01-07-2006, 09:53 PM
#136
Raw Wave
i wrote it with that function in mind i removed it at the last minute
i can put it back in easily
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
01-07-2006, 11:13 PM
#137
If you could, that'd be great!
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
01-08-2006, 01:57 AM
#138
Ok , I will hold off updating everything till I hear from you lostreception
01-08-2006, 11:28 AM
#139
Quote: Originally Posted by Chuck
Lucianop I can make one without the color picker for now if you want me to?
here it is
01-08-2006, 11:30 AM
#140
Update 1-8-06
All files in post 2 are updated
Last record saved
This will make it so the last record saved will be the 1st one to come up
Restricted area fixed again
Added button down
Thx lostreception for the update
01-08-2006, 11:36 AM
#141
Raw Wave
Quote: Originally Posted by Meelobee
For those intrested; I've attached a jpg of the chalkboard I used in the picture above.
How did you integrate this, I cant find a way
01-08-2006, 02:38 PM
#142
Raw Wave
OK, this is a cool utility, but I have 2 comments/suggestions:
1) Could you remove the frame around the window, so that when we embed the frame is not shown? (and hence, looks more 'integrated' in our frontends)
2) If I save a record, the SAVE button changes to ERASE. This is OK, but if I go to another record, and then back to the saved record, it still shows ERASE. So, If I want to make an addition to that record (scribble a bit more) I have no way of saving the changes because the SAVE button is gone (I can only hit ERASE).
01-08-2006, 02:39 PM
#143
Raw Wave
the bg of draw will be transparent only if you use the swf to embed in rr all you then need to do is place that jpg in the skin your using see the post a while back where i posted a pic embedded in MC 2.0
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-08-2006, 02:42 PM
#144
Raw Wave
Ah nice one
01-08-2006, 02:46 PM
#145
Raw Wave
JIT
http://www.mp3car.com/vbulletin/show...4&postcount=86
as for the frame i dont know quite what you mean unless your referring to the e.exe if thats the case the final version of the exe will not have a border
2) alittle bit more tricky its not undoable but when someone asked for complete removal i did that for them i could make then separate buttons but right now i need to focus on the vehicle maintenence program
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-08-2006, 03:03 PM
#146
Raw Wave
lostreception: I did not realize you had a separate SWF file... I assume the EXE file simply embeds the swf content, with a frame...?
If I were to use this in CentraFuse, for example, I think the exe is my only option. Not sure I can run a swf by itself, still investigating.
01-08-2006, 03:15 PM
#147
Raw Wave
jit yes your right it just embeds it as to whether or not ransparency is supported in the bg of the exe AFAIK only by buying a 3rd party app can transparency be achieved within the exe
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-08-2006, 03:16 PM
#148
Raw Wave
Can't get the swf to work in RR, it appears hidden, any ideas?
01-08-2006, 03:20 PM
#149
Raw Wave
to be clear, I'm only complaining about the frame (the border) drawn around the exe file window....
01-08-2006, 03:52 PM
#150
Witch are you using?
| Thread Tools |
| Display Modes |
Linear Mode
