The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 01-03-2006, 02:43 AM   #61
Raw Wave
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
Quote: Originally Posted by wysocki
Same here. I put this command on a button in my main screen (and used my iGuidance skin) for it.
B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;Draw;C:\ PROGRA~1\ROADRU~1\SKINS\DRAWANDSAVE.EXE;Draw"
Does this look ok? The app doesn't come up on my XPsp2 system, but it will start by itself.
try
B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;RUN;C:\PROGRA~1\ROADRU~1\SKINS\DRAWANDSAVE.EXE;Draw"
if that doesnt work try going without progra~1 and type it out in its entirety
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Sponsored Links
Old 01-03-2006, 05:26 AM   #62
mauri's Avatar
My Photos: (0)
Tested,skinning the buttons for my use, and work PERFECTLY embeddded with RR and APPS application launch ....best work!
Mauri
mauri is online now   Reply With Quote
Old 01-03-2006, 06:41 AM   #63
Clarre's Avatar
Vehicle: 1993/VW/Passat
My Photos: (0)
What can I do for having the save&draw open in fullscreen? IMO I've got a larger textarea.
Via Epia M1000
512MB RAM
120MB IBM Hard drive
Netgear MA111
Lilliput 8" Touchscreen
http://www.clarre.com/carcomputer.htm
Clarre is offline   Reply With Quote
Old 01-03-2006, 06:59 AM   #64
Viscouse's Avatar
Vehicle: 2003 Saab 9³
My Photos: (0)
Ditto, another plug for working perfectly in RR, in Apps, and embedded in it's own window.
Here's the code I used to give it it's own dedicated button on the MAIN page using the IG skin, same as you:
B15,113,10,60,70,"LOAD;draw.skin;;c:\drawandsave.e xe;Draw"
I found I needed 2 semicolons after the skin name. The format is (I think) "load;skinfile;verbalcommand;filelocation;embedded windowname"
I wussed out & just put it under C:/ though. If my code doesn't work, try it with the prog in C:/, then once it works put it somewhere else & see if you need to spell out the directory name.
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline   Reply With Quote
Old 01-03-2006, 08:27 AM   #65
kbreeden's CarPC Specs
Vehicle: 2005 Acura TL
My Photos: (0)
Quote: Originally Posted by Escalade182
chuck, how far is ocean city and frederick from ellicot? sounds so familier I just cant seem to remember where it is.
About 150 miles west of the ocean and 45 miles east of Frederick.
kbreeden is offline   Reply With Quote
Old 01-03-2006, 08:33 AM   #66
Civic03's Avatar
My Photos: (0)
Ok, now I'm going to take this to another level!! Wouldn't it be nice if you could use NaviVoice and have this write for you as you speak? I mean think of it this way; you're driving and you get a call and have to take a number down. You bring up this app, say the text and it writes it down for you and save it. Perfect!!
What do you think guys?? Is this even possible?
PROGRESS 95%[//////////]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
Civic03 is offline   Reply With Quote
Old 01-03-2006, 12:17 PM   #67
Chuck's Avatar
Vehicle: 2001 Chevy S10 ZR2
My Photos: (0)
Update 1-3-06
Thanks to lostreception this is the greatest
see post #1
2001 S10 ZR2
Chucks Skin
Chuck is offline   Reply With Quote
Old 01-03-2006, 12:30 PM   #68
ITL
ITL's Avatar
Vehicle: 2004 Acura TL 6MT
My Photos: (0)
awesome little app....thanks Chuck and lostreception.
My $1200 etch-a-sketch is finally in place
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 01-03-2006, 12:57 PM   #69
Meelobee's Avatar
Vehicle: VW GOLF Mk5.
My Photos: (0)
I use this code on my button:
B09,0,460,160,70,"LOAD;scribble.skin;;c:\draw\draw andsave.exe;Draw"
The scribble.skin screen opens, but the draw app isn't visible. (doesn't appear to start at all) The path c:\draw\drawandsave.exe is correct.The app works fine when I click the .exe outside RR. What am I doing wrong?
Edit: Hmm, don't I need some indicator on the scribble.skin to define where drawandsave.exe is shown? Which label should I use?
[■■■■■■■■■■■■■■■■■■■■] Install 80%
WWW.ZDCLAN.NL
Meelobee is offline   Reply With Quote
Old 01-03-2006, 01:16 PM   #70
Chuck's Avatar
My Photos: (0)
you need to add something like this to your draw skin
/, A, x, y, w, h, color;RGB
A,17,98,600,415,
2001 S10 ZR2
Chucks Skin
Sponsored Links
Old 01-03-2006, 01:22 PM   #71
Meelobee's Avatar
My Photos: (0)
I've put this in my skin:
A01,45,70,710,477,0
and it still won't show
WWW.ZDCLAN.NL
Old 01-03-2006, 01:32 PM   #72
My Photos: (0)
NaviVoice memo
I think using notepad as NaviVoice currently has built in support works well enough, no?
Curious, have you found using letters and numbers work accurately enough? I changed to using a phonetic ie alpha, bravo etc. works more accurate with less false interpreted commands thinking I said a letter.
kth
whodwho is offline   Reply With Quote
Old 01-03-2006, 01:37 PM   #73
Civic03's Avatar
My Photos: (0)
I guess you're right, you can use voice to open notepad, voice type your message and save it and close it. Hmmm, I guess it's about the "fun" aspect now!
I use NaviVoice and typing with it is a bit slow but I don't know if that is configuation issue. Any links to good voice recog. sites?
My Carputer Blog
Car System Site
Old 01-03-2006, 01:37 PM   #74
Raw Wave
My Photos: (1)
chuck are you using win 2k it may be possible these problems arent isolated
if you have this working in XP any sp please post... thx
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-03-2006, 02:37 PM   #75
Chuck's Avatar
My Photos: (0)
I have xp desktop and 2k truck and both work with no problems using the .exe
But with the .swf in RR the background is transparent and it will not draw. -or you cant see it
I like using .swf better because
1 you do not need a button to load the draw app
2 when you quit RR the app closes
3 when you have another app open with the word (draw) in it will not suck into RR window
4 loads smoother
5 you can have more then one app in a skin
6 if you use /DISCARDABLE in a skin it will close the app when ever you go to another skin
what is thx?
2001 S10 ZR2
Chucks Skin
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
