11-25-2005, 03:56 PM
#46
Gamma was working on my PC so I went to setup in the car. With the new RRCONFIG I get an error ONLY when trying to go into general settings. The following comes up COMCTL32.OCX is not registered or one of it's dependencies is missing.
All other setting options appear to be working fine.
Thx,
Chuck
11-25-2005, 04:49 PM
#47
Of Ice and Men
Yup, I found this "dependancy" too. Issue confirmed.
11-25-2005, 08:53 PM
#48
Chuck: Yes, 9a was compiled in Vista.
Also I've checked the code and the spaces are not there... I think it's the way it is displayed here.
Re dependency, yes, the ocx needs to be registred or copied to the Road Runner directory. I just copied over the ocx from my desktop to my carpc. In the next BETA release I'll put it in the ZIP file.
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
11-25-2005, 10:52 PM
#49
Hi,
I spend a lot of time for the indicators now, but it won´t work like I want. Something going wrong. Look at my skin.ini:
/, I, x, y, w, h, Code;INDICATORCODES
I05,25,465,115,50,"REPEAT:b"
I06,424,534,93,50,"MASTERMUTE:b"
I02,522,555,12,12,"GPSVOL:b"
IMG,522,555,12,12,"LED.jpg",ON
The LED.jpg is in the skin folder. Have I change something in my Skin.jpg.
The problem:
Press mute button -> mute is activated, no led
Press mute button -> mute is deactivated, led is on but when I get over another button -> no led
Press mute button -> same as second
Ti-ejtsch
11-25-2005, 11:09 PM
#50
the config looks nice..
havent tried it in the car with gps yet but all is working on the home pc
now rr is using gps cords for a few things now would it be wise to have the option for rr to conect to a port to get its own data. cus i dont run Freedrive all the time.. but i run a gps port splitter..
or, the option for run gps in the background when RR is loading??
anyways so far so good.. i will play some more
11-26-2005, 07:08 AM
#51
Quote: Originally Posted by Chuck
Speed vol works good with linear – tried the others but at 70 mph the vol was all the way up and the slider made no change
There seems to have bug that if you set max step to very small (something like 0.05%) and other setting are so that volume can reach 100% it will stay there for ever. If you think that's not your problem, post from your ini-file all the (speetatt***) lines which you have in use when this happend.
Then there was another bug in gain mode, which caused problems when volume was over 50%. When volume was changed manually, wrong value was stored as basevolume, so basically when playing over 50% volumes it always try to decrease volume.
Third one was that when setting volume by slider, basevolume was not stored at all.
And for those who use FD as gps-program and are also getting speed from FD, don't wonder if you get strange results with volume levels.. FD will send speed as mph or km/h and RR import it as knots, so speed has never been correct in RR if you get it from FD. That's not only related to speedvol stuff, but anywhere where you use speed, like labels.. Someone was few times ago wondering that why RR show different speed than FD, so here's the reason.
These are fixed now to next release.
And if someone don't know, to get get speed from FD add next line to FD's sdk.ini file (found in FD installation directory):
FDSPEED=RoadRunner
In RRconfig's GPS-section, set gps port to 0 (not in use) and if you are using Km/h as speed unit in FD, check "international standard units" checkbox, if using miles verify that it's not checked.
Tim
11-26-2005, 10:04 AM
#52
djmickyg: Yes, I personally suggest using a COM Port splitter and assigning a dedicated COM Port to RR.
Ti-ejtsch: you have the wrong idea... please look into how the skiining is supposed to work. Your on / off LED is to be part of you skin_on.jpg and skin_off.jpg. The coords identify the area of the jpeg.
06 Volvo XC90
11-26-2005, 11:08 AM
#53
Terminal flasher
Skippy, did you get a chance to talk toTheUni regarding the transparent app problem?
11-26-2005, 11:44 AM
#54
Have PM'ed him. However, it was mentioned that this was no longer a problem in BETA 10a
06 Volvo XC90
11-26-2005, 02:33 PM
#55
Skippy76
I did use beta 10A yesterday and the transparent was still a problem on windows 2000 – beta 9a did not do this
11-26-2005, 02:40 PM
#56
Quote: Originally Posted by Ti-ejtsch
Hi,
The problem:
Ti-ejtsch
Ti-ejtsch are you putting gpsvol and led.jpg inside the mute indicator – that might be the problem – I do not have it inside the mute indicator
Skin Commands.txt
IMG,XXX,XXX,XXX,XXX,"IMAGE.GIF|JPG|BMP",[LAYER]
The above tag defines a screen region to load a specific image onto. The fast resizing will likely reduce
the picture's quality so you should try to make a matched size image.
The Image can be GIF, JPG or BMP -- If a GIF is used, transparency can be used.
[LAYER] can be ON/OFF/DOWN/EMPTY/OUT (to specify which layer to load the image onto) -- Optional, deault=OUT.
11-26-2005, 03:50 PM
#57
indicators stoped working in beta 10a
Ti-ejtsch stop what you are doing !!!!!!!!! indicators stoped working in beta 10a !!!!!!!!!!!
11-26-2005, 04:50 PM
#58
The Vauxhall Vectra Project
Thanks. Firstly, I did point out that this is a BETA so was not going go into great detail about how the functionality works. To most I believe it is pretty self explanatory.
Re Gamma test button: I'll try to add this, should not be too difficult.
Re Transparent Flash: Does anyone else have this problem.
Re GPSVOL and now GPS fix: I'll see if I can also encorporate it into the same indicator.
Basically for those that don't quite understand what this release is... It's a BETA release. It's a pre-release... It's a "may work / may not work, please test".
Once everyone is happy with the functionality and that it works the way we want it to, this will become an official RR release. Why am I doing this?
a) It's open source
b) Guino is taking a little time out
c) People wanted the functionality I implemented so I went ahead and did it.
Thanks for taking this up... when its released with it be 'Gunio' approved ?
Terran
11-26-2005, 05:03 PM
#59
CCSNET: IN short, yes. Please see this thread: http://www.mp3car.com/vbulletin/road-runner/64323-im-bit-confused.html.
Chuck: Has it stopped working or is it working better? I added a check to see if the GPS has lock!
06 Volvo XC90
11-26-2005, 05:45 PM
#60
Thanks skipp76
Ok - I did not know you added gps lock to the indicators – 10a was working in truck yesterday and today it was not, maybe I did not have a lock yet.
Also I tried to add indicators GIF with transparency and they would not work on 2k or xp
Ti-ejtsch - make shoe you have a lock on your GPS then try indicators
| Thread Tools |
| Display Modes |
Linear Mode
