Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-11-2005, 03:44 PM   #1
Flappy's Avatar
Flappy is on a distinguished road
RR is running really slow...
Hi!
Today i did a fresh install on my desktop PC. I use it to test roadrunner and skins. Since then Road Runner runs really slow... I have to click on buttons 4-5 times before they work... Sometimes RR hangs completely. This is kinda strange, cause before the fresh install there was nothing wrong...
I used the same software as before, only now updated versions.
I use:
Roadrunner
Skin: LS3.0 ver4
Winamp 5
How is this possible? Did i miss something?
Thanx for your help!
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Flappy is offline   Reply With Quote
Old 10-11-2005, 03:46 PM   #2
chewEboy's Avatar
chewEboy is on a distinguished road
installed macromedia flash? newest version?
chewEboy is offline   Reply With Quote
Old 10-11-2005, 03:57 PM   #3
Flappy's Avatar
installed this one,
http://www.macromedia.com/shockwave/...ShockwaveFlash
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Old 10-11-2005, 04:09 PM   #4
TheKingPlaza is on a distinguished road
I also noticed this today in my car setup.
When playing some folders/mp3's kinda use abnormal performance. hit the next/forward button normaly plays next song, but after latest update it only forwards the slider. My car setup hasn't changed since february 2005. Tomorrow I'll try a fresh (RR) install to see if it solves any problems.
TheKingPlaza is offline   Reply With Quote
Old 10-11-2005, 04:13 PM   #5
Chita79's Avatar
Chita79 is on a distinguished road
ive been noticing similar issues... takes a while to respond when searching through a video file on the slider, doesnt refresh as fast anymore
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79 is offline   Reply With Quote
Old 10-11-2005, 04:18 PM   #6
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Diddo. I've noticed it to. Movie between menu selections takes a good 5 seconds. Latest updates and zots skin.
Old 10-11-2005, 04:37 PM   #7
Flappy's Avatar
strange... everything runs normal now... Sometimes it just happen again, slow running and system hanging (RR). Only option then is CTRL-ALT-DEL..
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Old 10-12-2005, 10:21 AM   #8
jjfta is on a distinguished road
Anyone have any luck figuring this one out. My menu selection are all extremely slow when selected for the first time (5 to 10 seconds). I have installed the latest flash. I have even reinstalled windows (as my carpc is still on my desk being tweaked). I used a different version of windows xp pro this time. I still have the same issues, extremely high cpu demand when starting and selecting menu buttons in RR. (all buttons excepte "minimize" and "Day/night", and mute). I have checked my ini file, looks good to me.
Also, maybe some has come across this problem. When I first touch the volume control (after rr boots), sound stops. I have to move the slider all the way to zero then back up to get sound. Once this is done volume controls function normally.
jjfta is offline   Reply With Quote
Old 10-12-2005, 11:44 AM   #9
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Which skin are you using, do you have the latest flash + OCX ? Can you post the first 3 lines of some of your .skin files ?
Your slider problem seems very much like a driver issue... some SB cards are known to have bad drivers... I'd suggest looking for an updated driver before anything.. RR only reports a slider at a certain location when/if it is being reported (from the drivers) as in that location... and it unmutes the line prior to any adjustments (exactly to prevent issues like yours)... I can only assume the sound card is saying the audio is at X% when you actually have no sound..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-12-2005, 01:47 PM   #10
MEDIACAR Skin
MEDIACAR "audioplayer" Skin
audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B02,500,0,150,60,"VISU",
