Hi Man,
I've connect the original steering whell command of my car whit an IR interface to the CarPC, setup WinLIRC and Girder, and run RR, this work well, the job is little, only vol+/- track +/- and paly/pause, vol and track work fine in mp3 (audio) section, but when I press play button RR play but don't accept any IR command.... I must stop music manually, return in main menu and all work, press IR play and this stop to work, no IR volume change or other.
In Radio section all works fine, I've try to install old version of RR (Fist April) but nothing change.
Help ME....
Bye
