didn't get it. Will this device switch the VGA to AV1 and 2 on a lilliput automatically hen the reverse light is on and then back to VGA when it is off?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 04-25-2005, 04:18 PM   #5
mauri's Avatar
YES!
default VGA
turn the revers light
switch VGA-AV1
off revers ligth
switch AV2-VGA
Mauri
Old 04-25-2005, 04:28 PM   #6
Zebelkhan's Avatar
Cool...I am off reading your original thread. Hope you have info on how to build or buy over there....
Old 04-25-2005, 04:34 PM   #7
mauri's Avatar
I have built" home made" ALL....
The old version is in download in my web space (see the link) by now for a while, full version, and compatible to 100% with RR (thanks Guino)
Also the new version and perfectly already it works (tested).
I use this rear Cam,waterprof, in enclosure the photo
Mauri
Old 04-25-2005, 04:46 PM   #8
Zebelkhan's Avatar
I read the other threads and downloaded the project. Unfortunately it is way over my head. Will you build and and sell one to me? I only need it to switch the lilliput. Thanks.
Old 04-25-2005, 04:51 PM   #9
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
are you selling these built. I may be interested
antimatter is offline   Reply With Quote
Old 04-25-2005, 04:54 PM   #10
mauri's Avatar
NO,I don't sell this.
My idea and for everybody, free, to build him "Home made"
Mauri
Old 04-25-2005, 05:07 PM   #11
Zebelkhan's Avatar
Mauri
Unfortunately I don't have a way to program a PIC so I guess I can't have this. Thanks anyway...
Old 04-25-2005, 05:28 PM   #12
mauri's Avatar
In the web is possible download many simple hardware to burning the PIC device.....And sw free (type IC-PROG)
Mauri
Old 04-25-2005, 05:55 PM   #13
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
I have a similar camera, the same actually, but with IR... I really like it in case you guys are looking for one! I wrote a review on here just search for "REVIEW" and my username...
</hijack>
RoyN is offline   Reply With Quote
Old 04-25-2005, 05:56 PM   #14
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Mauri is possible to implement this on xenarcs someday??? or is to hard to go from lilli to xenarc confi...??
thanatos106 is offline   Reply With Quote
Old 04-25-2005, 06:03 PM   #15
mauri's Avatar
I have made the tests with the Lilli....
But the Xenarc if I am not wrong it already has the automatic functions to switch VGA - AV..
However if the Xenarc has the button for the manual switch VGA-AV in theory it works equally my hardware.
EDIT:If you connect my hardware to the Lilli, ALL the original /manual functions(timer -led and manual switch VGA-AV) work correctly!
Mauri
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
On-line for download my hardware for RR (Serial Voltmeter) implemented by Guino mauri Road Runner 22 03-04-2006 09:35 PM
serial ata hardware consumption kilomo General Hardware Discussion 1 03-15-2005 02:53 PM
USB Serial Port Adapter Troubles bLindmOnkey General MP3Car Discussion 0 10-14-2004 12:29 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
