11-25-2005, 12:05 PM
#31
Sorry, you thought wrong. The iGuidance changes are not added yet. This is future development. I've added the iGuidance config item into RRConfig, but at present this config value is not used by RR.exe (sorry).
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
11-25-2005, 01:43 PM
#32
Of Ice and Men
Looks like there is still some other bug. This is what I get after launching RR after update to 10a
11-25-2005, 01:45 PM
#33
LagunaICE: What version of windows are you using?
06 Volvo XC90
11-25-2005, 01:47 PM
#34
Of Ice and Men
..and this is my Time zones registry export for debugging purposes...
11-25-2005, 01:54 PM
#35
Anyone else with this TZ problem? I've tested on XP SP2 and Vista and have not been able to recreate this problem.
06 Volvo XC90
11-25-2005, 02:00 PM
#36
Skippy: How do your Time Zones registery entries compare to the ones he uploaded? The same or different?
Laguna: What version of Windows are you running, and where did you pull those registry files (obviously from \Software\Microsoft\..., but from HKLM or HKCU or what?)
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
11-25-2005, 02:14 PM
#37
Of Ice and Men
Its WindowsXP Pro SP2 English but with Czech regional settings.
The registries are export of: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones]
11-25-2005, 02:37 PM
#38
Of Ice and Men
By the way I just tried on VM machine running with nLited WindowsXP Pro SP2 Czech with same regional settings
11-25-2005, 02:38 PM
#39
Of Ice and Men
One more thing I have noticed: Original guinos RR.exe is 485kb in size and your beta 10a has 1.91MB Is this expected growth in size?
11-25-2005, 03:00 PM
#40
LagunaICE: Re size: It's just compilation options (for the BETA)
Is anyone else having this TZ problem?
Here's the code used for the TZ:
' get current timezone
If IsNT Then
sRegKeyTZI = "Software\Microsoft\Windows NT\CurrentVersion\Time Zones"
Else
sRegKeyTZI = "Software\Microsoft\Windows\CurrentVersion\Tim e Zones"
End If
If Not GetTZICollection(sRegKeyTZI) Then
MsgBox "Unable to locate Time Zones information in Registry under the key: " & vbCrLf & sRegKeyTZI
End
End If
sCurZone = GetRegValueStr("System\CurrentControlSet\Control\T imeZoneInformation", "StandardName")
06 Volvo XC90
11-25-2005, 03:04 PM
#41
Just got back from long test drive and down loaded beta 10A on the road
Speed vol works good with linear – tried the others but at 70 mph the vol was all the way up and the slider made no change
As for the gamma the button goes thru all modes with no problems in gps mode
Now for transparencys with .swf files and windows 2000 – the background shows up now and it did not before like the picture of the clock in post #22 above.
Did the indicators make this happen?
11-25-2005, 03:12 PM
#42
Else
End If
Is there a space there? Not sure if that is a typo in Time Zones or just the way it is being displayed in the post.
Oh and here also a space after the T:
Just grasping at straws here :-)
Chuck
11-25-2005, 03:14 PM
#43
Thanks Chuck. Need to look into the other GPS Vol changes, not sure if Tim's changes has effected this.
Not sure about the swf transparency problem! I'm using Windows Vista to compile on so it could have been something to do with that... (maybe / maybe not)...
Tim is looking at the source code and is going to make some small fixes. Once he's done I'll issue BETA 10b
06 Volvo XC90
11-25-2005, 03:19 PM
#44
Internal GAMMA based on set times is working flawlessly for me :-) I was changing skins before but I'm going to try this as my default now.
Thanks for the hard work.
Chuck
11-25-2005, 03:21 PM
#45
did you use Vista to compile 9a?
| Thread Tools |
| Display Modes |
Linear Mode
