Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 01-08-2006, 03:52 PM   #151
Raw Wave
Gobby is on a distinguished road
The one in post 1 or 2 I think
Gobby is offline   Reply With Quote
Old 01-08-2006, 04:29 PM   #152
Chuck's Avatar
Chuck is on a distinguished road
pm sent
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 01-08-2006, 04:49 PM   #153
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
chuck we should make a generic .skin and bundle it that way we know what were dealing with also im gonna take down all past releases
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 01-08-2006, 05:01 PM   #154
Raw Wave
Thanks for the help chuck, for anyone else, I had to move the .swf to the skins folder not in a separate path.
Old 01-08-2006, 05:28 PM   #155
Chuck's Avatar
Quote: Originally Posted by lostreception
jit yes your right it just embeds it as to whether or not ransparency is supported in the bg of the exe AFAIK only by buying a 3rd party app can transparency be achieved within the exe
Ok - I will put all files in each zip file in post #2
Those files are all fixed with
Last record saved
Restricted area fixed
Added button down
I went thru all post in this thread and took out all others
2001 S10 ZR2
Old 01-08-2006, 07:50 PM   #156
Chuck's Avatar
Update 1-8-06 PM
Added all needed files in each zip file
2001 S10 ZR2
Old 01-08-2006, 08:00 PM   #157
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Quote: Originally Posted by Chuck
Update 1-8-06 PM
I don't see the EXE in any of the archives. Is it not needed anymore? I have not been able to run the SWF files by themselves... they have a generic icon, indicating that I don't have an app associated with them... ideas?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 01-08-2006, 08:03 PM   #158
Raw Wave
@chuck
when publishing these also publish the projector as an option its a standalone exe that will print with the swf embedded
its in file>publish setting> format on my version
check yours
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-08-2006, 08:07 PM   #159
Raw Wave
justintime's Avatar
Thanks guys, this is a useful tool that I plan to use.
I just noticed the whole thing (buttons, fonts etc) resize when the window resizes. Not sure if that was intentional, but in this case I see that as an unwanted feature... the reason is that usualkly people will skin buttons using an exact size, and don't want things to be resized (you lose the 1:1 pixel structure originally designed into the image file, because it stretches out).
Just nitpicking at this point Thanks for all your hard work.
2002 Honda CR-V
Old 01-08-2006, 08:18 PM   #160
Raw Wave
i know what you mean about the sizing however with different resolutions and skin areas there is not way to standardize the size besides stretching or making a version for every screen size
if the program is opened in its original state it will have the 1-1 ratio
is anyone knows a good solution for this id love to have it as im confronted with a similar problem with vehicle maintenence
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-08-2006, 08:38 PM   #161
Raw Wave
justintime's Avatar
Why not let every button relocate upon window resize, but maintain each image original size even after relocating them? I'd say, relocate based on the upper left corner of each image. If you can put a toggle in the config file, all the better -- this way people can force image resize if they want to.
Sorry, don't have any other ideas.
2002 Honda CR-V
Old 01-08-2006, 08:43 PM   #162
Raw Wave
that would unfortunatly be a huge amount of work each x and y width height i have well over 100 objects to move in that program :-/
not that its not doable just a headache and a half
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-09-2006, 12:26 AM   #163
Mattkins99's Avatar
Mattkins99 is on a distinguished road
ok, sorry to bring up another problem... but erase doesn't seem to fully work. When I save more than one drawing/doodle/whatever, close out of the program and then relaunch it, it takes me to the last doodle, however, if I then erase all of my doodles (or just a couple), close out and relaunch, I'm still taken the the last drawing (say it was record 4) even though that record, and all the records previous are blank.
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
Old 01-09-2006, 12:41 AM   #164
tolisn's Avatar
tolisn is on a distinguished road
How hard would it be to include a button, that when pressed, will close the application and return to the screen that is was called from ? This way we would not require any skinned button from RR to close the application thus conserving screen space.
Thanks for all you time and efforts
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 01-09-2006, 03:24 AM   #165
Raw Wave
thats the best its gonna be for now i can make a better version later for sure a few clicks wont be that bad for the time being also im going to make it so that draw is global meaning no matter what version (file) you open the drawings will be there preloaded
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