B03,300,520,100,80,"VOL-",
B04,400,520,100,80,"VOL+","Volume+"
B05,0,520,150,80,"PREV","Prev/FW"
B06,500,520,150,80,"PLAY","Play"
B07,650,520,150,80,"NEXT","Next/FF"
B08,150,520,150,80,"STOP","Stop"
B09,175,217,200,200,"LOAD;Audio_List.skin",
B10,0,0,150,60,"EXIT","Exit"
/, I, x, y, w, h, Code;INDICATORCODES
I,675,118,80,30,"REPEAT"
I,675,87,80,30,"SHUFFLE"
B12,150,0,150,60,"MIXER",
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,74,133,600,30,192,192,192,20,"Decker:B","TAGAR TIST","SCROLL-LEFT"
L02,74,83,600,40,255,255,255,28,"Decker:B","TAGTIT LE","SCROLL-LEFT"
L04,75,351,80,30,254,5,0,14,"Decker:B","KBPS","Tra ck bitrate"
L05,75,307,80,30,254,5,0,14,"Decker:B","KHZ","Trac k freq"
L06,75,394,80,30,254,5,0,16,"Decker:B","TAGYEAR",
L08,409,486,50,30,255,255,255,16,"Decker","VOLUME" ,"LEFT"
L10,75,262,80,30,254,5,0,14,"Decker:B","CURRENTTRA CKTIME","Current track time"
L11,75,215,80,30,254,5,0,14,"Decker:B","TRACKTIME" ,"Total Track Time"
L12,633,487,40,30,255,0,0,16,"Decker","=ETR","RIGH T"
L,41,487,60,30,255,0,0,16,"Decker","=CPU","RIGHT"
L,183,487,50,30,255,0,0,16,"Decker","=CASE","RIGHT "
L13,500,487,40,30,255,0,0,16,"Decker","=ETA",
L14,343,486,50,30,192,192,192,16,"Decker","=Vol"," RIGHT"
L,686,487,60,30,255,0,0,16,"Decker","CUSTOMFDETR", "LEFT"
L,552,487,60,30,255,0,0,16,"Decker","CUSTOMFDETA", "LEFT"
L,641,422,100,40,255,255,255,24,"Decker","=Km/h","LEFT"
L,531,422,100,40,255,255,255,24,"Decker","CUSTOMFD SPEED","RIGHT"
L22,413,333,330,40,255,255,255,22,"Decker","CUSTOM FDROAD","LEFT"
L,637,304,100,20,192,192,192,14,"Arial","=Satellit es","LEFT"
L23,588,304,40,20,255,255,255,14,"Arial","CUSTOMFD SATS","RIGHT"
L24,532,379,200,30,255,255,255,18,"Decker","CUSTOM FDNEXTMAN","LEFT"
L25,415,379,100,30,255,255,255,18,"Decker","CUSTOM FDNEXTMANDIST","LEFT"
L15,75,437,300,30,255,255,255,18,"Decker","TAGALBU M","SCROLL-RIGHT"
L16,113,487,52,30,255,0,0,16,"Decker","MbM1","0.0C "
L17,247,487,52,30,255,0,0,16,"Decker","MbM2","0.0C "
B,473,205,250,60,"SHUFFLE/REPEAT",
B11,400,294,350,150,"GPS",
/, J, x, y, w, h
J01,175,217,200,200
/, A, x, y, w, h, color;RGB
A01,30,170,740,310,000
END
Old 10-12-2005, 11:01 PM   #11
Still frustrated with the slow launch times, I went and uninstalled version dated 10/7/05 and put back version dated 5/12/2005.
All is back to normal now (about 3 to 4 times faster launching menu buttons).
In addition, the volume slider issue I was having is no longer.
I'm using the BMV2 and Zots skins just downloaded from the rr page. So far no issues.
If I can't get the newer versions to run right on my system, what major features will I be lacking?
Old 10-13-2005, 12:48 AM   #12
goosey2099's Avatar
goosey2099 is on a distinguished road
My RR is also very slow after i last reinstalled windows.
4G64 5 SPEED
MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
goosey2099 is offline   Reply With Quote
Old 10-13-2005, 01:21 AM   #13
pRoFiT's Avatar
pRoFiT will become famous soon enough
MEDIACAR Skin
Whats up with that. Im seeing ****. there is a space between "audio_pl" and "ayer_on.jpg" but when i quote it it fixes itself.
Anyone else see that or have i been up too long? If im not seeing things then TheKingPlazza: is that how the file has it too?
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 10-13-2005, 01:28 AM   #14
tolisn's Avatar
tolisn is on a distinguished road
Yep I'm also seeing the space
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 10-13-2005, 03:13 AM   #15
Flappy's Avatar
I had the same problem too... I did a fresh install of windows yesterday, the volume problems are over now...
RR is running slow as in my previous install, i also used another Win XP Pro cd.
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
PhoneControl.NET startup delays RR rjoek Road Runner 2 08-04-2005 07:06 PM
Tripex3 in RR accentsound Road Runner 3 07-21-2005 08:09 AM
IE in RR bug accentsound RR Bug Tracker 2 07-10-2005 02:21 PM
RR is slow when pusinh Music Goose Road Runner 14 04-20-2005 06:17 PM
