Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-16-2005, 09:04 AM   #1
Problem with hybernate and touchscreen
I know this problem is not a RR problem so just asking for advice. I use a Lilliput screen with Touchscreen but when I select hybernate in RR the computer hybernates correctly but immediately resumes again. If I disconnect the touchscreen USB it works OK. Is there a way to disable the touchscreen USB driver from within RR before RR issues the hybernate instruction and enable it again on resume or has anyone have a fix for this problem.
Many thanks.
p1cass0 is offline   Reply With Quote
Old 10-16-2005, 10:52 PM   #2
RoadRunner Mastermind
guino's Avatar
You can use the ONSUSPEND and ONRESUME events of ExecTBL.ini to execute a command to disable the touchscreen and to re-enable it.. this can be done by running DEVCON.EXE on RR's folder. You may want to use a .bat file for ease of setup.. but nonetheless, I think most users have a touchscreen and don't have this issue, so sounds like it could be something else...
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 10-17-2005, 01:31 PM   #3
Thanks Guino, did as you suggested and works like a charm.....Great software and support. Thanks.
