The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 04-26-2005, 03:32 PM   #1
DjBac's Avatar
Vehicle: BMW Z4 3.0i SMG
My Photos: (0)
Application Embedding
I tried to make a button on the menu.skin embed an application but only half the times it would work properly.. Sometimes RR minimizes!! It is like something happening with the timers maybe?
I finally enabled embed support in base plugin but still the same thing!
DjBac is offline   Reply With Quote
Sponsored Links
Old 04-26-2005, 06:29 PM   #2
mbkowns's Avatar
Vehicle: 2005 Ford Mustang GT
My Photos: (0)
I am also trying to embed something in it. I want to embed IM clients such as aim. I have it mostly working but I get that same problem as you were it minimizes.
can anyone help us out?
thanks
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 04-26-2005, 08:34 PM   #3
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
please post the button commands you're using. Then I can try to help.
@DJBac
If you're tryihng to embed your plugin, you MUST use the PLUGIN Command and NOT the load OR run commands.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 04-26-2005, 08:50 PM   #4
DjBac's Avatar
My Photos: (0)
I am trying to embed an application in RR.. I also tried to embed the same app in my plugin!!
Here is the button command
B01,142,258,066,084,"LOAD;ACCEL.SKIN;accelarometer ;D:\Base Plugin\accelerometer.exe;accelerometer"
I have set in the accel.skin where it should embed... It embeds fine but not always!
Old 04-26-2005, 09:01 PM   #5
guino's CarPC Specs
guino's Avatar
My Photos: (5)
what happens when it doesn't embed ? does this application, by any chance, change the window title depending on what you open/run ? I can only assume it's something with the window title you're using..
Also, I see you're running this "application" from your base plugin folder -- if this is a plugin, you MUST use the "PLUGIN" Command (as I said before).
Old 04-26-2005, 09:09 PM   #6
DjBac's Avatar
My Photos: (0)
The application I am trying to embed in the plugin is not another plugin.. It is just a VB app that doesn't change window title!!
it seems to embed but RR (or plugin) minimizes.. If I close the embeded app and then try to open it (more than 20 times) it embeds fine!! Only the first time is the difficult one!
Old 04-26-2005, 09:42 PM   #7
guino's CarPC Specs
guino's Avatar
My Photos: (5)
you need to make sure you don't have any other application with the title "accelerometer" (or similar) running or RR may be trying to embed the wrong window.. you can probably try changing the applications title to something more specific..
Old 04-27-2005, 02:35 AM   #8
DjBac's Avatar
My Photos: (0)
Tried to change it to G Meter.. Exactly the same reaction..
When I try to put something different as app title it won't embed it at all..
I cannot figure out anything else!
Should I put something else apart from the embed space in the accel.skin?
Old 04-27-2005, 02:52 AM   #9
guino's CarPC Specs
guino's Avatar
My Photos: (5)
if you can send or post me the application i can tell you exactly what to use for window title OR you can look at the FAQ on embedding applications, using the WinSpectosSPY application.
Old 04-27-2005, 03:20 AM   #10
DjBac's Avatar
My Photos: (0)
I've tried winspectosSpy app and read the FAQ!!
The app is attached!! It is just a temp one!
Sponsored Links
Old 05-13-2005, 10:05 AM   #11
Bradipo's Avatar
My Photos: (0)
It doesn't embed SereneScreen Aquarium 2 screensaver, it only open the setting window (the window name is the same: Class Name "Aquarium_Window", Text "Marine Aquarium 2") ...
Bradipo is offline   Reply With Quote
Old 05-13-2005, 01:06 PM   #12
guino's CarPC Specs
guino's Avatar
My Photos: (5)
Screen savers typically use the entire window.. if it starts maximized the embedding may not work.. if you've tried: "!Aquarium_Window!Marine Aquirium 2" and it didn't work, then it probably won't embed in any application .
Sponsored Links
vB code is On
Trackbacks are Off
Neocar External Application Bug Fix! reddeath30 NeoCar Media Center 10 04-07-2005 08:25 AM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 02:17 PM
How to embbed any Application in RR ? guino RR FAQ 0 03-20-2005 12:35 PM
embedded GPS application problem Bokky Centrafuse 4 01-23-2005 12:44 PM
Embedding a backup application l0gic MediaCar 2 10-22-2004 04:55 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
