This is a design limitation.. you can add something like this to ExecTBL.INI to relaunch it automatically:
"SELECT","NEWSKIN",skin_browser.skin
"NEWSKIN","SELECT||DESTINATOR||MAIN",MM
"NEWSKIN","SELECT"
The above will detect the select button on the skin browser, and if MM is running, it will re-launch MM upon changing the skin then exit back to the main menu (this will take a few seconds likely).. and if MM is not running it will not auto start it.. I have not tried the above but it should work..
Ride Runner RR's Myspace
