Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-05-2005, 11:29 PM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow RR 06-06-05 .. Winamp Library Support ...
Ok, here's what I came up with for this version:
-Added Support for Winamp Library Database (Albums/Artists/Genres Lists)
-Added Option to remove ".." from folder lists
-Added MM Direction Indicator Support (Thanks 307SW_NLD) (Untested)
-Added XM Channel change (preset) skin/sdk command
-Added Option to disable hibernate handling (for those with freeze issues)
-Added Support For PhoCo Mixer preset (untested)
-Added Support for Muting/Unmuting audio lines in the mixer
-Added Support to toggle Repeat/Shuffle by clicking on indicators
-Added Support for Alpine Skin's Search Screens
-Added Support for polling XM Channel Info on labels
-Improved HideMouse function to "blank" the System Cursor
-Modified XM Satellite Signal information to reflect Quality
-Modified PostalCode input to use the normal OSK Mappoint
-Fixed sound issues with Direct XM<->Radio Switching
-Updated RRConfig Tool
-Updated Brush Metal/Aluminum skin files
Notes:
-Database Support (Winamp Library) is totally optional, I use file names only (because it's a lot easier to organize + it is a lot faster).
* You can simply hit browse in the artist/album etc to browse through your DB. Hit back to start over. You can search the whole DB by hitting the search button on the DB titles or search from the current selection you made so far. You should set your watch folders/scanning settings on Winamp to your liking.
-Haven't tested the MM Direction indicators (307SW_NLD can probably fill you in with this)
-To Disable Hibernate Handling add: HibernateAware=False to RR.INI
-Haven't tested the Phoco mixer stuff, but should work since I used standard/pre-tested functions to do it. You should most likely DISABLE the volume controls in PHOCO itself.
-Tweaked the Skin files a bit, mostly text colors and such (no image changes).
-There's a "loading banner" now -- I guarantee you that it will not slow down the start process in any way, but it will tell you what's going on. I did this so I could discard unused code from memory after loading, plus, give some user feedback. You can disable the Loader using the (Quiet) command line parameter: /Q
-To hide the ".." from the folder lists, add this to your RR.INI: hidedots=true
Thanks for your support,
Guino.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 06-05-2005, 11:37 PM   #2
goosey2099's Avatar
goosey2099 is on a distinguished road
Nice! Thank You!!
4G64 5 SPEED
MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
goosey2099 is offline   Reply With Quote
Old 06-06-2005, 01:31 AM   #3
4u2n's Avatar
4u2n is on a distinguished road
nice job
Plan for project = 100%
Part the project. = 100%
Built...................= 99%
Finish.................= 99%
Install ...............= 99% -50%
Ditail at 4u2n.dk
Here
4u2n is offline   Reply With Quote
Old 06-06-2005, 01:56 AM   #4
ppgt94's Avatar
ppgt94
This is friggin' great!
ppgt94 is offline   Reply With Quote
Old 06-06-2005, 02:22 AM   #5
Mr.Fabio's Avatar
Mr.Fabio is on a distinguished road
Thanks Guino!!!!
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 06-06-2005, 03:04 AM   #6
contaygious's Avatar
contaygious is on a distinguished road
sweet thanks!
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
contaygious is offline   Reply With Quote
Old 06-06-2005, 03:30 AM   #7
Clarre's Avatar
Clarre is on a distinguished road
Thank you Guino!!
Via Epia M1000
512MB RAM
120MB IBM Hard drive
Netgear MA111
Lilliput 8" Touchscreen
http://www.clarre.com/carcomputer.htm
Clarre is offline   Reply With Quote
Old 06-06-2005, 04:19 AM   #8
Magma
Excellent, thankyou!
Celica VVTi
EPIA M10000 Nehemiah, 160Gb HDD, 7" Lilliput VGA Touchscreen, Opus 150Watt PSU, Slimline DVD/CDRW, Road Runner
Magma is offline   Reply With Quote
Old 06-06-2005, 07:13 AM   #9
Mr.Fabio's Avatar
Guino, I have tested the Preset for PhoCo. When a call is done or is incoming, the Phone preset is correctly loaded, but when i press the hangup button to terminate the call, the previous preset is not restored
Mr.Fabio
Travla C134
Old 06-06-2005, 12:50 PM   #10
guino's Avatar
I have to test it myself.. but did you DISABLE the Phoco volume controls in PHOCO settings -- I remember I had trouble with it.
Old 06-06-2005, 01:19 PM   #11
Mr.Fabio's Avatar
Onestly i have to check this setting, dont remember now. I will let you know later
Mr.Fabio
Travla C134
Old 06-06-2005, 05:19 PM   #12
Mr.Fabio's Avatar
Nothing to do. I've double checked and still doesn't release the phone preset at the end of the call. Seems like in a first moment the preset returns to his previous state, and after a while it returns on Phone.....
Mr.Fabio
Travla C134
Old 06-06-2005, 10:41 PM   #13
Gender is Questionable
ibrennan's Avatar
ibrennan is on a distinguished road
ok with this new version rr.exe is using about 75-100% of the cpu most of the time and the lib support doesn't seem to be working....i get to all albums and it just doesn't do anything..... and no its not flash thats causing the cpu problem
2001 Explorer
Xenarc, Opus 90W, 120 GB HD, Bondo everywhere
Sold the Explorer...got a 350z
ibrennan is offline   Reply With Quote
Old 06-06-2005, 11:28 PM   #14
cdevelasco's Avatar
cdevelasco is on a distinguished road
hmmsorry if its a dumb question but how exactly do i use/incorporate the winamp library support? what exactly would be its benefit?
My Projects:
Old project
2000 A4
http://www.mp3car.com/vbulletin/show...ight=2000+audi
New Project
2006 Montero
http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
cdevelasco is offline   Reply With Quote
Old 06-07-2005, 01:46 AM   #15
guino's Avatar
Some people just like having disorganized files and organized tags, the lib support allows you to browse by artist/album/genre instead of by file. All you have to do is setup the library settings in Winamp (with the folder of your files) and have it build the database. Then RR will find and show that info.
RR 05-12-05... Extra FM support ... guino Road Runner 64 05-27-2005 11:37 PM
Minimize winamp on RR Startup Shelbrain Road Runner 6 05-26-2005 02:09 AM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
RR 3-30-05 ... Mappoint ... guino Road Runner 122 04-06-2005 01:47 AM
RR 03-12-05 .. Keyboard Support ... guino Road Runner 26 03-15-2005 02:48 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
