Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-29-2005, 05:25 PM   #121
skippy76's Avatar
skippy76 is on a distinguished road
Excellent, Guino has the source at the moment. I could take a look if I have time to figure out why it's broken, but best thing to do is to PM Guino.
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
skippy76 is offline   Reply With Quote
Old 11-29-2005, 05:47 PM   #122
Chuck's Avatar
Chuck is on a distinguished road
Indicators on both gamma and skin show activated when you have them disabled in config file
I think every thing else is good – still-hunting
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-29-2005, 05:58 PM   #123
Chuck's Avatar
Not trying to be a bad boy but
Cannot manually change gamma with button when auto gamma is disabled in config file and Use built in gamma is selected.
2001 S10 ZR2
Old 11-29-2005, 06:56 PM   #124
skippy76's Avatar
Chuck: Re your second bug: Yes, that's normal. This one will go on the list of 'may fix this one day'.
Chuck: Re your first bug: Ok, I'll add this to the list of bugs to fix and shall fix in a future release (severity: low).
06 Volvo XC90
Old 11-30-2005, 04:57 AM   #125
mauri's Avatar
mauri is on a distinguished road
Hi Skippy,
I have sent my question above to Guino,but he already has a lot of job with RR...
I ask if is possible to do you this thing and implement for RR....
Mauri
Quote:
Originally Posted by mauri
@Guino
Is it possible to add one custom indicator for displayed the Low Batt in my voltimeter?
Type:
If Vbatt is < 11.3v or another settings blink one indicator skinned.
Mauri
Quote:
Originally Posted by Guino
I'll add to the todo list... but this will be more complex cause I'll make dynamic indicator codes for any value readings available to RR... (temp sensors, Phidgets, etc)...
mauri is offline   Reply With Quote
Old 11-30-2005, 08:42 AM   #126
skippy76's Avatar
Mauri: If you PM me with detailed requirements I shall add it to my list. I won't be done in the next two releases but I may certainly try to get to it.
06 Volvo XC90
Old 11-30-2005, 08:58 AM   #127
tolisn's Avatar
tolisn is on a distinguished road
Hey Skippy
Do you have any plans of implementing parallel port Input/output in the near future?
We can use this to switch between skins, for instance if one bit of the parallel port is hooked up to the reverse lights, the backup camera screen can come up. Or we can use it for auto switching day/night skins based on if the car lights are On or OFF. Do you think something like that can be implemented or am I just dreaming?
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 11-30-2005, 09:16 AM   #128
skippy76's Avatar
I'll take a look into it, I've added it to my list of 'to do's'
http://www.mp3car.com/vbulletin/road-runner/63646-do-list-road-runner-skippy76.html
06 Volvo XC90
Old 11-30-2005, 09:20 AM   #129
mauri's Avatar
PM send
Mauri
Old 11-30-2005, 09:25 AM   #130
skippy76's Avatar
tolisn: Do you have some code in VB that already does this? If you know any VB then feel free to knock up a very simple app then I shall integrate into RR for you.
Saves me a lot of time and also get's your request done faster...
06 Volvo XC90
Old 11-30-2005, 09:34 AM   #131
mauri's Avatar
@Skippy
Thanks for you fast PM reply
All OK !
Mauri
Old 11-30-2005, 11:35 AM   #132
tolisn's Avatar
I would love to help out on this great and ever expanding project but unfortunately I do not have any coding skills. After having a second though about this parallel port request It looks to me that we should ditch the parallel port implementation and focus on better integration and full support of the phidget 8/8/8 module. It would be the best choice because many people around the board have these and it will also be a waist of coding time since the phidget board has already been supported to some extent.
I would like to thank you for your time and effort to support and fulfill every request that we make. Thanks a million
Old 11-30-2005, 04:48 PM   #133
skippy76's Avatar
No problem. I'm pleased that:
a) You've taken the time to let me know so that I don't waste my time.
b) You've decided that the Phidget board is the best way to go, as it its!
06 Volvo XC90
Old 11-30-2005, 05:22 PM   #134
MoonShiner's Avatar
MoonShiner is on a distinguished road
shufflevideo command
Skippy,
I'm trying to test the shufflevideo command, is it working? I can't seem to get the videos to shuffle. I'm using the internal video player (I assume it's media player classic).
Also, which line in resume.ini refers to the videoshuffle?
Any help is appreciated.
Thanks!
MoonShiner is offline   Reply With Quote
Old 11-30-2005, 06:41 PM   #135
p1cass0 is on a distinguished road
Skippy, tolisn. I raised the parallel port idea a while ago and it did receive some interest. Since then I've started to put some VB code together myself to do this. I'm no programmer so it's not pretty so forgive it's crudeness, well the parts that i created aren't but the examples I borrowed from Guino are, thanks Guino :-). Anyway if you or anyone else wants to finish it and develop it further I would be delighted and so have attached the source code here. All I would ask is that anyones efforts are made available to everyone to take advantage of. It actually uses the SDK to interface to RR and uses a dll I found freely available on the Web so I hope I'm not infringing any copyright by including it here. I haven't worked on it for a while and I can't even remember what state its in but it did work. Unfortunately I have to finish building the car first before implementing the carPC so this isn't high priority. Hope someone can find the time to develop it so it can realise its full potential.
p1cass0 is offline   Reply With Quote
Next release (BETA 10) delayed skippy76 Road Runner 7 11-24-2005 11:29 PM
MediaEngine Beta 2 Released! phat_bastard Media Engine 13 09-20-2005 09:53 AM
FrodoPlayer 1.0.3 Beta Has Been released. frodobaggins FrodoPlayer 0 04-23-2004 04:37 PM
beta plug-in update, 2.03 has be released Blackwind Software & Software Development 3 02-19-2001 09:15 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
