Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-06-2005, 08:59 PM   #1
lominono's Avatar
Help RR did something to my winamp
before i installed RR my winamp was working just fine. after i installed RR if i just open winamp and play a song it will attemp to play then a sec later it stops.
What can i do to get winamp to work again???
lominono is offline   Reply With Quote
Old 06-07-2005, 12:38 AM   #2
RoadRunner Mastermind
guino's Avatar
All RR does is RUN winamp. It changes no settings, no files and nothing with the plugins. I don't believe the Installshield could have done something either (but I don't maintain that so I can't guarantee it). You can try deleting your winamp.m3u file and see if that helps (by selecting other music), but chances are you're either loading bad files or your install is messed up, which would require a re-install.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 06-07-2005, 02:22 PM   #3
The Install doesn't do anything to the Winamp Install. It only copies the Files in that Road Runner needs, but doesn't touch the Winamp settings or Installation.
Later,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
bry21317 is offline   Reply With Quote
Old 06-08-2005, 12:05 AM   #4
lominono's Avatar
my winamp was working fine untill after i had used rr. i have no idea what the deal is. rr plays music thru winamp fine but winamp wont play. i guess im gonna have to reinstall winamp
Old 06-08-2005, 12:23 AM   #5
guino's Avatar
are you sure you're using the same winamp ? who plays music in RR IS Winamp. whatever songs you select in RR, will be what Winamp will have loaded when running winamp alone. you can probably run a task-list and make sure winamp is the only audio application running. RR does nothing to winamp different than what happens when you run winamp alone...
Old 06-08-2005, 02:36 AM   #6
With last version of RR Winamp stay on Top if i dont select a RR module to hide Winamp.
So I had to minimize Winamp to hide it.
Older versions of RR have'nt this problem
grave is offline   Reply With Quote
Old 06-08-2005, 09:02 AM   #7
guino's Avatar
This is just a Always on Top option in winamp you probably have on... there hasn't been a single change in winamp's handling for the longest time.
RR 06-06-05 .. Winamp Library Support ... guino Road Runner 76 06-19-2005 12:36 AM
Minimize winamp on RR Startup Shelbrain Road Runner 6 05-26-2005 01:09 AM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
RR hang due to WinAmp dialog. Arathranar RR Bug Tracker 4 04-06-2005 07:19 PM
Occasionally winamp uses almost all the cpu slowing down RR Arathranar RR Bug Tracker 3 03-21-2005 11:38 PM
