Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-26-2005, 06:01 PM   #61
skippy76's Avatar
skippy76 is on a distinguished road
I'm beginning to wonder if this is a VISTA compilation issue...
Maybe I'll install VB6 on my laptop (XP SP2) and try to recompile...
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
skippy76 is offline   Reply With Quote
Old 11-26-2005, 06:09 PM   #62
Chuck's Avatar
Chuck is on a distinguished road
9a worked right with transparencies
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-26-2005, 07:05 PM   #63
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
it didnt on all 3 of my systems
Old 11-26-2005, 08:25 PM   #64
djmickyg's Avatar
djmickyg is on a distinguished road
Quote: Originally Posted by skippy76
djmickyg: Yes, I personally suggest using a COM Port splitter and assigning a dedicated COM Port to RR.
do u mean you can already do this??
djmickyg is offline   Reply With Quote
Old 11-26-2005, 08:45 PM   #65
Chuck's Avatar
What problems did you have with RR 10-31-05 and Beta 9 and 9a?
2001 S10 ZR2
Old 11-26-2005, 10:01 PM   #66
Terminal flasher
Applications would open normally then for no reason at all go transparent. It was a bug added when the transparent visualizations were added. If i opened igmod or any other embedded application it would go transparent, slowly down my computer considerably. Theuni said he had a fix on the 10-31-05 release but guino hasnt released anything since then. So far in my testing of beta 10 the problem has been solved. I have yet to try my transparent visualization yet though.
Old 11-27-2005, 08:11 AM   #67
Chuck's Avatar
Sonicxtacy02 what operating system are you using on all 3 of your systems?
2001 S10 ZR2
Old 11-27-2005, 09:24 AM   #68
Terminal flasher
Was using xp home on all of them.. However i recently upgraded my car to xp pro.
Old 11-27-2005, 12:01 PM   #69
Chuck's Avatar
Syippy76 - RR 11-27-05 update is working ok with transparencies on my machines
Are you going to do a beta 11 with RR’s 11-27-05?
2001 S10 ZR2
Old 11-27-2005, 12:51 PM   #70
skippy76's Avatar
Ok, I've recieved Guion's changes and am in the process of merging these (quite a bit of work).
I also plan on making a single units configuration (e.g. kph /mph) as this is beginning to be used in several places.
Once done I shall release BETA 11
Andrew
06 Volvo XC90
Old 11-27-2005, 02:10 PM   #71
skippy76's Avatar
Right, here goes...
I've released BETA 11 and it's available via the website:
Changes in this BETA include:
- Merged Giuno's changes in... there were quite a few and it gave me a head ache in ensuring I did not miss out anyones changes... hopefully it's good!
- Added a single kph / mph option to RRConfig and removed the exisiting one in GPS Vol and also in the GPS settings page. RR will now use this single value for all functionality that makes use of kph / mph.
- Included the missing ocx in the zip file.
Please ensure you run RRConfig and check all your config values (especially the kph / mph setting).
Andrew
06 Volvo XC90
Old 11-27-2005, 05:09 PM   #72
Chuck's Avatar
on it now
2001 S10 ZR2
Old 11-27-2005, 05:15 PM   #73
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Hey Skippy76 and others...
first of all thanks for your effort.... now, I just installed last night your 10a version (so still havent tried beta11 but I dont see your changelog referring to this), when using the USE VOLUME+ATTENUATION option, I'm having some problems...
it seems that RR loves starting with volume at 0%...(when stopped - when I'm running volume starts at a bit, but when I stop goes to 0, showing that RR isnt really regarding the previous volume I had set)... Also, when I set volume to say 5%... I speed up, volume goes to 10%, then I stop, volume goes below 5%, to something like 3%, for example... if I speed up and slow down several times, eventually it will go to 0% when I stop, again disregarding my initial volume...
I tried setting the max% and % at 80kph from 10% to 5% to see if it would do something, but it didnt change this behaviour...
I have also noticed that often RR is stopped, not resuming when coming out of hibernation/restart... is the functionality broken?
Overall the feature is great, but a bit unstable atmo... are you others having the same?
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 11-27-2005, 05:38 PM   #74
Chuck's Avatar
Beta 11 has introduced the transparencies with swf files on windows 2000 again.
I just do not understand adding gps speed vol, gps gamma and indicators and so on would do this to RR 11-27-05.
So I guess it back 9a or RR 11-27-05 for me in my truck till a fix comes out.
2001 S10 ZR2
Old 11-27-2005, 05:59 PM   #75
Chuck's Avatar
RoyN did you try the linear mode of speed vol?
2001 S10 ZR2
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
MediaEngine Beta 2 Released! phat_bastard Media Engine 13 09-20-2005 09:53 AM
FrodoPlayer 1.0.3 Beta Has Been released. frodobaggins FrodoPlayer 0 04-23-2004 04:37 PM
beta plug-in update, 2.03 has be released Blackwind Software & Software Development 3 02-19-2001 09:15 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
