that will depend exlusively of the software/hardware used... there's typically a setting to select the output monitor... maybe the easiest thing is to put RR in the 1st screen, swap the cables and move the monitor 2 to the left of monitor 1 in the display propperties... this should virtually be the same as the initial setup...
Road Runner,RR's Myspace
