Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 08-03-2005, 01:45 PM   #16
Tim97rs is on a distinguished road
okay, since im a little slow on all this so far... RR now has sirius option, and in order to use it you need an interface from another board memeber (forgot who, can i get a link??? ) and obviously a subscription. i thought the interface was still experimental and not availanble to us yet... that changed?
this is the first sirius option out right now for carputer use, correct?
thanks
Tim97rs is offline   Reply With Quote
Old 08-03-2005, 01:57 PM   #17
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Quote: Originally Posted by iPal
guino
i found bug in builtin video player...
i found missing fregment...
hope it helps you saving time to find it...
Thanks for pointing out the bug... 'getthistime' was meant for XM usage (this in the XM module).. I ended up using it in the video player for convenience, in any case I just modified the two functions in the video player to return the time in seconds and kept the 'getthistime' function as before so it doesn't interfere with the XM support.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 08-03-2005, 01:59 PM   #18
guino's Avatar
thanks
I'm Thinking TimeTrax does the same (simulate a COM port).. MitchJS will make boards available for sale as soon as he's back from Vacation (mid-August).. but any adapter with a COM port in windows should work.
Old 08-03-2005, 03:21 PM   #19
maestro83's Avatar
maestro83 is on a distinguished road
hi guino, thanks for the speed of your Update but I would have a problem, INDICATOR:"direction" does not work, or mistake I!
you could help me?
the logo flash it does not work, does not come more redesigned!
maestro83 is offline   Reply With Quote
Old 08-03-2005, 03:59 PM   #20
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
not sure if its only me but the "w0dayicons" etc dont load on my summary or main page
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 08-03-2005, 04:19 PM   #21
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Guino, could it work with using MM/FD's City? (could you add this option)
like mybe you can add an option to make cityweather=FDCity and a countryweather=São Paulo, Brazil so it would get the city I'm in.... (and use São Paulo if it cant find weather for that city)
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 08-03-2005, 04:37 PM   #22
Mr.Fabio's Avatar
Mr.Fabio is on a distinguished road
This will be very useful
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 08-03-2005, 04:47 PM   #23
guino's Avatar
you could help me?
Note: the indicator "DIRECTION" works only with MM (currently) -- I'll also parse FD messages in the future so it works with it.
The most important thing is that the CURRENT SKIN has the MM_*.jpg images available for drawing. Otherwise it won't work.
The flash logo works, but you're basically overwriting the area of the logo (and that was "granted" on previous version) -- but won't work from now on... you should either reduce the size of the flash logo OR make transparent OFF/DOWN and ON images to where it only draws the buttons outside the area used by the flash logo. To do that, you just have to make BMP files instead of JPG (lossy), and make the transparent area (where not to draw) PINK (Full Red, Full Blue, No Green).
Old 08-03-2005, 04:48 PM   #24
guino's Avatar
As I posted on the notes: the WEATHER folder needs to go under RR's subfolder and NOT on the Skin's folder.
Old 08-03-2005, 04:51 PM   #25
guino's Avatar
Guino, could it work with using MM/FD's City? (could you add this option) like mybe you can add an option to make cityweather=FDCity and a countryweather=São Paulo, Brazil so it would get the city I'm in.... (and use São Paulo if it cant find weather for that city)
I'm not done with the weather, and have actually devoted little time on it so far... I do intend to allow it to use the GPS's city info for weather... but there are many things I need to work on it..
Old 08-03-2005, 05:07 PM   #26
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
As you mentioned above, the problem with the flash i'm using is that my ON image also uses the same area of the flash, the flash was transparent before.. but I will alter my skin now to suit
cheers m8
CdR
CdRsKuLL is offline   Reply With Quote
Old 08-03-2005, 05:14 PM   #27
guino's Avatar
cheers m8
CdR
If anything, I can probably add some code to redraw the flash object when drawing over it, but chances are it might make it "flash" (literally)..
Old 08-03-2005, 06:44 PM   #28
dmurray14 is on a distinguished road
Has he left yet? I know he had a few trials left, and I've been trying to get a hold of him for a few days, but he's not responding...
dmurray14 is offline   Reply With Quote
Old 08-03-2005, 07:14 PM   #29
Chita79's Avatar
Chita79 is on a distinguished road
it would definately be nice to see timetrax embedded/reskinned into RR!
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
Old 08-03-2005, 07:46 PM   #30
maestro83's Avatar
Exclamation
original post: from guino
I have understood thanks!
for the logo all ok! for "direction" it does not work!
I have inserted in skin the images mm_*.jpg, I have started MM but nothing!
RR 06-06-05 .. Winamp Library Support ... guino Road Runner 76 06-19-2005 01:36 AM
RR 05-12-05... Extra FM support ... guino Road Runner 64 05-27-2005 11:37 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
RR 3-30-05 ... Mappoint ... guino Road Runner 122 04-06-2005 01:47 AM
RR 03-12-05 .. Keyboard Support ... guino Road Runner 26 03-15-2005 02:48 AM
