Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 08-02-2005, 11:17 PM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow RR 08-02-05... SIRIUS Support ...
In this version:
-Added Screen Limiting Option (To limit memory usage)
-Added Full SIRIUS Support
-Added Weather Support (Thanks to MSCAR)
-Improved Memory Handling
-Fixed Issue with "ADD1" on searchfiles results
-Fixed Issue with "SETLABEL" on switching labels
-Fixed Issues with "DIRECTION" indicator
-Fixed Issue with "SEARCHLIST" on XM
Notes:
-I'll be updating the skins to include SIRIUS support. If you wish to try it before then, download this: SiriusFiles.zip. You'll need to change/make a button to execute "SIRIUS". RR should work with ANY sirius interface as long as it provides a SERIAL/COM port for commnication with the tuner. Thanks to Chuck for the Station Art images. You should also read a few notes on Sirius support HERE .
-Screen limiting is optional and is done by adding "screenlimit=N" to RR.INI where N is the number of screens allowed in memory (minimun of 3).
-For now, Weather Support only works when the internet is connected. I might add Weather Cache support later. You'll need those files: Weather.zip. You should thank MSCar this code. The Weather folder should be inside RR's folder.
-As you may have seen when I was testing a BETA version, the memory optimizations took out quite a bunch of my time during the past few weeks.. I tried about 6 different approches before defining the current one.
For as much as I don't like to, I'll spend some time improving a few things in the Brushed skins on the next few days..
As always, thank you for your support,
Guino.
PS: Special thanks to MitchJS who was kind enough to donate one of his interface boards (soon for sale) for development purposes.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 08-03-2005, 02:26 AM   #2
iPal is on a distinguished road
guino
i found bug in builtin video player...
i found missing fregment...
hope it helps you saving time to find it...
[modXM]
Public Function getThisTime(ByVal timein As Long) As String
'Used to format the position and duration
On Error Resume Next
Dim conH As Integer
Dim conM As Integer
Dim conS As Integer
Dim remTime As Long
Dim strRetTime As String
remTime = timein / 1000
conH = Int(remTime / 3600)
remTime = remTime Mod 3600
conM = Int(remTime / 60)
remTime = remTime Mod 60
conS = remTime
If conH > 0 Then strRetTime = Format(conH, "00") & ":"
strRetTime = strRetTime & Format(conM, "00") & ":"
strRetTime = strRetTime & Format(conS, "00")
getThisTime = strRetTime
Exit Function
End Function
iPal is offline   Reply With Quote
Old 08-03-2005, 02:41 AM   #3
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
You forgot to update GammaControl. Use v1.2
0l33l is offline   Reply With Quote
Old 08-03-2005, 02:43 AM   #4
My Village Called
0l33l's Avatar
Ok... using your SDK example. I type in RRSCREEN and I press send and I get nothing.
Old 08-03-2005, 03:29 AM   #5
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
funny things happening with flash ? Just updated to this version, but now it seems that the flash bit is being overwrote by image_on when hovering over, then sometimes it stays on, then other times it disappears
CdR
CdRsKuLL is offline   Reply With Quote
Old 08-03-2005, 07:52 AM   #6
dmurray14 is on a distinguished road
Guino - this is awesome! I can NOT believe how fast you shot out a SIRIUS update! I know you used MitchJS's interface, but you speak about a com port - isn't MitchJS's USB? Or is it creating a virtual com port? Thanks again for all your work, with any luck I'll be able to get in touch with Mitch and get my own interface...
Dan
dmurray14 is offline   Reply With Quote
Old 08-03-2005, 10:22 AM   #7
Jeeve5 is on a distinguished road
Great think on the weather addon. Will do some fiddeling with ita nd can't wait for the weather cache function
Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
Download the German Voicepack 1.0 for FreeDrive now!
Jeeve5 is offline   Reply With Quote
Old 08-03-2005, 10:24 AM   #8
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Hey Guino, pardon my extreme ignorance, but where do I change the area that it gets the weather from?
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 08-03-2005, 10:35 AM   #9
I second that
Old 08-03-2005, 11:07 AM   #10
Custommx3's Avatar
Custommx3
LOL, I was about to post the same thing
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 08-03-2005, 01:02 PM   #11
guino's Avatar
Yeah, I have yet to add those options to RRConfig. I meant to mention it, and forgot (did place it in the readme.txt file though).. Add to RR.INI:
cityweather=<CITY>
weatherunits=USA|WORLD
Examples:
cityweather=Los Angeles, CA
weatherunits=USA
or
cityweather=Amsterdam, Netherlands
weatherunits=WORLD
I can't guarantee coverage for the entire world...
Old 08-03-2005, 01:05 PM   #12
guino's Avatar
You need to use the "REQUEST" command... i.e. "REQUEST;MyApp;RRSCREEN" where 'MyApp' is the window name that will receive the message with the information requested. There are more details in Skin Commands.txt.
Old 08-03-2005, 01:06 PM   #13
guino's Avatar
Dan
His USB interface simulates a COM port (serial) for easy interfacing. Direct USB control is also possible but requires extra files I didn't want to use.
Old 08-03-2005, 01:14 PM   #14
Awesome...hopefully he'll respond to my PM and I can get one of these interfaces...
Old 08-03-2005, 01:26 PM   #15
guino's Avatar
CdR
I only found an issue with the Flashtastic skin.. the SHUFFLE/REPEAT indicators are still defined to draw the images onto the screen and RR is doing it over the flash object (new drawing functions have more power now).. but if you define them as 'Ixx,0,0,0,0' for area that won't happen.
Please give me another example of "funny thing" and I'll look into it.. I can't exepect to re-write most of the image handling and have no issues at all..
RR 06-06-05 .. Winamp Library Support ... guino Road Runner 76 06-19-2005 01:36 AM
RR 05-12-05... Extra FM support ... guino Road Runner 64 05-27-2005 11:37 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
RR 3-30-05 ... Mappoint ... guino Road Runner 122 04-06-2005 01:47 AM
RR 03-12-05 .. Keyboard Support ... guino Road Runner 26 03-15-2005 02:48 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
