Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-29-2005, 12:04 AM   #106
skippy76's Avatar
skippy76 is on a distinguished road
So, here is BETA 11b..
LOTS of nice changes:
- 3 stage gamma button (configurable through RRConfig)
- 3 stage skin button (configurable through RRConfig)
- fixed divide by zero problem
- added gpsskin indicator too (as well as gpsgamma indicator)
- Moved all skin / gamma settings to seperate window in RRConfig
- Added shufflevideo option (button / indicator)...
Big thanks to Chuck for working on the testing with me. We have done quite a lot so think that most if not all should be good now!
The only bug I know of is if you specify the gamma day time to be later than the night time...
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
skippy76 is offline   Reply With Quote
Old 11-29-2005, 12:24 AM   #107
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
When will you let me "review" the sources ?
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-29-2005, 12:26 AM   #108
skippy76's Avatar
Guino, for you man... whenever you like. I think we have got rid of most of the bugs. I want to double check that everyone is happy, and if so I'll pass them over to you. I did not want to do it too soon and end up having to make more changes!
06 Volvo XC90
Old 11-29-2005, 12:36 AM   #109
djmickyg's Avatar
djmickyg is on a distinguished road
Quote: Originally Posted by RoyN
Also, is there anything special that needs to be done for gps gamma to work? Testing the gamma through the button shows me day/night gamma, but gps gamma is on, offset=0, and still no dimming at night.... any idea? (Im probably missing something really stupid... Ill try time-based today)
i dont think mine is working either.. havent had a big play with it but it doesnt seem to me..
also, will RR make Freedrive switch to day and night?? and also will it record the last LAT & LOG so next time RR is started it will dim/brighten the screen before the gps software has opened??
djmickyg is offline   Reply With Quote
Old 11-29-2005, 12:39 AM   #110
skippy76's Avatar
djmickyg... nice ideas... Have you tried BETA 11b? I fixed a few major issues with the Auto Gamma / Skin stuff...
06 Volvo XC90
Old 11-29-2005, 12:45 AM   #111
djmickyg's Avatar
i think i have the latest
i will check now
edit: igot the one that came out on the 27th
i am redownloading anyways
Old 11-29-2005, 12:51 AM   #112
skippy76's Avatar
unless you downloaded it in the last 20 mins you don't have the latest.
[Edit] BTW, in the previous version if your offset was set to zero ( 0 ) then the gamma change would not work. I actually had a device by zero (d'oh)... but I've resolved that issue now, so you should be good in BETA 11b.
06 Volvo XC90
Old 11-29-2005, 12:53 AM   #113
djmickyg's Avatar
ok ive just downloaded it now
thanks.. i will have a play with this one
EDIT: all works good now.. i like alot
Old 11-29-2005, 12:58 AM   #114
tolisn's Avatar
tolisn is on a distinguished road
Well I tried out the auto-skin change in the new beta version (11b).It seem that the auto-skin change is directly linked to the auto-gamma selection. If you want auto-skin changing then you also have to select auto-gamma change in the config. utility. If only auto-skin change is selected and auto-gamma is set to disable then the skin will not change automatically. This observation was made without using a GPS (time based auto switching). Is this a normal behavior?
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 11-29-2005, 05:31 AM   #115
tolisn's Avatar
What is the button code for the 3stage skin button ? I've searched the skin commands.txt file but I cannot find it. Is it one of the old button or is it a new addition ?
Old 11-29-2005, 06:39 AM   #116
djmickyg's Avatar
i believe its the old button, it now has 3 positions so.. dark/light/auto
Old 11-29-2005, 09:37 AM   #117
skippy76's Avatar
Yes,
for skin it's daynightskin
for gamma it's gamma
tolisn: Actually, small oversight on my behalf. I've fixed the bug and BETA 11c will be there in about 20 mins.
[Edit]: It's just uploading... I've also added a command daynightgammaskin this button will change the state of both the gamma and the skin.
06 Volvo XC90
Old 11-29-2005, 01:55 PM   #118
Chuck's Avatar
Chuck is on a distinguished road
I think I found a bug in RR
Before if you use the RUN command in a button (RUN:C:\test\test.exe) and the exe file was not found it would ignore it and go on. But with new RR it will stop RR from running on my machine.
Button for truck and not on desktop
B33,162,394,150,63,"SHOWWINDOW;!Shell_TrayWnd;True ||RUN;C:\WINNT\TRTUTILS\TRTUTILS.EXE||SWITCHBUTTON ;1>>SHOWWINDOW;!Shell_TrayWnd;FALSE||CLOSEWINDOW;T ouchRight Utilities||SWITCHBUTTON;1",""
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-29-2005, 03:23 PM   #119
skippy76's Avatar
Chuck: This maybe something that Guino introduced. Can you try it with the latest release that Guino sent out?
06 Volvo XC90
Old 11-29-2005, 05:22 PM   #120
Chuck's Avatar
Same with RR 11-27-05
will post in 11-27-update
2001 S10 ZR2
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
MediaEngine Beta 2 Released! phat_bastard Media Engine 13 09-20-2005 09:53 AM
FrodoPlayer 1.0.3 Beta Has Been released. frodobaggins FrodoPlayer 0 04-23-2004 04:37 PM
beta plug-in update, 2.03 has be released Blackwind Software & Software Development 3 02-19-2001 09:15 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
