01-04-2006, 03:20 PM
#91
I see that the correct folder has been created under the Documents and Settings tree, but there are no *.sol files there or anywhere else on the drive.
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
01-04-2006, 03:34 PM
#92
Raw Wave
also it sound like you may not have shared object implemented then being as its not saving ...
***IMPORTANT FOR ALL OTHER WHO SAVE DOES NOT WORK FOR****
try this go to the app right click and select settings then make sure flash can save locally (move the slider)
you can figure out how much storage you need by assuming the average scribble will be between 5-8k in size saved locally i left 10 megabytes to potentially store things
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
01-04-2006, 04:00 PM
#93
I right clicked the screen and went into SETTINGS and adjusted my local disk size to 10mb. But curiously, the ABOUT said that I had version 6. I checked the macromedia website and it said I have version 8,0,22,0 installed on my computer. When I exit the app, the disk size goes back to what it was initially (100k).
01-04-2006, 07:59 PM
#94
I love this. This is a great tool. I can't tell you how many times I've needed to write something down in my car, but couldn't find a pen so I had to root around my car looking for the damn keyboard.
This is great!
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
01-04-2006, 08:32 PM
#95
I use it several times a day and I don’t think I could do without it any more.
01-04-2006, 08:36 PM
#96
Raw Wave
that is strange but if your using the exe i belive this is how it works i encoded the app with flash6 so to exe is not going to update itself unless you have a greater version of the flash player installed try the swf i posted and load it into rr and see if it works or dl one of chucks versions and see if that exe works he is using flash 8
BTW flashplayer 8 is the version installed for playing swfs over the internet not locally thru the exe AFAIK
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-04-2006, 10:29 PM
#98
Raw Wave
Quote: Originally Posted by Chuck
Is someone lying?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-05-2006, 12:12 AM
#99
The Curator
look at the drawing...it looks like lie detector test....
01-05-2006, 06:03 AM
#100
Where does it store the messages ?
Sorry, Lostreception already explained. Didn't search hard enough I think.
BTW, nice work again Chuck.
Car : Hyundai Tucson
Carpc :
Lilliput 7" touchscreen indash 90% done
PSU : M2-ATX
Epia M10K /512DDR/80GB Maxtor
Software : Windows XP Pro 100% done
RR with DigitalFX skin
In car : 80% done
01-05-2006, 06:18 PM
#101
Update 1-5-06 - see post #2 for new .swf files
lostreception was kind enough to send me his .fla file or this grate app he made with all the fixes…… thx lostreception
So I have made some draw&save.swf files with all the fixes - left side menu – bottom menu – small left menu.
If someone needs a different one just let me know
01-05-2006, 07:08 PM
#102
Raw Wave
Any chance of a copy of the older buttons?? Prefered them much more than the current ones ... sorry to be a pain.
01-05-2006, 07:56 PM
#103
My type buttons
01-05-2006, 08:46 PM
#104
Raw Wave
wow nice work with the different versions
ive been so busy i only had time to write it thanks alot for supporting it and making some real nice changes
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
01-05-2006, 10:04 PM
#105
I extracted the swf from drawsmleft.zip and doubleclicked it to run it. It is the first one I've found that saves the drawings. Don't know why the exe and other swf's didn't but I'm happy with this one anyway. The problem is, how do I run the swf instead of the exe from RR? Here's my button command line for the exe:
B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;Sketchpa d;C:\PROGRA~1\ROADRU~1\LAUNCH\DRAW\DRAW&SAVE.EXE;! ShockwaveFlash!Draw"
I've tried replacing the exe with swf with no luck. How do I run a swf from within RR?
| Thread Tools |
| Display Modes |
Linear Mode
