The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 10-11-2007, 04:43 PM   #106
xpluis's CarPC Specs
xpluis's Avatar
Vehicle: Dodge Neon
My Photos: (4)
Thanks Guino and tejesh83, i not sell my mobo until i can see next release of rr.
xpluis is offline   Reply With Quote
Sponsored Links
Old 10-12-2007, 02:36 PM   #107
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
3 resumes from hibernation and it's working flawless. Clock does not freeze and i get instant reading from GPS.
treetop777 is online now   Reply With Quote
Old 10-17-2007, 09:21 AM   #108
djmickyg's Avatar
Vehicle: 2006 Ford XR6 Turbo Ute
My Photos: (3)
i'll be trying this out also..
I've had this problem for ever,, some updates seemed to have fixed but then it was back agian right away..
djmickyg is offline   Reply With Quote
Old 10-17-2007, 03:56 PM   #109
treetop777's Avatar
My Photos: (0)
Still goin' strong after many returns from hybernation.
Old 10-19-2007, 12:10 PM   #110
djmickyg's Avatar
My Photos: (3)
after 2 days its been working fine..
nice work
Sponsored Links
Old 10-19-2007, 04:59 PM   #111
Vehicle: 91 Ford Probe
My Photos: (0)
Has this already been implented in the official rr code ? When will an official version, containing this changes, be released ?
Konrad is offline   Reply With Quote
Old 10-20-2007, 01:19 AM   #112
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
I've added a similar code based on tejesh83's code as an option for next release.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 10-20-2007, 09:30 AM   #113
My Photos: (0)
Great ! Thanks for the info .
Old 10-26-2007, 02:22 PM   #114
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
Quote: Originally Posted by tejesh83 View Post
Updated mod for 9/30 release is attached. Like before, lets consider this a beta release, so use it at your own risk. I've tested it in my carpc, and it appears to work correctly.
To install, browse to your RR install directory. For backup purposes, rename the existing RoadRunner.exe to RoadRunner.bak or whatever you prefer. Then replace this exe with the one provided in the zip file.
The basic mod is the same as I posted previously for the last RR release. This time around I had more familiarity with VB6 and the RR source, so it should be less quirky.
Basic Algorithm: The code keeps a timestamp that is updated every second. If between updates, more than 60 seconds has passed, I have assumed the system has just resumed from hibernation and call the RR resumeFromHibernate function to restore the skin, music, ports, etc. NOTE: For testing purposes, please wait at least 60 seconds while the carpc is in hibernation before powering it back on so that the mod will trigger.
Please post your results. I can't promise to work out the bugs, but I'll try as time permits. If its stable, I'll pass along the mods to Guino to incorporate into the next release.
I tried this beta version and It does not work all the time. Music plays just fine when returning from hibernation. The problem is that the ONRESUME command will not fire all of the time.
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 10-26-2007, 03:08 PM   #115
guino's CarPC Specs
guino's Avatar
My Photos: (5)
Try the new release -- my code is similar, but different than his -- do add resumecheck=true to RR.INI first.
Old 10-30-2007, 08:44 PM   #116
tbird2340's CarPC Specs
tbird2340's Avatar
Vehicle: 2005 Dodge Ram Quad Cab
My Photos: (0)
My music will sometimes resume to an album (and always the same one) that I listened to the very first time I ran RR..
Sometimes it will resume to the correct music but often times more than not it resumes to the same album (even though that album wasn't even in the playlist at the time of hibernation).
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-30-2007, 09:19 PM   #117
guino's CarPC Specs
guino's Avatar
My Photos: (5)
do you use EWF/HORM (Or XPe)?
Old 10-31-2007, 06:43 AM   #118
tbird2340's Avatar
My Photos: (0)
I used Minlogon for a couple days then I realized it wasn't worth the extra few seconds to lose network login support so I switched back. Other than that, nothing out of the ordinary.
Thanks for the reply.
Old 10-31-2007, 07:21 AM   #119
Nomader's CarPC Specs
Nomader's Avatar
Vehicle: Citroen Xsara 2002
My Photos: (0)
what i have noticed on the latest release is that when i have "resumecheck=true"
when i try to load a skin that has a visuallization embedded in it (and on my oldy desktop it takes 3-4 seconds) the skin is loaded but the resumecheck is triggered by mistake!! ( i can see that because my "ONRESUME";"xxxxxxx" stuff i have in ExecTBL.ini are run!!
Nomader is offline   Reply With Quote
Old 10-31-2007, 12:37 PM   #120
guino's CarPC Specs
guino's Avatar
My Photos: (5)
Well, RR checks if 5 seconds have gone by without it being able to update anything.. if that's the case, it triggers the resume event -- the original code also had a 5 seconds check. In most cases this is enough.. I'll make it 30 for next release.
Sponsored Links
vB code is On
Trackbacks are Off
RESUME after hibernate frodoplayer paused until user input kuo FP Bug Reports 22 08-06-2006 03:57 PM
no sound on resume from hibernate FIX temporarly xdjxklusivex FrodoPlayer 5 12-18-2005 12:23 PM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
Audio crash after hibernate (USB alerts) Peoples RR Bug Tracker 11 03-10-2005 01:29 PM
No auto resume music and video? organasised Road Runner 3 02-10-2005 09:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
