you probably have MM muting the MASTER VOLUME -- you don't want to do that.. you need to make it set the WINAMP volume ONLY.. and as DjBac mentioned, there's a TimeOut option to prevent muting/reducing volume for a number of seconds after a direction has been said -- I recommend turning that off too.
BTW, this is something that should be happening with ANY frontend and MM -- and probably MM alone too.
Ride Runner RR's Myspace
